The YUV sensor with ISP camera will work after power on. The MCLK is controlled by ISP not TX1.
The code is modified from ov5693.c.
The camera module need 4 lane. then I remove the HW board E3326 and connect (pin to pin) my camera module with camera connecter J22.
I add my custom camera dts and remove the default dts(tegra210-platforms/tegra210-jetson-cv-camera-modules.dtsi)
gst-launch-1.0 -v v4l2src device=“/dev/video0” ! “video/x-raw,width=1280,height=720, format=(string)I420” ! nvvidconv ! “video/x-raw(memory:NVMM)” ! nvoverlaysink sync=false -e
Now the preview is not ok.
the error log is as followed:
[ 1072.718925] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:110000, lanes:300000
[ 1072.918684] video4linux video0: frame start syncpt timeout!0
[ 1072.938685] tegra_mipi_cal 700e3000.mipical: Mipi cal timeout,val:110000, lanes:300000
[ 1072.942074] nvmap_alloc_handle: PID 2330: gst-launch-1.0: WARNING: All NvMap Allocations must have a tag to identify the subsystem allocating memory.Plase pass the tag to the API call NvRmMemHanldeAllocAttr() or relevant.
[ 1073.159305] video4linux video0: frame start syncpt timeout!0
[ 1073.359280] video4linux video0: frame start syncpt timeout!0
Please help check the source code. Can you give some suggestions.
arch/arm64/boot/dts/tegra210-platforms/tegra210-imx224.dtsi
drivers/media/i2c/imx224.c
drivers/media/platform/tegra/camera/camera_common.c
V4L2_MBUS_FMT_UYVY8_2X8,
V4L2_COLORSPACE_SRGB,
V4L2_PIX_FMT_UYVY,
#include <dt-bindings/media/camera.h>
#include <dt-bindings/platform/t210/t210.h>
#define CAM0_RST_L TEGRA_GPIO(S, 4)
#define CAM0_PWDN TEGRA_GPIO(S, 7)
host1x {
vi {
num-channels = <1>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
vi_in0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&ov5693_out0>;
i2c@546c0000 {
status = "okay";
#size-cells = <0>;
ov5693_c@36 {
compatible = "nvidia,imx224";
/* I2C device address */
reg = <0x36>;
physical_w = "3.674";
physical_h = "2.738";
sensor_model ="imx224";
avdd-reg = "vana";
iovdd-reg = "vif";
clocks = <&tegra_car TEGRA210_CLK_ID_CLK_OUT_3>;
clock-names = "mclk";
clock-frequency = <24000000>;
mclk = "cam_mclk1";
reset-gpios = <&gpio CAM0_RST_L GPIO_ACTIVE_HIGH>;
pwdn-gpios = <&gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
vana-supply = <&en_vdd_cam_hv_2v8>;
vif-supply = <&en_vdd_cam>;
mode0 { // OV5693_MODE_2592X1944
mclk_khz = "24000";
num_lanes = "4";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
active_w = "1280";
active_h = "720";
pixel_t = "uyvy";
readout_orientation = "180";
line_length = "2688";
inherent_gain = "1";
mclk_multiplier = "17.0";
pix_clk_hz = "160000000";
min_gain_val = "1.0";
max_gain_val = "16";
min_hdr_ratio = "1";
max_hdr_ratio = "64";
min_framerate = "1.816577";
max_framerate = "30";
min_exp_time = "34";
max_exp_time = "550385";
embedded_metadata_height = "0";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
ov5693_out0: endpoint {
csi-port = <0>;
bus-width = <4>;
remote-endpoint = <&vi_in0>;
tegra-camera-platform {
compatible = "nvidia, tegra-camera-platform";
modules {
module0 {
badge = "e3326_front_P5V27C";
position = "rear";
orientation = "1";
drivernode0 {
pcl_id = "v4l2_sensor";
proc-device-tree = "/proc/device-tree/host1x/i2c@546c0000/ov5693_c@36";
drivernode1 {
pcl_id = "v4l2_focuser_stub";
#include <linux/slab.h>
#include <linux/uaccess.h>
