Hi
Is there a way to render frames in slow motion? Understand this can be achieved using post editing tool, just want to know if this can be done in OV, thanks.
60 frames in max.
I also hope this would come some day…
For now, our only option is to use topazlabs and such…
Hi @qazs & @pekka.varis! I created an internal feature request ticket for the development team to add this feature. OM-52731: Slow Motion Render
Nice, Wendy.
I have seen in some nvidia tutorial videos even 120 frm in seq frm rate pop-up…
Yes sort of - you can scale the animation in sequencer by dragging the purple node on the track or by adjusting the playrate property when the sequence is selected.
Sure that is a good tip - but for dyn simulation and fire we are now only able to do 25, 30 and 60 frm/sec in Machinima but latest Create supports already 120 frm/sec!
But in Create movie capture the max is only 60 frm.
I bet that will be updated to 120 and then also this is bought to Machinima too?
Most likely. The Machinima build should support this eventually but I’m not sure of the time frame.
Thanks, I think this is better achieved using a post process tool. Rendering takes up too much time…
