Release Notes for Nvidia Base Command Manager 10.23.09
Release notes for Base Command Manager 10.23.09
NVIDIA Base Command™ Manager (BCM) 10.23.09 is the first public release for version 10, a new major version of NVIDIA cluster management software.
Starting with this version, Bright Cluster Manager is being merged into Base Command Manager.
Base Command Manager 10 is the next release of Bright Cluster Manager 9.2, now under the new name.
Unless expressly stated otherwise, Base Command Manager 10 includes all the functionality supported by Bright Cluster Manager 9.2.
This version marks the first release of BCM also used with NVIDIA AI Enterprise. From the same codebase as BCM, Base Command Manager Essentials (BCME) will be packaged with features certified for the NVIDIA AI Enterprise use case.
BCM 10 is licensed per GPU. This is different from the legacy Bright Cluster Manager product, which was licensed per node. Customers with active support subscriptions using Bright Cluster Manager 9.2 and earlier can upgrade to BCM 10 by exchanging their current licenses for GPU-based BCM 10 licenses at no cost. Contact sw-bright-sales-ops@NVIDIA.onmicrosoft.com for more information about licensing.
Information about Base Command Manager is available at NVIDIA Base Command Manager - NVIDIA Docs.
== General ==
== New Features ==
  • Support for Oracle Cloud Infrastructure for Cluster On Demand
  • Support for NVIDIA Spectrum switches provisioning (Cumulus OS 5) and management via cm-lite-daemon
  • Support for NVIDIA BlueField-2 and BlueField-3 Data Processing Units (DPUs) provisioning (BFB) and management
  • Support for NVIDIA AI Enterprise software versions
  • New DGX SuperPOD post install setup tool (cm-pod-setup)
  • New DGX SuperPOD network configuration setup tool (bcm-netautogen)
  • Switch to GPU-based licensing
  • Add cm-cron service
  • Add cm-list-image-conf-files.py script to list all special files in /cm/conf/
  • Add cuda12.2 packages
  • Add mlnx-ofed23.04 package
  • Add cuda-driver-legacy-470 package to support older datacenter/Tesla GPUs requiring NVIDIA CUDA driver version 470
== Improvements ==
  • Update cm-openssl package to 3.1.2
  • Update mlnx-ofed58 package to 5.8-3.0.7.0
  • Update mplnx-ofed54 package to 5.4-3.7.5.0
  • Update mlnx-ofed49 package to 4.9-7.1.0.0
  • Update mlnx-ofed59 DGX H100 package to 5.9.0.5.6.0.125
== CMDaemon ==
== New Features ==
  • Add cmsh device switchports command to get an overview of available switch ports
  • Send a warning event when a provisioning request has stalled longer than 2 hours. (Default value can be configured)
== Improvements ==
  • Switch to UUIDs to uniquely identify entities
  • Allow cm-mig-manage to support GPUs that do not have index = minorID
  • Turn on MIG on DGX H100 after node reboot when MIG.profiles are set in GPU settings
  • Increase DHCP maximal search domains to 32 by default
  • Add cmsh chassis set members as compact device list
  • Preserve files in /cm/images//cm/conf/{node,category}/ while updating images with rsync
  • Show an error message when cmsh createramdisk is run without arguments or an image set
  • Improved daily cron script to create monthly backup files for the openldap-servers to also include backups older than 1 year
  • Add a new ‘–all’ option to cmsh sysinfo command to show extra information that has been collected by CMDaemon
  • Prevent CMDaemon crash when missing or truncated files are present in the monitoring backup directory
  • Increase systemd-resolved.service reload timeout
  • Redirect all stdout/stderr from a cmburn test script to a log file
  • Show inherited kernel properties in cmsh device get
  • Add multiline support for cmsh rack display
  • Add free extra_values to all entities to store additional information
  • Remove field for the CPU frequency scaling governor
  • Add --certificate --key options in cmsh help
  • Add user/group name validation in cmsh
  • Do not populate status for each node in the environment to avoid multiple slow RPCs
== Fixed Issues ==
  • Fix killing jobs on a node when CMDaemon is restarted on that node
  • Fix RemoteMountChecker when a custom port is specified as the NFSCheckerPort AdvancedConfig parameter when querying cm-nfs-checker
  • Handle cm-lite-daemon restart properly
  • Fix help of cmsh cert removerequest command
  • Fix HPL test start in cmburn on SLES 15 base distribution
  • Automatically adjust overlay.category references when a category is removed
  • Do not clone switchports when cloning a device
  • Fix CMDaemon crash when malformed JSON data is sent
  • Update node environment cache when automatically changing FS exports
  • Honor backup role disabled=yes configuration
  • Detect xvd* disk in sysinfo
  • Prevent the addition of duplicate nameservers in /etc/resolv.conf
  • Delete duplicate entries in /etc/nginx/nginx.conf
  • Fix cmsh crash when cloning an entity without specifying a name in the genericresources submode
  • Hide all events in cmsh if --hide-events is used
  • Remove verbose logs in /tmp/aws* from cm-setup
  • Fix cmsh table formatting with long lines
  • Fix default gateway for edge nodes running Ubuntu
