Good morning everyone,
So recently I have been debugging a code of mine in which I try to optimize the GPU usage by allocating information into registers. I pay attention to the NVCC output so that spilling is 0 and there is not any allocation to local memory whatsoever. However, when looking at Nvidia Nsight Compute, it is saying me that there are loads of information that are being transfered to local memory instead of using registers. As the NVCC tells me that there is no spilling/local memory allocation, why is this happening? I created small algorithm that replicates this issue, in which the NVCC tells you that there has been 0 spills, with no reference to local memory, but then the Nsight Compute shows you that there’s been spilling to local memory.
The algorithm is below:
#include "cuda_runtime.h"
#include "device_launch_parameters.h"
#include <stdio.h>
__global__ void addKernel(float*a, float*b)
register float TData[8*36];
int warpID = (threadIdx.x >> 5);
for (int i = 0; i < (8 * 36); i++)
TData[i] = a[i+(8 * 36* warpID)];
for (int j = 0; j < (8 * 36); j++) {
TData[j] = TData[j] * 1.24;
for (int z = 0; z < (8 * 36); z++)
b[z + (8 * 36* warpID)] = TData[z];
int main()
const int arraySize = 8*36*4;
float a[arraySize] = { 1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,
1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36 ,
1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36,1, 2, 3, 4, 5,6,7,8,9,10,11,12,13,14,15,16,17,18,19,20,21,22,23,24,25,26,27,28,29,30,31,32,33,34,35,36 };
float*d_a, *d_b;
float b[arraySize];
cudaMalloc(&d_a, arraySize * sizeof(float));
cudaMalloc(&d_b, arraySize * sizeof(float));
cudaMemcpy(d_a, a, arraySize * sizeof(float), cudaMemcpyHostToDevice);
addKernel << <1, 128,0,0 >> > (d_a, d_b);
cudaMemcpy(b, d_b, arraySize * sizeof(float), cudaMemcpyDeviceToHost);
return 0;
The GPU is the RTX2060 and it’s running on CUDA 10.2. If you need any more information I will be pleased to provide it.
Thanks for any help you can bring!