#include <linux/gpio.h>
#include <linux/module.h>
#include <linux/seq_file.h>
#include <linux/of.h>
#include <linux/of_device.h>
#include <linux/of_gpio.h>
#include <media/camera_common.h>
#include <media//imx224.h>
#include “cam_dev/camera_gpio.h”
#include “imx224_mode_tbls.h”
#define IMX224_MAX_COARSE_DIFF 6
#define IMX224_GAIN_SHIFT 8
#define IMX224_REAL_GAIN_SHIFT 4
#define IMX224_MIN_GAIN (1 << IMX224_GAIN_SHIFT)
#define IMX224_MAX_GAIN (16 << IMX224_GAIN_SHIFT)
#define IMX224_MAX_UNREAL_GAIN (0x0F80)
#define IMX224_MIN_FRAME_LENGTH (0x0)
#define IMX224_MAX_FRAME_LENGTH (0x7fff)
#define IMX224_MIN_EXPOSURE_COARSE (0x0002)
#define IMX224_MAX_EXPOSURE_COARSE
(IMX224_MAX_FRAME_LENGTH-IMX224_MAX_COARSE_DIFF)
#define IMX224_DEFAULT_GAIN IMX224_MIN_GAIN
#define IMX224_DEFAULT_FRAME_LENGTH (0x07C0)
#define IMX224_DEFAULT_EXPOSURE_COARSE
(IMX224_DEFAULT_FRAME_LENGTH-IMX224_MAX_COARSE_DIFF)
#define IMX224_DEFAULT_MODE IMX224_MODE_2592X1944
#define IMX224_DEFAULT_HDR_MODE IMX224_MODE_2592X1944_HDR
#define IMX224_DEFAULT_WIDTH 1280
#define IMX224_DEFAULT_HEIGHT 720
//#define IMX224_DEFAULT_DATAFMT V4L2_MBUS_FMT_SRGGB10_1X10 //V4L2_MBUS_FMT_UYVY8_2X8
#define IMX224_DEFAULT_DATAFMT V4L2_MBUS_FMT_UYVY8_2X8
#define IMX224_DEFAULT_CLK_FREQ 24000000
#define DEBUG 1
struct imx224 {
struct camera_common_power_rail power;
int numctrls;
struct v4l2_ctrl_handler ctrl_handler;
struct i2c_client *i2c_client;
struct v4l2_subdev *subdev;
struct media_pad pad;
int reg_offset;
s32 group_hold_prev;
bool group_hold_en;
struct regmap *regmap;
struct camera_common_data *s_data;
struct camera_common_pdata *pdata;
struct v4l2_ctrl *ctrls[];
static struct regmap_config imx224_regmap_config = {
.reg_bits = 16,
.val_bits = 8,
static int imx224_s_ctrl(struct v4l2_ctrl *ctrl);
static void imx224_update_ctrl_range(struct imx224 *priv, s32 frame_length);
static const struct v4l2_ctrl_ops imx224_ctrl_ops = {
.s_ctrl = imx224_s_ctrl,
static struct v4l2_ctrl_config ctrl_config_list = {
/* Do not change the name field for the controls! */
.ops = &imx224_ctrl_ops,
.id = V4L2_CID_GAIN,
.name = “Gain”,
.type = V4L2_CTRL_TYPE_INTEGER,
.flags = V4L2_CTRL_FLAG_SLIDER,
.min = IMX224_MIN_GAIN,
.max = IMX224_MAX_GAIN,
.def = IMX224_DEFAULT_GAIN,
.step = 1,
.id = V4L2_CID_FRAME_LENGTH,
.name = “Frame Length”,
.min = IMX224_MIN_FRAME_LENGTH,
.max = IMX224_MAX_FRAME_LENGTH,
.def = IMX224_DEFAULT_FRAME_LENGTH,
.step = 1,
.id = V4L2_CID_COARSE_TIME,
.name = “Coarse Time”,
.min = IMX224_MIN_EXPOSURE_COARSE,
.max = IMX224_MAX_EXPOSURE_COARSE,
.def = IMX224_DEFAULT_EXPOSURE_COARSE,
.step = 1,
.id = V4L2_CID_COARSE_TIME_SHORT,
.name = “Coarse Time Short”,
.step = 1,
.id = V4L2_CID_GROUP_HOLD,
.name = “Group Hold”,
.type = V4L2_CTRL_TYPE_INTEGER_MENU,
.min = 0,
.max = ARRAY_SIZE(switch_ctrl_qmenu) - 1,
.menu_skip_mask = 0,
.def = 0,
.qmenu_int = switch_ctrl_qmenu,
.id = V4L2_CID_HDR_EN,
.name = “HDR enable”,
.min = 0,
.def = 0,
.id = V4L2_CID_FUSE_ID,
.name = “Fuse ID”,
.type = V4L2_CTRL_TYPE_STRING,
.flags = V4L2_CTRL_FLAG_READ_ONLY,
.min = 0,
.max = IMX224_FUSE_ID_STR_SIZE,
.step = 2,
static inline void imx224_get_frame_length_regs(imx224_reg *regs,
u32 frame_length)
printk(“imx224_get_frame_length_regs\n”);
static inline void imx224_get_coarse_time_regs(imx224_reg *regs,
u32 coarse_time)
printk(“imx224_get_coarse_time_regs\n”);
