I’m trying to recompile cboot_t194.bin so that the cboot delay is removed.
I’m using Jetpack 4.5.1, and downloaded source files from “https://developer.nvidia.com/l4t-jetson-xavier-c-boot-sources”
There is a readme file that specifies: “2. Export the cross compiler tools with the following enviroment variables:
export CROSS_COMPILE=<your_64-bit_ARM_toolchain_triple>”
Thus I set the variable as such:
export CROSS_COMPILE=/home/alexis/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-
However when compiling with:
make -C ./bootloader/partner/t18x/cboot PROJECT=t194 TOOLCHAIN_PREFIX="${CROSS_COMPILE}" DEBUG=2 BUILDROOT="${PWD}"/out NV_TARGET_BOARD=t194ref NV_BUILD_SYSTEM_TYPE=l4t NOECHO=@
I get the following errors:
/bin/bash: c/home/alexis/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-size: No such file or directory
make/build.mk:18: recipe for target '/home/alexis/Downloads/cboot/out/build-t194/lk.elf' failed
make[1]: *** [/home/alexis/Downloads/cboot/out/build-t194/lk.elf] Error 127
make[1]: Leaving directory '/home/alexis/Downloads/cboot/bootloader/partner/t18x/cboot'
makefile:13: recipe for target '_top' failed
make: *** [_top] Error 2
make: Leaving directory '/home/alexis/Downloads/cboot/bootloader/partner/t18x/cboot'
Could you help me understand where the errors come from?
