I am trying to get Displayport output on a custom carrier board to which I have routed DP0 to a mini-dp connector.
On the reference schematic it says this is normally eDP but from the TRM it says DP can be output, by configuring HPD and pulls on the aux channel.
The device tree as been configured for both sor1 and sor to output on dp1 and dp0 and the nvdisplay’s enabled.
I can see video on dp1 however nothing when switching to dp0.
When I plug in to a monitor I get the following output for dp0.
[ 132.332331] tegradc 15220000.nvdisplay: dp: plug event received
[ 132.338455] hpd: state 3 (Disabled), hpd 1, pending_hpd_evt 1
[ 132.344323] hpd: switching from state 3 (Disabled) to state 0 (Reset)
[ 132.387324] hpd: state 0 (Reset), hpd 1, pending_hpd_evt 0
[ 132.392893] tegradc 15220000.nvdisplay: blank - powerdown
[ 132.398474] hpd: hpd_switch 0
[ 132.401561] tegradc 15210000.nvdisplay: blank - powerdown
[ 132.401660] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 132.411332] hpd: state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[ 132.411350] hpd: switching from state 1 (Check Plug) to state 2 (Check EDID)
[ 132.426986] tegradc 15220000.nvdisplay: blank - powerdown
[ 132.471290] hpd: state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[ 132.477905] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 132.486613] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 132.495329] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 132.502414] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 132.512090] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 132.520687] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 132.529309] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 132.536523] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 132.546201] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 132.554749] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 132.563270] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 132.570359] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 132.579976] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 1
[ 132.588492] tegradc 15220000.nvdisplay: dp: aux write retry (0x10000100) -- 0
[ 132.596996] tegradc 15220000.nvdisplay: dp: aux write got error (0x10000100)
[ 132.604102] tegradc 15220000.nvdisplay: dp: Failed to write DPCD data. CMD 0x600, Status 0x10000100
[ 132.613190] tegradc 15220000.nvdisplay: dp: failed to exit panel power save mode (0xfffffff2)
[ 132.621745] hpd: edid read prepare failed
[ 132.625618] tegradc 15220000.nvdisplay: blank - powerdown
[ 132.631250] hpd: hpd_switch 0
[ 132.634232] tegradc 15210000.nvdisplay: blank - powerdown
[ 132.634276] hpd: switching from state 2 (Check EDID) to state 3 (Disabled)
[ 132.646625] tegradc 15220000.nvdisplay: blank - powerdown
Since dp0 says eDP is there an additional setting that I should be looking for to properly enable regular displayport?
fdt.txt (371 KB)
