I have installed and used the OS in the internal storage until now.
I want to install and use an OS on sdcard, and I wonder how I can erase the OS of the internal storage.
So you’re using the custom carrir board with eMMC Xavier module, right?
Which JetPack version you’re using?
yes. I’m using avermedia NX215 board.
I’m using jetpack 4.6
Hi jej1591,
You could refer to the following instruction to flash into SD Card.
Flashing and Booting the Target Device - Flashing to an SD Card | NVIDIA Docs