static inline void imx224_get_coarse_time_short_regs(imx224_reg *regs,
u32 coarse_time)
printk(“imx224_get_coarse_time_short_regs\n”);
static inline void imx224_get_gain_regs(imx224_reg *regs,
u16 gain)
printk(“imx224_get_gain_regs\n”);
static int test_mode;
module_param(test_mode, int, 0644);
static inline int imx224_read_reg(struct camera_common_data *s_data,
u16 addr, u8 *val)
struct imx224 *priv = (struct imx224 *)s_data->priv;
printk(“%s\n”,func);
return 0;
return regmap_read(priv->regmap, addr, (unsigned int *) val);
static int imx224_write_reg(struct camera_common_data *s_data, u16 addr, u8 val)
int err;
return 0;
err = regmap_write(priv->regmap, addr, val);
if (err)
pr_err("%s:i2c write failed, %x = %x\n",
__func__, addr, val);
return err;
static int imx224_write_table(struct imx224 *priv,
const imx224_reg table)
return 0;
return regmap_util_write_table_8(priv->regmap,
table,
NULL, 0,
IMX224_TABLE_WAIT_MS,
IMX224_TABLE_END);
static void imx224_gpio_set(struct imx224 *priv,
unsigned int gpio, int val)
if (priv->pdata->use_cam_gpio)
cam_gpio_ctrl(priv->i2c_client, gpio, val, 1);
else {
if (gpio_cansleep(gpio))
gpio_set_value_cansleep(gpio, val);
else
gpio_set_value(gpio, val);
static int imx224_power_on(struct camera_common_data *s_data)
int err = 0;
struct camera_common_power_rail *pw = &priv->power;
dev_dbg(&priv->i2c_client->dev, “%s: power on\n”, func);
if (priv->pdata && priv->pdata->power_on) {
err = priv->pdata->power_on(pw);
if (err)
pr_err("%s failed.\n", __func__);
else
pw->state = SWITCH_ON;
return err;
/* sleeps calls in the sequence below are for internal device
* signal propagation as specified by sensor vendor */
if (pw->avdd)
err = regulator_enable(pw->avdd);
if (err)
goto imx224_avdd_fail;
if (pw->iovdd)
err = regulator_enable(pw->iovdd);
if (err)
goto imx224_iovdd_fail;
usleep_range(1, 2);
if (pw->pwdn_gpio)
imx224_gpio_set(priv, pw->pwdn_gpio, 1);
/* datasheet 2.9: reset requires ~2ms settling time
* a power on reset is generated after core power becomes stable */
usleep_range(2000, 2010);
if (pw->reset_gpio)
imx224_gpio_set(priv, pw->reset_gpio, 1);
/* datasheet fig 2-9: t3 */
usleep_range(1350, 1360);
return 0;
imx224_iovdd_fail:
regulator_disable(pw->avdd);
imx224_avdd_fail:
pr_err(“%s failed.\n”, func);
return -ENODEV;
static int imx224_power_off(struct camera_common_data *s_data)
int err = 0;
dev_dbg(&priv->i2c_client->dev, "%s: power off\n", __func__);
printk("%s\n",__func__);
err = priv->pdata->power_off(pw);
if (!err)
pw->state = SWITCH_OFF;
else
return err;
usleep_range(21, 25);
if (pw->pwdn_gpio)
imx224_gpio_set(priv, pw->pwdn_gpio, 0);
usleep_range(1, 2);
if (pw->reset_gpio)
imx224_gpio_set(priv, pw->reset_gpio, 0);
/* datasheet 2.9: reset requires ~2ms settling time*/
if (pw->iovdd)
regulator_disable(pw->iovdd);
if (pw->avdd)
return 0;
static int imx224_power_put(struct imx224 *priv)
if (unlikely(!pw))
return -EFAULT;
if (likely(pw->avdd))
regulator_put(pw->avdd);
if (likely(pw->iovdd))
regulator_put(pw->iovdd);
pw->avdd = NULL;
pw->iovdd = NULL;
cam_gpio_deregister(priv->i2c_client, pw->pwdn_gpio);
else {
gpio_free(pw->pwdn_gpio);
gpio_free(pw->reset_gpio);
return 0;
static int imx224_power_get(struct imx224 *priv)
struct camera_common_pdata *pdata = priv->pdata;
const char *mclk_name;
const char *parentclk_name;
struct clk *parent;
int err = 0;
mclk_name = priv->pdata->mclk_name ?
