If I do a movie capture it seems to be cutting off the frame - it gets worse as I increase the resolution scale.
normal resolution, regular cam
5x resolution same cam
Has anyone seen this before?
I can see it when I click capture frame it makes the viewport smaller and shows grey then renders that part out black- the grey is just black - its very strange.
I figured out the bug (at least I think it’s a bug) - when you enter “RESHADE” in Machinima it does it.
make sure render resolution = movie capture resolution and do not have fill viewport checked
Hi @garretthoyos! I created a ticket for the dev team to fix.
Internal Reference OM-38277
@garretthoyos Basically this happens because at the moment Reshade doesn’t pick up resolution changes that happened after the preset was applied.
As a temp workaround, you could just check, as you correctly pointed out, that (render resolution = movie capture resolution) and then turn Reshade off and on again. (Or disable Reshade, and then enable some particular preset from the Menu).
