• Hardware Platform (Jetson / GPU) AGX Xavier
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
I am able to create my own newplugin using gst-dsexample and tested under the same element name “dsexample” and lib name libnvdsgst_dsexample.so.
Next step, create a new element name “newplugin” and lib name still using libnvdsgst_dsexample.so and it still works perfectly.
But when I try to spin out as a new libnvdsgst_newplugin.so by changing the Makefile:
from
LIB:=libnvdsgst_dsexample.so
to
LIB:=libnvdsgst_newplugin.so
I am able to “make” and “make install” without error. But when I run the pipeline or gst-inspect-1.0 newplugin and cannot find the element. If I resume the Makefile back to:
, and make/make install again, then I can run the pipeline or gst-inspect-1.0 newplugin again.
I wonder is there any step I am missing to “register” the “libnvdsgst_newplugin.so”? how? Please help. Thanks a lot.
P.S. I did “rm .cache/gst-gstreamer-1.1/registry.x86_64.bin” for element rescan/register. But it still behaves as above.
