let me check
it doesnt work. I comment the line: “gst_element_set_state” and add line:" state_return=GST_STATE_CHANGE_SUCCESS;"
and run with an invalid rtsp
it still blocked in releasing pad:
It works in my device:
./deepstream-test3-app rtsp://12345
rtsp source:rtsp://12345
add sink
----- Now ---- playing: rtsp://12345,
+++++++generateBackendContext
TrtModelBuilder structor
WARNING: [TRT]: Current optimization profile is: 0. Please ensure there are no enqueued operations pending in this context prior to switching profiles
0:00:02.125782735 108 0x559bbd779780 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1704> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.125906876 108 0x559bbd779780 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger: NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1809> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/samples/models/Primary_Detector/resnet10.caffemodel_b1_gpu0_int8.engine
-------generateBackendContext
0:00:02.126979957 108 0x559bbd779780 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus: [UID 1]: Load new model:dstest3_pgie_config.txt sucessfully
Decodebin child added: source
Running…
ERROR from element source: Could not open resource for reading and writing.
Error details: gstrtspsrc.c(7469): gst_rtspsrc_retrieve_sdp (): /GstPipeline:dstest3-pipeline/GstBin:source-bin-00/GstURIDecodeBin:uri-decode-bin/GstRTSPSrc:source:
Failed to connect. (Generic error)
bus_call: start to delete:sink_0
bus_call: sourceBin:source-bin-00 STATE CHANGE FAILURE
—Returned, stopping playback
—Deleting pipeline
Can you upload your demo code? Let me compare with mine.
your change is wrong,because only comment the “gst_element_set_state” leads to the variant "state_return "still have the value : GST_STATE_CHANGE_FAILURE( its the default value for state_return beacause GST_STATE_CHANGE_FAILURE=0)
if check your log ,you can see the log:
so, the code about releasing pad is not runing(because it in the case GST_STATE_CHANGE_SUCCESS) during your program executing.
you need write this:
We will investigate the root cause and solution and feedback to you when there is any progress.
okey, waiting for your response. ;)
any update?
@Fiona.Chen It’s been 3 months and this issue is still unresolved, please give us some feedback of your progress so far!
although i turned to do works for trt model generating,but THIS issue is sitll blocking my project
I have the same issue. Any update??
any update for now?
any update?
The bug is fixed with DeepStream 6.0 GA.
