Release notes for Bright 9.2-8
== General ==
=Improvements=
- Integration with Run:ai
=Fixed Issues=
- mlnx-ofed57: An issue where the mst service does not start when using mlnx-ofed57 due to the mst sysvinit service file being packaged as a systemd unit file
== CMDaemon ==
=New Features=
- Add a cm-package-release-info tool which can determine the Bright 9.X-Y version of installed packages
=Improvements=
- Introduce a new CPUUsage metric for compute and head nodes to show the percentage of the CPU usage
- Exclude the ram and loop devices from /sys/block/ from being sampled by the SysBlockStat monitoring data producer
- Allow for special OID for PDU load to be specified via the revision property
=Fixed Issues=
- Disable the cgroup job metrics collection for users (user IDs) that cannot be found on the nodes
- An issue where the monitoringdrop command may drop the data only for the head node
- An issue with creating the LSF configuration when some node is converted from a compute to a submit-only host
- An issue where cloud node that have never been booted may have a status “unknown error”
- Automatically start slurmdbd when Slurm configuration is frozen in cmd.conf
- An issue where the lite daemon may not reconnect when the websocket is closed cleanly on the server side
== Head Node Installer ==
=Fixed Issues=
- An issue with head node installations with Lmod where the DefaultModules.lua module file is not created by default, resulting in messages about empty LMOD_SYSTEM_DEFAULT_MODULES environment variable
== Machine Learning ==
=New Features=
- Introduced ML package cm-onnx-pytorch- * -cuda11.7- *
- Introduced ML package cm-gpytorch-*-cuda11.7- *
- Introduced ML package cm-fastai2- * -cuda11.7-*
- Introduced ML package cm-pytorch-extra- * -cuda11.7-*
- Introduced ML package cm-xgboost- * -cuda11.7-
- Introduced ML package cm-pytorch-cuda11.7
- Introduced ML package cm-cub-cuda11.7
- Introduced ML package cm-tensorflow2- * -cuda11.7-*
- Introduced ML package cm-opencv4- * -cuda11.7-*
- Introduced ML package cm-ml-pythondeps- * -cuda11.7-*
- Updated cm-gcc9-* packages to v9.5.0
- Updated cm-pytorch-* packages to v1.13.0
- Updated cm-tensorflow2-* packages to v2.10.0
- Updated cm-gpytorch-* packages to v1.9.0
- Updated cm-fastai2-* packages to v2.7.0
- Updated cm-xgboost-* packages to v1.6.2
- Deprecated ML packages for CUDA 11.2 and introduced new variants for CUDA 11.7
=Improvements=
- Deprecated cm-openmpi4-cuda11.2-ofed47-gcc9 and cm-openmpi4-cuda11.2-ofed51-gcc9 packages
== cm-wlm-setup ==
=New Features=
- Allow to use the “master” keyword in the cm-wlm-setup configuration as a placeholder for the real head node host name
