Remote GPU Access
I have a doubt
a) I have access to GPUs on the cluster but do I need to install cuda toolkit on my local host system to run it from the local system?
If you use something like SSH to access the remote cluster, there is no particular requirement for any tools to be installed on your local system (other than an SSH client if needed).
If you want to compile, or compile and run codes on your local system, then you will need a local copy of the tools installed.
Hi, I want GPU access remotely of any system having GPU 3.0 or higher…I am Research student and i have no access to GPU in my university so anyone please give can give me access to system having GPU 3.0 or higher…
It quiet important…