priv->pdata->mclk_name : "cam_mclk1";
pw->mclk = devm_clk_get(&priv->i2c_client->dev, mclk_name);
if (IS_ERR(pw->mclk)) {
dev_err(&priv->i2c_client->dev,
"unable to get clock %s\n", mclk_name);
return PTR_ERR(pw->mclk);
parentclk_name = priv->pdata->parentclk_name;
if (parentclk_name) {
parent = devm_clk_get(&priv->i2c_client->dev, parentclk_name);
if (IS_ERR(parent))
"unable to get parent clcok %s",
parentclk_name);
else
clk_set_parent(pw->mclk, parent);
/* analog 2.8v */
err |= camera_common_regulator_get(priv->i2c_client,
&pw->avdd, pdata->regulators.avdd);
/* IO 1.8v */
&pw->iovdd, pdata->regulators.iovdd);
if (!err) {
pw->reset_gpio = pdata->reset_gpio;
pw->pwdn_gpio = pdata->pwdn_gpio;
if (priv->pdata->use_cam_gpio) {
err = cam_gpio_register(priv->i2c_client, pw->pwdn_gpio);
if (err)
"%s ERR can't register cam gpio %u!\n",
__func__, pw->pwdn_gpio);
} else {
gpio_request(pw->pwdn_gpio, "cam_pwdn_gpio");
gpio_request(pw->reset_gpio, "cam_reset_gpio");
return err;
static int imx224_set_gain(struct imx224 *priv, s32 val);
static int imx224_set_frame_length(struct imx224 *priv, s32 val);
static int imx224_set_coarse_time(struct imx224 *priv, s32 val);
static int imx224_set_coarse_time_short(struct imx224 *priv, s32 val);
static int imx224_s_stream(struct v4l2_subdev *sd, int enable)
struct i2c_client *client = v4l2_get_subdevdata(sd);
struct camera_common_data *s_data = to_camera_common_data(client);
struct v4l2_control control;
int err;
dev_dbg(&client->dev, "%s++\n", __func__);
if (!enable) {
imx224_update_ctrl_range(priv, IMX224_MAX_FRAME_LENGTH);
return imx224_write_table(priv,
mode_table[IMX224_MODE_STOP_STREAM]);
err = imx224_write_table(priv, mode_table[s_data->mode]);
if (err)
goto exit;
/* write list of override regs for the asking frame length,
* coarse integration time, and gain. Failures to write
* overrides are non-fatal */
control.id = V4L2_CID_GAIN;
err = v4l2_g_ctrl(&priv->ctrl_handler, &control);
err |= imx224_set_gain(priv, control.value);
if (err)
dev_dbg(&client->dev, "%s: warning gain override failed\n",
__func__);
control.id = V4L2_CID_FRAME_LENGTH;
err |= imx224_set_frame_length(priv, control.value);
if (err)
"%s: warning frame length override failed\n",
__func__);
control.id = V4L2_CID_COARSE_TIME;
err |= imx224_set_coarse_time(priv, control.value);
if (err)
"%s: warning coarse time override failed\n",
__func__);
control.id = V4L2_CID_COARSE_TIME_SHORT;
err |= imx224_set_coarse_time_short(priv, control.value);
if (err)
"%s: warning coarse time short override failed\n",
__func__);
err = imx224_write_table(priv, mode_table[IMX224_MODE_START_STREAM]);
if (err)
goto exit;
if (test_mode)
mode_table[IMX224_MODE_TEST_PATTERN]);
dev_dbg(&client->dev, "%s--\n", __func__);
return 0;
exit:
dev_dbg(&client->dev, “%s: error setting stream\n”, func);
return err;
static int imx224_g_input_status(struct v4l2_subdev *sd, u32 *status)
*status = pw->state == SWITCH_ON;
return 0;
static struct v4l2_subdev_video_ops imx224_subdev_video_ops = {
.s_stream = imx224_s_stream,
.s_mbus_fmt = camera_common_s_fmt,
.g_mbus_fmt = camera_common_g_fmt,
