Regression in latest legacy driver: "error C0118: macros prefixed with 'GL_' are reserved"
Now Paraview 3.14.1 spits out this with the LIC plugin:
ERROR: In /home/utkarsh/Kitware/superbuild/paraview/src/paraview/VTK/Rendering/vtkShaderProgram2.cxx, line 497
vtkShaderProgram2 (0x454af20):  a shader failed to compile. Its log is:
0(19) : error C0118: macros prefixed with 'GL_' are reserved
0(20) : error C0118: macros prefixed with 'GL_' are reserved
0(21) : error C0118: macros prefixed with 'GL_' are reserved
0(22) : error C0118: macros prefixed with 'GL_' are reserved
0(23) : error C0118: macros prefixed with 'GL_' are reserved
. Its source code is:
//  Program:   Visualization Toolkit
//  Module:    vtkColorMaterialHelper_vs.glsl
//  Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
//  All rights reserved.
//  See Copyright.txt or http://www.kitware.com/Copyright.htm for details.
//     This software is distributed WITHOUT ANY WARRANTY; without even
//     the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR
//     PURPOSE.  See the above copyright notice for more information.
// Id: Id
#version 110
#define GL_AMBIENT 1
#define GL_DIFFUSE 2
#define GL_SPECULAR 3
#define GL_AMBIENT_AND_DIFFUSE 4
#define GL_EMISSION 5
uniform int vtkColorMaterialHelper_Mode;
gl_MaterialParameters getMaterialParameters()
  if (vtkColorMaterialHelper_Mode == 0)
    return gl_FrontMaterial;
  gl_MaterialParameters materialParams = gl_FrontMaterial;
  if (vtkColorMaterialHelper_Mode == GL_AMBIENT)
    materialParams.ambient = gl_Color;
  else if (vtkColorMaterialHelper_Mode == GL_DIFFUSE)
    materialParams.diffuse = gl_Color;
  else if (vtkColorMaterialHelper_Mode == GL_SPECULAR)
    materialParams.specular = gl_Color;
  else if (vtkColorMaterialHelper_Mode == GL_AMBIENT_AND_DIFFUSE)
  else if (vtkColorMaterialHelper_Mode == GL_EMISSION)
    materialParams.emission = gl_Color;
  return materialParams;
Is there any workaround like setting an environment variable or adding something to nvidia-application-profiles?
nvidia-bug-report.log.gz (51.4 KB)
