Hi
I work with tx1+SDK 28.2; the speaker device is tas5751, it always sound less. I have no idear to debug it!! help help help
kernel show trace as follow :
[ 18.067337] tegra210-i2s tegra210-i2s.0: Failed at I2S0_RX sw reset
[ 18.082612] tegra210-i2s tegra210-i2s.0: ASoC: PRE_PMU: I2S1 DAP RX event failed: -22 -
my dts as follow:
gpio: gpio@6000d000 {
gpio-init-names = “default”;
gpio-init-0 = <&gpio_default>;gpio_default: default { /* Transfer pins from GPIO to I2S for audio. */ gpio-to-sfio = < /* GPIO# TX1-PIN TX1-FUNC/ERA-FUNC CODEC-PIN */ TEGRA_GPIO(B, 0) /* 8 H1 I2S0_LRCLK/SFSYNC R335/3 */ TEGRA_GPIO(B, 1) /* 9 G1 I2S0_SDIN R339/5 */ TEGRA_GPIO(B, 2) /* 10 H2 I2S0_SDOUT R337/4 */ TEGRA_GPIO(B, 3) /* 11 G2 I2S0_CLK/SRCLK R334/2 */ TEGRA_GPIO(K, 0) /* 80 D13 I2S1_LRCLK/SFSYNC */ TEGRA_GPIO(K, 1) /* 81 C14 I2S1_SDIN */ TEGRA_GPIO(K, 2) /* 82 D14 I2S1_SDOUT */ TEGRA_GPIO(K, 3) /* 83 C15 I2S1_CLK/SRCLK */ TEGRA_GPIO(BB, 0) /* 216 F1 AUDIO_MCLK R1/R332/1 */ >; }; }; sound_card: sound { compatible = "nvidia,tegra-audio-t210ref-mobile-rt565x"; nvidia,model = "tegra-snd-t210ref-mobile-rt565x"; clocks = <&tegra_car TEGRA210_CLK_PLL_P_OUT1>, <&tegra_car TEGRA210_CLK_PLL_A>, <&tegra_car TEGRA210_CLK_PLL_A_OUT0>, <&tegra_car TEGRA210_CLK_D_AUDIO>, <&tegra_car TEGRA210_CLK_CLK_M>, <&tegra_car TEGRA210_CLK_EXTERN1>; clock-names = "pll_p_out1", "pll_a", "pll_a_out0", "ahub", "clk_m", "extern1"; assigned-clocks = <&tegra_car TEGRA210_CLK_PLL_A>, <&tegra_car TEGRA210_CLK_PLL_A_OUT0>, <&tegra_car TEGRA210_CLK_D_AUDIO>, <&tegra_car TEGRA210_CLK_EXTERN1>; assigned-clock-rates = <368640000>, <36864000>, <36864000>, <12288000>; nvidia,num-codec-link = <2>; nvidia,audio-routing = "x Headphone", "x OUT", "x IN", "x Mic", "y Headphone", "y OUT", "y IN", "y Mic", "l Headphone", "l OUT", "l IN", "l Mic", "s Headphone", "s OUT", "s IN", "s Mic", "w Headphone", "w OUT", "w IN", "w Mic", "z IN", "z Mic"; nvidia,xbar = <&tegra_axbar>; /* The codec-dai here is initialized to dummy and will be */ /* replaced with rt565x codec-dai on detecting super-module */ nvidia,dai-link-1 { link-name = "rt565x-playback"; cpu-dai = <&tegra_i2s1>; codec-dai = <&spdif_dit4>; cpu-dai-name = "I2S1"; codec-dai-name = "dit-hifi"; format = "i2s"; bitclock-master; frame-master; bitclock-noninversion; frame-noninversion; bit-format = "s16_le"; bclk_ratio = <2>; srate = <96000>; num-channel = <2>; ignore_suspend; name-prefix = "y"; }; nvidia,dai-link-2 { link-name = "tas5751-playback"; cpu-dai = <&tegra_i2s5>; codec-dai = <&tas5751>; cpu-dai-name = "I2S5"; codec-dai-name = "tas5751-speaker"; format = "i2s"; bitclock-slave; frame-slave; bit-format = "s16_le"; bclk_ratio = <2>; srate = <96000>; num-channel = <2>; ignore_suspend; name-prefix = "x"; };