.try_mbus_fmt = camera_common_try_fmt,
.enum_mbus_fmt = camera_common_enum_fmt,
.g_mbus_config = camera_common_g_mbus_config,
.g_input_status = imx224_g_input_status,
.enum_framesizes = camera_common_enum_framesizes,
.enum_frameintervals = camera_common_enum_frameintervals,
static struct v4l2_subdev_core_ops imx224_subdev_core_ops = {
.s_power = camera_common_s_power,
static int imx224_get_fmt(struct v4l2_subdev *sd,
struct v4l2_subdev_fh *fh,
struct v4l2_subdev_format *format)
return camera_common_g_fmt(sd, &format->format);
static int imx224_set_fmt(struct v4l2_subdev *sd,
int ret;
if (format->which == V4L2_SUBDEV_FORMAT_TRY)
ret = camera_common_try_fmt(sd, &format->format);
else
ret = camera_common_s_fmt(sd, &format->format);
return ret;
static struct v4l2_subdev_pad_ops imx224_subdev_pad_ops = {
.enum_mbus_code = camera_common_enum_mbus_code,
.set_fmt = imx224_set_fmt,
.get_fmt = imx224_get_fmt,
static struct v4l2_subdev_ops imx224_subdev_ops = {
.core = &imx224_subdev_core_ops,
.video = &imx224_subdev_video_ops,
.pad = &imx224_subdev_pad_ops,
static struct of_device_id imx224_of_match = {
{ .compatible = “nvidia,imx224”, },
static struct camera_common_sensor_ops imx224_common_ops = {
.power_on = imx224_power_on,
.power_off = imx224_power_off,
.write_reg = imx224_write_reg,
.read_reg = imx224_read_reg,
static int imx224_set_group_hold(struct imx224 *priv)
int err;
int gh_prev = switch_ctrl_qmenu[priv->group_hold_prev];
if (priv->group_hold_en == true && gh_prev == SWITCH_OFF) {
/* enter group hold */
err = imx224_write_reg(priv->s_data,
IMX224_GROUP_HOLD_ADDR, 0x01);
if (err)
goto fail;
priv->group_hold_prev = 1;
"%s: enter group hold\n", __func__);
} else if (priv->group_hold_en == false && gh_prev == SWITCH_ON) {
/* leave group hold */
IMX224_GROUP_HOLD_ADDR, 0x11);
if (err)
goto fail;
IMX224_GROUP_HOLD_ADDR, 0x61);
if (err)
goto fail;
priv->group_hold_prev = 0;
"%s: leave group hold\n", __func__);
return 0;
fail:
“%s: Group hold control error\n”, func);
return err;
static u16 imx224_to_real_gain(u32 rep, int shift)
u16 gain;
int gain_int;
int gain_dec;
int min_int = (1 << shift);
if (rep < IMX224_MIN_GAIN)
rep = IMX224_MIN_GAIN;
else if (rep > IMX224_MAX_GAIN)
rep = IMX224_MAX_GAIN;
gain_int = (int)(rep >> shift);
gain_dec = (int)(rep & ~(0xffff << shift));
/* derived from formulat gain = (x * 16 + 0.5) */
gain = ((gain_int * min_int + gain_dec) * 32 + min_int) / (2 * min_int);
return gain;
imx224_reg reg_list[2];
int err;
u16 gain;
int i;
if (!priv->group_hold_prev)
imx224_set_group_hold(priv);
/* translate value */
gain = imx224_to_real_gain((u32)val, IMX224_GAIN_SHIFT);
imx224_get_gain_regs(reg_list, gain);
"%s: gain %04x val: %04x\n", __func__, val, gain);
for (i = 0; i < 2; i++) {
err = imx224_write_reg(priv->s_data, reg_list[i].addr,
reg_list[i].val);
if (err)
goto fail;
return 0;
fail:
“%s: GAIN control error\n”, func);
return err;
struct v4l2_ctrl *ctrl = NULL;
int ctrl_ids[2] = {V4L2_CID_COARSE_TIME,
V4L2_CID_COARSE_TIME_SHORT};
s32 max, min, def;
int i, j;
for (i = 0; i < ARRAY_SIZE(ctrl_ids); i++) {
for (j = 0; j < priv->numctrls; j++) {
