I have tried to pull the image deepstream:6.1-devel from the registry, following the commands from Application Workflow in three different environments Ubuntu 18.04, 20.04, 22.04.
In the extracting phase I get always the same error: failed to register layer: Error processing tar file(exit status 1): Container ID 71873 cannot be mapped to a host ID
As far as I know, in a linux env you don’t have to specify the resources that docker is about to use.
However, I’ve tried to pull the image in two different machines which are 16 & 32 GB of RAM, the image size of the 6.1-devel is around 8.8 GB and it fails in both.
Yes, the result is active (running) I can pull other images (e.g. 6.0-devel or 6.1-base) but not the 6.1-devel.
In the attached picture you can find the error when pulling.
