Lev: forgot to mention the occupancy of 0.25 was for the 43 register case. From my occupancy calculator it should be 0.50 using compute capability 1.3 with 32 registers.
WIth those 4 lines of math code, the 4 lined up, one of them you mentioned about lev, I have bene playing with that recently. That value use to be pre-computed for each pixel and passed into the kernal and now i changed it to be computed on the fly. But yes you are write, it on depends on the outter loop and not the inner loop, I assumed the compiler would take care of it. I moved those 4 lines out of the inner loop into the outer loop and running a test now.
Note that your reads from [font=“Courier New”]pR_table[/font] are not coalesced, so you are wasting a significant amount of your device memory bandwidth. Because of this, I would assume that at the moment you are limited by memory bandwidth, even though only a fraction of the peak bandwidth is actually used.
I haven’t used the profiler for a while, but I’d expect the instruction throughput for a computationally limited kernel to be (close to) 1 or higher. This would again hint that memory bandwidth (or it’s efficient use) is the limiting factor at the moment.
Note that even if you want to keep [font=“Courier New”]pR_table[/font] in global memory, you could at least reorder the indices to achieve coalesced access.
Moving r_table to be recomputed further increased out speed, we are up to 6.8x now. Does this mean we are probably bandwidth limited? It’s time to coalesce the pImage. So the best way to coalesced is to setup my memory accesses so the most amount of threads are “fed” data in the smallest data load from global memory I guess.
Yeah, I compute a 8192x8192 image which takes about 5 minutes to run for my short test case and I put it in the profiler. I just need to learn what all the numbers mean and what they are hinting to me to what the bottleneck is.
Can you replace
pImage[ bigYOffset + bigXOffset ] += storedValue;
with temp+=storedvalue;
pImage[ bigYOffset + bigXOffset ]=temp; after cycle?
And see is there any time difference. Also time difference with 32 and 48 registers wiht square root out of cycle. Compiler may precompute it, interesting to check with small test case.
Also I suggest to change all numbers and variables to floats, just to see what performance gain can you have if you get rid from doubles. It is simple I think. Do npot forget to change 1.0 to 1.0f.
I think my instruction throughput increased when I moved r_table into being computed on the fly, and maybe that gave me the speed increase. Not sure exactly how to increase instruction throughput though,there seems to be a few ways… Still not sure what I’m limited on.
I also tried computing cos values on the fly. But it almost trippled my running time. I’m not sure how I could use cospi function directly, I think i’ll have to change my calculation a little to be able to use it,
Hmm not exactly, since this loop computes many pixels, at the moment it is doing a 5x5 patch of pixels per thread. So thats 25 pixels, so I would need 25 local temp variables. I was thinking of making it only do say, 2x2 pixel grid, which is 4 pixels per thread, and i’m using 256 threads per block, which means i’ll use up 4k of shared memory. At the cost of more memory transfers( device to host) because I have to compute smaller sub images.
Yeah it’s time to fiddle with these doubles I think as well.
Also going to coalesce image pixel accesses which will require lots of code changes, so delaying it until I figure out if it is needed or not. By the looks of it, coalescing is always needed where its possible.
Your low instruction throughput means you are limited by something else - global memory throughput probably.
Using cospi() is easy. Just replace [font=“Courier New”]cos(M_PI*x)[/font] with [font=“Courier New”]cospi(x)[/font]. In you case the code reduces nicely, instead of
The original computation computes cos (M_PI * 2.0 * (float)(indx + indx -1) / 2.0 * (float)(NUMTBL)), Since the factor of two occurs in both the numerator and the denominator, it cancels, and can be removed. The use of cospi() instead of cos() takes care of the multiplication with M_PI, leaving