if (priv->ctrls[j]->id == ctrl_ids[i]) {
ctrl = priv->ctrls[j];
break;
if (j == priv->numctrls) {
"could not find ctrl %x\n",
ctrl_ids[i]);
continue;
max = frame_length - IMX224_MAX_COARSE_DIFF;
/* clamp the value in case above is negative */
max = clamp_val(max, IMX224_MIN_EXPOSURE_COARSE,
IMX224_MAX_EXPOSURE_COARSE);
min = IMX224_MIN_EXPOSURE_COARSE;
def = clamp_val(IMX224_DEFAULT_EXPOSURE_COARSE, min, max);
if (__v4l2_ctrl_modify_range(ctrl, min, max, 1, def))
"ctrl %x: range update failed\n",
ctrl_ids[i]);
int err;
u32 frame_length;
int i;
frame_length = (u32)val;
imx224_get_frame_length_regs(reg_list, frame_length);
"%s: val: %d\n", __func__, frame_length);
reg_list[i].val);
if (err)
goto fail;
imx224_update_ctrl_range(priv, val);
return 0;
fail:
“%s: FRAME_LENGTH control error\n”, func);
return err;
imx224_reg reg_list[3];
int err;
u32 coarse_time;
int i;
coarse_time = (u32)val;
imx224_get_coarse_time_regs(reg_list, coarse_time);
"%s: val: %d\n", __func__, coarse_time);
for (i = 0; i < 3; i++) {
reg_list[i].val);
if (err)
goto fail;
return 0;
fail:
“%s: COARSE_TIME control error\n”, func);
return err;
int err;
struct v4l2_control hdr_control;
int hdr_en;
u32 coarse_time_short;
int i;
/* check hdr enable ctrl */
hdr_control.id = V4L2_CID_HDR_EN;
err = camera_common_g_ctrl(priv->s_data, &hdr_control);
if (err < 0) {
"could not find device ctrl.\n");
return err;
hdr_en = switch_ctrl_qmenu[hdr_control.value];
if (hdr_en == SWITCH_OFF)
return 0;
coarse_time_short = (u32)val;
imx224_get_coarse_time_short_regs(reg_list, coarse_time_short);
"%s: val: %d\n", __func__, coarse_time_short);
reg_list[i].val);
if (err)
goto fail;
return 0;
fail:
“%s: COARSE_TIME_SHORT control error\n”, func);
return err;
container_of(ctrl->handler, struct imx224, ctrl_handler);
int err = 0;
if (priv->power.state == SWITCH_OFF)
return 0;
switch (ctrl->id) {
case V4L2_CID_GAIN:
err = imx224_set_gain(priv, ctrl->val);
break;
case V4L2_CID_FRAME_LENGTH:
err = imx224_set_frame_length(priv, ctrl->val);
break;
case V4L2_CID_COARSE_TIME:
err = imx224_set_coarse_time(priv, ctrl->val);
break;
case V4L2_CID_COARSE_TIME_SHORT:
err = imx224_set_coarse_time_short(priv, ctrl->val);
break;
case V4L2_CID_GROUP_HOLD:
if (switch_ctrl_qmenu[ctrl->val] == SWITCH_ON) {
priv->group_hold_en = true;
} else {
priv->group_hold_en = false;
err = imx224_set_group_hold(priv);
break;
case V4L2_CID_HDR_EN:
break;
default:
pr_err("%s: unknown ctrl id.\n", __func__);
return -EINVAL;
return err;
static int imx224_ctrls_init(struct imx224 *priv, bool eeprom_ctrl)
struct i2c_client *client = priv->i2c_client;
struct camera_common_data *common_data = priv->s_data;
struct v4l2_ctrl *ctrl;
int numctrls;
int err;
int i;
numctrls = ARRAY_SIZE(ctrl_config_list);
v4l2_ctrl_handler_init(&priv->ctrl_handler, numctrls);
for (i = 0; i < numctrls; i++) {
ctrl = v4l2_ctrl_new_custom(&priv->ctrl_handler,
&ctrl_config_list[i], NULL);
if (ctrl == NULL) {
dev_err(&client->dev, "Failed to init %s ctrl\n",
ctrl_config_list[i].name);
continue;
if (ctrl_config_list[i].type == V4L2_CTRL_TYPE_STRING &&
ctrl_config_list[i].flags & V4L2_CTRL_FLAG_READ_ONLY) {
