Hi Guys,
I have a few questions I was hoping you could help me with.
From my dmesg output I would like to resolve some bugs and remove undesired/not required functionality in the DTS.
First of all my hardware has the HDMI CEC pin floating and hence I would like to disable that to rid the following garbage in dmesg
[ 1.030962] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=390
[ 1.031704] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[ 1.032758] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[ 1.032786] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[ 1.033535] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[ 1.033542] tegra_cec 3960000.tegra_cec: probed
Q1: Is it enough/okay to simply set the tegra_cec status to “disable” ?
Q2a: My Custom board does not use the FAN PWM and FAN TACH pins on the Tegra TX1 but rather I have a dedicated FAN controller IC which Im controlling manually over I2C based on the temperature in my enclosure - Is there a way to disble/remove the Tegra FAN driver?
Q2b: If I disable the above will there still be hardware based thermal throttling in case the internal temperature sensors of the TX1 detects over temperature?
[ 1.638661] FAN dev name: pwm-fan
[ 1.638715] FAN:gpio request success.
[ 1.638723] FAN: can’t find tach_gpio
[ 1.638745] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 1.638979] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
[ 1.638984] pwm_fan_driver pwm-fan: tach period: 1000
[ 1.639752] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.639756] Extcon AUX1(HDMI) enable
[ 1.640057] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 1.640063] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 1.640068] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 1.640072] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 1.640076] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 1.640080] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 1.640084] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 1.640088] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 1.640093] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 1.640098] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
Q3: my hardware does not use the Ethernet MAC (only WiFi/BT) **
** - how can I disable it so that the system is not wasting time loading it?
Q4: My hardware has no SATA or PCIe ports (PEX0, PEX1, PEX2 pins are all floating except RX pins which are grounded), I am using the USB0 flashing port, one USB3 port and the USB2 port. How can I disable the PCIe and SATA?
Lasse
