With 2026.09.15_UE5.8_DLSS4.5Plugin_v8.8.0 in Unreal Editor 5.8.3, I can add r.NGX.DLSS.Denoisermode 1to Start Console Commands in the Console Variables tab in Movie Render Queue settings to use DLSS-RR in MRQ renders.
But with 2026.10.16_UE5.8_DLSS4.5Plugin_v8.9.0, this no longer works and also causes an issue where the r.NGX.DLSS.Denoisermode 1 command somehow resets the DLSS cvars set in DefaultEngine.ini for the rest of the session.
I’ve run into the same issue. I also tried configuring it via nodes in MRG, but I still can’t enable DLSS-RR.
Thank you for the notification!
I shared this with the Team, they should be able to look into it.
Hello, I would like to share some additional findings regarding the use of DLSS-RR on MRQ and MRG (I later checked the DLSS documentation, which states that DLSS-RR does not support MRG for the time being; nevertheless, I did some experimentation).
I’m attempting to use this in MRG because I stumbled upon this feature. In MRQ, once I add the “DLAA/DLSS” option in the settings, the DLSS Denoiser gets forced to 0 — meaning DLSS-RR is disabled — regardless of the CVAR setting. The DLSS Denoise value stays at 1 (enabled) only when this option is unchecked. Even with DLSS Denoise set to 1, the rendered result still looks drastically different from the viewport with DLSS-RR active.
MRG works by connecting nodes. My initial idea was to chain them in a specific order, but evidently, as soon as the “DLSS” render node is connected, the DLSS Denoiser configuration is still forced to 0 (off).