ctrl->string = devm_kzalloc(&client->dev,
ctrl_config_list[i].max + 1, GFP_KERNEL);
if (!ctrl->string)
return -ENOMEM;
priv->ctrls[i] = ctrl;
priv->numctrls = numctrls;
priv->subdev->ctrl_handler = &priv->ctrl_handler;
if (priv->ctrl_handler.error) {
dev_err(&client->dev, "Error %d adding controls\n",
priv->ctrl_handler.error);
err = priv->ctrl_handler.error;
goto error;
err = v4l2_ctrl_handler_setup(&priv->ctrl_handler);
if (err) {
"Error %d setting default controls\n", err);
goto error;
return 0;
error:
v4l2_ctrl_handler_free(&priv->ctrl_handler);
return err;
MODULE_DEVICE_TABLE(of, imx224_of_match);
static struct camera_common_pdata *imx224_parse_dt(struct i2c_client *client)
struct device_node *node = client->dev.of_node;
struct camera_common_pdata *board_priv_pdata;
const struct of_device_id *match;
int gpio;
int err;
if (!node)
return NULL;
match = of_match_device(imx224_of_match, &client->dev);
if (!match) {
dev_err(&client->dev, "Failed to find matching dt id\n");
return NULL;
board_priv_pdata = devm_kzalloc(&client->dev,
sizeof(*board_priv_pdata), GFP_KERNEL);
if (!board_priv_pdata)
return NULL;
err = camera_common_parse_clocks(client, board_priv_pdata);
if (err) {
dev_err(&client->dev, "Failed to find clocks\n");
goto error;
gpio = of_get_named_gpio(node, "pwdn-gpios", 0);
if (gpio < 0) {
dev_err(&client->dev, "pwdn gpios not in DT\n");
goto error;
board_priv_pdata->pwdn_gpio = (unsigned int)gpio;
gpio = of_get_named_gpio(node, "reset-gpios", 0);
if (gpio < 0) {
/* reset-gpio is not absoluctly needed */
dev_dbg(&client->dev, "reset gpios not in DT\n");
gpio = 0;
board_priv_pdata->reset_gpio = (unsigned int)gpio;
board_priv_pdata->use_cam_gpio =
of_property_read_bool(node, "cam,use-cam-gpio");
err = of_property_read_string(node, "avdd-reg",
&board_priv_pdata->regulators.avdd);
if (err) {
dev_err(&client->dev, "avdd-reg not in DT\n");
goto error;
err = of_property_read_string(node, "iovdd-reg",
&board_priv_pdata->regulators.iovdd);
if (err) {
dev_err(&client->dev, "iovdd-reg not in DT\n");
goto error;
return board_priv_pdata;
error:
devm_kfree(&client->dev, board_priv_pdata);
return NULL;
static int imx224_open(struct v4l2_subdev *sd, struct v4l2_subdev_fh *fh)
pr_info("[andy IMX224]: open v4l2 sensor.\n");
dev_dbg(&client->dev, "%s:\n", __func__);
return 0;
static const struct v4l2_subdev_internal_ops imx224_subdev_internal_ops = {
.open = imx224_open,
static const struct media_entity_operations imx224_media_ops = {
.link_validate = v4l2_subdev_link_validate,
static int imx224_probe(struct i2c_client *client,
const struct i2c_device_id *id)
struct camera_common_data *common_data;
struct imx224 *priv;
char debugfs_name[10];
int err;
pr_info("[andy IMX224]: probing v4l2 sensor.\n");
if (!IS_ENABLED(CONFIG_OF) || !node)
return -EINVAL;
common_data = devm_kzalloc(&client->dev,
sizeof(struct camera_common_data), GFP_KERNEL);
if (!common_data)
return -ENOMEM;
priv = devm_kzalloc(&client->dev,
sizeof(struct imx224) + sizeof(struct v4l2_ctrl *) *
ARRAY_SIZE(ctrl_config_list),
GFP_KERNEL);
if (!priv)
return -ENOMEM;
