Remove nvgpu module on Jetson Nano
Is there a way I can remove the nvgpu module in Jetson Nano?
Tried: “rmmod -f nvgpu” but got below issue:
rmmod: ERROR: …/libkmod/libkmod-module.c:793 kmod_module_remove_module() could not remove ‘nvgpu’: Resource temporarily unavailable
rmmod: ERROR: could not remove module nvgpu: Resource temporarily unavailable
What other modules or services do nvgpu depend on?
Why do you want to remove the nvgpu module?
It could cause boot failed if remove nvgpu module.
If you just want to boot to text mode you can reference to below link.
https://devtalk.nvidia.com/default/topic/1050739/jetson-nano/how-to-boot-jetson-nano-in-text-mode-/post/5332698/#5332698
I am trying to load another kernel module that conflicts with nvgpu.
Is there a way to remove this module? I will try at my own risk.
You could probably blacklist the module :D
But not only will this mean you can only use text mode, it will disable other peripherals like CSI-2 cameras too…
What module conflicts? It would help to know what you’re trying to accomplish. There might be another way.