  • Fix duplicate nodes for monitoring pickup scheduler
  • Fix database storage of drained provisioning nodes
  • Ensure named gets reloaded when network changes made
  • Fix false negative open --failbeforedown when a status value is unchanged
  • Fix typo guage → gauge
== Node Installer ==
== Fixed Issues ==
  • Fix booting of compute nodes with separate /usr filesystem
  • Allowed cloning of headnodes with btrfs filesystems
  • Fix disk management script to correctly assemble MD raids
== cm-scale ==
== New Features ==
  • Support for Oracle Cloud Infrastructure for Auto Scaler
  • Automatically detect memory and GPUs for cloud nodes
== Improvements ==
  • Support multi-partition Slurm jobs in Auto Scaler
== Fixed Issues ==
  • Fix incorrect number of CPUs for Slurm jobs in Auto Scaler
  • Handle lack of availability zone capacity for AWS spot instances in Auto Scaler
  • Auto Scaler ignores queue priorities for multi-queue Slurm jobs
== Linux and Hardware Integration ==
== New Features ==
  • Support for DGX OS 6.1
  • Add cm-dpu-setup tool to define NVIDIA BlueField-2 and BlueField-3 Data Processing Units (DPUs) in the cluster
  • Add cm-dpu-manage to perform management actions on NVIDIA BlueField-2 and BlueField-3 Data Processing Units (DPUs)
== Cloud ==
== New Features ==
  • Add cm-cod-oci to create Cluster on Demand in Oracle Cloud Infrastructure
  • Allow COD-AWS cluster to span multiple regions (contact support for assistance)
  • Add support for AWS FSx on Ubuntu
== Fixed Issues ==
  • Fix various issues with Azure locations caused by Azure API errors
  • Improved support for AWS spot instances
== Kubernetes ==
== New Features ==
  • Change Kubernetes deployment to use kubeadm
  • Change Kubernetes deployment to use packages from kubernetes.io instead of cm-kubernetesXXX packages
  • Support for Cluster API (CAPI) as a deployment method for new Kubernetes clusters
== Improvements ==
  • Update Kyverno to 3.0.4 (due to incompatibility with Kubernetes 1.27.x)
  • Support for multiple NVIDIA GPU operator versions
  • Deploy the NVIDIA GPU Operator with toolkit.enabled=false by default
== Fixed Issues ==
  • NVIDIA GPU Operator deployment always results in NVIDIA packages being installed
  • Update exclude lists for Kubernetes to avoid failures on “grabimage”
  • Do not include kubelet.service file in exclude list (this can interfere with assigning additional nodes to the Kubernetes roles and prevent the kubelet service from starting correctly)
== Workload Management ==
== New Features ==
  • Support data and cache sharing options for pyxis and enroot
  • Allow management of Slurm prolog/epilog timeouts
== Improvements ==
  • Rely on MIG autodetection to configure gres.conf
  • Update Slurm package to 23.02 (older versions are not supported anymore)
  • Use pmix4 with Slurm 23.02
  • pyxis may now be compiled and installed from a local tarball with sources
  • All RPCs for job management API in CMDaemon also return an exit code of the operation
== Fixed Issues ==
  • Fix parsing of Slurm job CPUs
  • Fix fetching job information when UGE accounting rotation is configured
  • Fix UGE AdditionalSubmitHosts advanced configuration flag
  • Advanced accounting (job types and account hierarchy monitoring)
== Jupyter ==
== New Features ==
  • Manage Spark and PostgreSQL instances from JupyterLab
  • Manage Pods and data migration from/to Persistent Volume Claims
  • Read Pod logs and events from Jupyter interface
  • Support for multi-factor authentication
== Improvements ==
  • Support for private NGC credentials in Kubernetes kernel templates
== Container Engines ==
== Improvements ==
  • Update cm-docker package to 23.0.6
  • Update cm-containerd package to 1.7.1
  • Update cm-apptainer package to 1.1.9
== Container Registries ==
== Improvements ==
  • Update cm-harbor package to 2.8.2
  • Update cm-docker-registry package to 2.8.1
== Fixed Issues ==
  • Generate containerd certificates when a registry mirror is not configured
== Ceph ==
== Improvements ==
  • Updated Ceph to Ceph Quincy
== Monitoring ==
== New Features ==
  • Add new NVSwitch metrics
  • Support for Graphana 10
== Improvements ==
  • Disable job metrics collection when JobSampler is not setup to run in OOB mode
  • Sample node JobsRunning metric even when there are no jobs running
  • Reduce memory usage spike when using PromQL over short timespans
  • Multiply metric value by 100 when displaying % in pythoncm
  • Exclude rdma* by default in /proc/net/dev sampler
  • Exclude virtual ibpv interface from monitoring
== Fixed Issues ==
  • Fix the Slurm job_gpu_utilization and job_gpu_wasted metric calculations when running GPU process within sbatch scripts
  • Fix calculation of job_gpu_wasted metric when the node has multiple GPUs
  • Fix samplenow CPUUsage metric
  • Ensure job_gpu_* have correct values in the first few seconds of a job being started
  • Ensure first data sample of a Prometheus sampler is stored to the database
  • Propagate cumulative values passed by a JSON sampler during initialize
  • Fix metrics sampling when temperatures are not provided by the Redfish API
  • Clean up job monitoring when jobs are removed from cache