priv->regmap = devm_regmap_init_i2c(client, &imx224_regmap_config);
if (IS_ERR(priv->regmap)) {
"regmap init failed: %ld\n", PTR_ERR(priv->regmap));
return -ENODEV;
priv->pdata = imx224_parse_dt(client);
if (!priv->pdata) {
dev_err(&client->dev, "unable to get platform data\n");
return -EFAULT;
common_data->ops = &imx224_common_ops;
common_data->ctrl_handler = &priv->ctrl_handler;
common_data->i2c_client = client;
common_data->frmfmt = imx224_frmfmt;
common_data->colorfmt = camera_common_find_datafmt(
IMX224_DEFAULT_DATAFMT);
common_data->power = &priv->power;
common_data->ctrls = priv->ctrls;
common_data->priv = (void *)priv;
common_data->numctrls = ARRAY_SIZE(ctrl_config_list);
common_data->numfmts = ARRAY_SIZE(imx224_frmfmt);
common_data->def_mode = IMX224_DEFAULT_MODE;
common_data->def_width = IMX224_DEFAULT_WIDTH;
common_data->def_height = IMX224_DEFAULT_HEIGHT;
common_data->fmt_width = common_data->def_width;
common_data->fmt_height = common_data->def_height;
common_data->def_clk_freq = IMX224_DEFAULT_CLK_FREQ;
priv->i2c_client = client;
priv->s_data = common_data;
priv->subdev = &common_data->subdev;
priv->subdev->dev = &client->dev;
priv->s_data->dev = &client->dev;
err = imx224_power_get(priv);
if (err)
return err;
pr_info("[andy IMX224]: probing v4l2 sensor 1.\n");
err = camera_common_parse_ports(client, common_data);
if (err) {
dev_err(&client->dev, "Failed to find port info\n");
return err;
sprintf(debugfs_name, "imx224_%c", common_data->csi_port + 'a');
dev_err(&client->dev, "%s: name %s\n", __func__, debugfs_name);
camera_common_create_debugfs(common_data, debugfs_name);
v4l2_i2c_subdev_init(priv->subdev, client, &imx224_subdev_ops);
err = imx224_ctrls_init(priv, !err);
if (err)
return err;
pr_info("[andy IMX224]: probing v4l2 sensor 2.\n");
priv->subdev->internal_ops = &imx224_subdev_internal_ops;
priv->subdev->flags |= V4L2_SUBDEV_FL_HAS_DEVNODE |
V4L2_SUBDEV_FL_HAS_EVENTS;
#if defined(CONFIG_MEDIA_CONTROLLER)
priv->pad.flags = MEDIA_PAD_FL_SOURCE;
priv->subdev->entity.type = MEDIA_ENT_T_V4L2_SUBDEV_SENSOR;
priv->subdev->entity.ops = &imx224_media_ops;
err = media_entity_init(&priv->subdev->entity, 1, &priv->pad, 0);
if (err < 0) {
dev_err(&client->dev, “unable to init media entity\n”);
return err;
#endif
err = v4l2_async_register_subdev(priv->subdev);
if (err)
return err;
printk("Detected IMX224 sensor\n");
dev_dbg(&client->dev, "Detected IMX224 sensor\n");
return 0;
static int
imx224_remove(struct i2c_client *client)
v4l2_async_unregister_subdev(priv->subdev);
media_entity_cleanup(&priv->subdev->entity);
#endif
imx224_power_put(priv);
camera_common_remove_debugfs(s_data);
return 0;
static const struct i2c_device_id imx224_id = {
{ “imx224”, 0 },
MODULE_DEVICE_TABLE(i2c, imx224_id);
static struct i2c_driver imx224_i2c_driver = {
.driver = {
.name = “imx224”,
.owner = THIS_MODULE,
.of_match_table = of_match_ptr(imx224_of_match),
.probe = imx224_probe,
.remove = imx224_remove,
.id_table = imx224_id,
module_i2c_driver(imx224_i2c_driver);
MODULE_DESCRIPTION(“SoC Camera driver for Sony IMX224”);
MODULE_AUTHOR(“David Wang davidw@nvidia.com”);
MODULE_LICENSE(“GPL v2”);
