Release date for FPGA Holoscan Sensor Bridge IP version 2501 or later
I have a Jetson AGX Thor Developer Kit with JetPack 7.0 installed.
I got the following message…
hololink._hololink.UnsupportedVersion: hsb_ip_version=0X2412; minimum supported version=0X2501.
Checking the NGC Catalog, version 2412 is the latest public offering.
When will version 2501 or later be released?
In the interim, is it possible to rollback the Holoscan SDK version to something compatible with 2412?
Support for Thor configurations is provided in the HSB 2.5.0 release, which is available on github. In the device setup instructions, it shows how to use that tree to program your device with the FPGA firmware that’s released with that tree. Have a look at that and let us know if you have any further questions.
I should add that I am not using Holoscan Bridge COTS hardware like the ones mentioned in the GitHub repo linked above (Lattice/Microchip/Terasic). Instead, I am using a generic FPGA Dev Kit with my own custom logic wrapped around the Holoscan Sensor Bridge FPGA IP that I downloaded from the Nvidia NGC Catalog.
The issue is version 2412 is the latest available on the NGC Catalog and this is too old because the Thor Hololink SDK gives me an error message and calls for version 2501 or later.
Hi Joe,
We’ve moved all our IPs release to here Index of sw-holoscan-thirdparty-generic-local/hsb/fpga_ip
The public 2.5GA SDK is QA’ed with IP version 2510.
