I tried to run Mobilenet V2 with TensorRT with uff file and it gave me below error RELU6 not supported. Seeing the documentation, TensorRT doesn’t support RELU6 as of now but the sampleUffSSD example shows Relu6 is replaced by Relu(x) - Relu(x-6).
adit@gibson2:~/Downloads/mobilenet_v2_1.4_224$ ~/Downloads/TensorRT-4.0.1.6/bin/trtexec --uff=mobilenet_v2_1.4_224_frozen.pb.uff --output=MobilenetV2/Predictions/Reshape_1 --uffInput=input,3,224,224
uff: mobilenet_v2_1.4_224_frozen.pb.uff
output: MobilenetV2/Predictions/Reshape_1
uffInput: input,3,224,224
UFFParser: Validator error: MobilenetV2/expanded_conv_1/expand/Relu6: Unsupported operation _Relu6
Engine could not be created
I created the config.py file similar to samplesUffSSD example as which pre-processes RElu6 operation but unfortunately it doesnt work.
- Created config.py
import graphsurgeon as gs
import tensorflow as tf
Input = gs.create_node(“input”,
op=“Placeholder”,
dtype=tf.float32,
shape=[1, 3, 224, 224])
namespace_plugin_map = {
“Preprocessor”: Input,
“ToFloat”: Input,
“input”: Input,
def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
#dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
- Generated uff file
convert-to-uff tensorflow --input-file mobilenet_v2_1.4_224_frozen.pb -O MobilenetV2/Predictions/Reshape_1 -p config.py
- Ran inference
Can anyone let me know how the UFFParser does the pre-processing on Relu6 ?
Thanks in advance
