Hello Sight Documentation says that " The sight::show function can render an image directly (Image1ub, Image3ub, and Image4ub "
Can we render Image1f or Image4f inside the Sight ? Also i am curious as you guys have included coarseto fine depth as a Library , how were you able to render the Image inside Sight ?
I am trying to directly render a depth Image inside Sight , if there is a way Image1f can be rendered , it will be possible.
I intend to use the following Code :-
void HeroCamera::publishDepthData(int64_t acq_time) {
Image1f buffer_left_depth(Hero_resolution_.height, Hero_resolution_.width);
Copy(DepthHeroImageView(left_image_depth_), buffer_left_depth);
show(“left_depth_thumbnail”,
[&](sight::Sop& sop) { sop.add(Reduce(buffer_left_depth)); });
ToProto(std::move(buffer_left_depth), tx_left_camera_depth().initProto(),
tx_left_camera_depth().buffers());
OR can we use TOPROTO/FROM PROTO to show it in sight.
