HI,
we are using the relion 5.0.0 container and relion fails when using the --blush option.
We checked and we could not find the required packages inside the container.
The error:
level=info msg="Setting CUDA_MODULE_LOADING=LAZY. Please see https://docs.nvidia.com for more information."
Something went wrong in the external Python call...
Command: relion_python_blush Class3D/job097/run_it001_class001_external_reconstruct.star --gpu ,
---------------------------------- PYTHON ERROR ---------------------------------
Has RELION been provided a Python interpreter with the correct environment?
The interpreter can be passed to RELION either during Cmake configuration by
using the Cmake flag -DPYTHON_EXE_PATH=<path/to/python/interpreter>.
NOTE: For some modules TORCH_HOME needs to be set to find pretrained models
Using python executable:
The command I ran:
singularity run --env PATH=/usr/local/relion/sm90/bin/:$PATH --nv $SIF_FILE /usr/local/openmpi/bin/mpirun -np 5 relion_refine_mpi --o Class3D/job097/run --i Select/job014/particles.s
tar --ref InitialModel/job015/initial_model.mrc --trust_ref_size --ini_high 50 --dont_combine_weights_via_disc --pool 30 --pad 1 --ctf --iter 25 --tau2_fudge 4 --particle_diameter 200
--K 4 --flatten_solvent --zero_mask --blush --oversampling 1 --healpix_order 2 --offset_range 5 --offset_step 2 --sym C1 --norm --scale --j 4 --gpu "" --pipeline_control Class3D/jo
b097/
Any Idea how to resolve this ?
