Removing dsa key generation on ota_make_recovery_img_dtb.sh
I know Ubuntu 25.10 is not officially supported, but when I run flash.sh it fails with:
72730 blocks gzip: /home/aartavia/nvidia/jp612/Linux_for_Tegra/kernel/Image: not in gzip format _BASE_KERNEL_VERSION=5.15.148-tegra
command is failed
No previous errors, just ‘command is failed’. I traced it down to tools/ota_tools/version_upgrade/ota_make_recovery_img_dtb.sh, to the prepare_sshd_files method, specifically the dsa key generation. As it seems openssl now doesn’t supports it.
# generate keys
rm -f "${_initrd_dir}/${ssh_config_dir}/"ssh_host_*_key
rm -f "${_initrd_dir}/${ssh_config_dir}/"ssh_host_*_key.pub
ssh-keygen -t dsa -N "" -f "${_initrd_dir}/${ssh_config_dir}/ssh_host_dsa_key" >/dev/null 2>&1;check_error #This is what causes error
ssh-keygen -t rsa -N "" -f "${_initrd_dir}/${ssh_config_dir}/ssh_host_rsa_key" >/dev/null 2>&1;check_error
ssh-keygen -t ecdsa -N "" -f "${_initrd_dir}/${ssh_config_dir}/ssh_host_ecdsa_key" >/dev/null 2>&1;check_error
ssh-keygen -t ed25519 -N "" -f "${_initrd_dir}/${ssh_config_dir}/ssh_host_ed25519_key" >/dev/null 2>&1;check_error
If I remove it it works and flashes ok, but I was wondering if down the line it might cause something to break of its ok to have it removed?
Regards,
Andres
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com/
Website: www.ridgerun.com
hello andres.artavia,
it’s just one of the legacy host key types that sshd knows how to load.
it should be okay to comment out that.
Got it, thanks you for the confimation.
Regards
