Remote control orin nx does not work
Im trying to connect with remmina in a jetson orin nx from another pc in a different network .I install all the vnc steps in the readme file also the vcn setup is here: Setting Up VNC | NVIDIA Developer
But i still cant open screen share from my options,what is happening ?
This might be the main cause. Be aware that the link you’ve followed starts with this note:
Alternatively, you may try to use NoMachine. I have used it without any problem, only in LAN, but I think it is possible to use it over internet.
You may also try TeamViewer.
Thanks i wasnt aware of local host only … teamviwer work sweet :)
