We tried to use 4-port USB 3.0 PCIe card from Renkforce on the Xavier. The PCIe card was not recognized…
Please share the kernel log. Thanks.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Linux version 4.9.108-rt76-rt76-rt76+ (root@jetson-0423618000794) (gcc version 7.3.0 (Ubuntu/Linaro 7.3.0-27ubuntu1~18.04) ) #1 SMP PREEMPT RT Thu Mar 21 10:24:58 UTC 2019
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Boot CPU: AArch64 Processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] OF: fdt:memory scan node memory, reg size 48,
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] OF: fdt: - 80000000 , 2a000000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] OF: fdt: - aa200000 , 46a00000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] OF: fdt: - 100000000 , 380000000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options ‘’)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] bootconsole [tegra_comb_uart0] enabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Found tegra_fbmem: 00800000@a0791000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Found lut_mem: 00002008@a078e000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] cma: Reserved 64 MiB at 0x00000000ec800000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] On node 0 totalpages: 4130816
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] DMA zone: 7200 pages used for memmap
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] DMA zone: 0 pages reserved
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] DMA zone: 460800 pages, LIFO batch:31
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Normal zone: 57344 pages used for memmap
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Normal zone: 3670016 pages, LIFO batch:31
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] psci: probing for conduit method from DT.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] psci: PSCIv1.0 detected in firmware.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] psci: Using standard PSCI v0.2 function IDs
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] psci: SMC Calling Convention v1.1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] percpu: Embedded 24 pages/cpu @ffffffc3ffdad000 s57664 r8192 d32448 u98304
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] pcpu-alloc: s57664 r8192 d32448 u98304 alloc=24*4096
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5 [0] 6 [0] 7
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 4066272
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 OS=l4t video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt tegra_fbmem=0x800000@0xa0791000 lut_mem=0x2008@0xa078e000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.2.2 sdhci_tegra.en_boot_part_access=1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Dentry cache hash table entries: 2097152 (order: 13, 33554432 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Memory: 16107964K/16523264K available (15486K kernel code, 2974K rwdata, 6968K rodata, 8448K init, 1722K bss, 349764K reserved, 65536K cma-reserved)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Virtual kernel memory layout:
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008fa0000 ( 15488 KB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] .rodata : 0xffffff8008fa0000 - 0xffffff8009680000 ( 7040 KB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] .init : 0xffffff8009680000 - 0xffffff8009ec0000 ( 8448 KB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] .data : 0xffffff8009ec0000 - 0xffffff800a1a7808 ( 2975 KB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] .bss : 0xffffff800a1a7808 - 0xffffff800a356228 ( 1723 KB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] 0xffffffbf00000000 - 0xffffffbf10000000 ( 256 MB actual)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] memory : 0xffffffc000000000 - 0xffffffc400000000 ( 16384 MB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] Preemptible hierarchical RCU implementation.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] RCU kthread priority: 1.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] **********************************************************
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE NOTICE **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** trace_printk() being used. Allocating extra memory. **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** This means that this is a DEBUG kernel and it is **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** unsafe for production use. **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** If you see this message and you are not debugging **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] ** the kernel, report this immediately to your vendor! **
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] NR_IRQS:64 nr_irqs:64 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] GIC: Using split EOI/Deactivate mode
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000007] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000997] Console: colour dummy device 80x25
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.305227] console [tty0] enabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.305233] bootconsole [tegra_comb_uart0] disabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.305336] kmemleak: Kernel memory leak detector disabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.305366] Calibrating delay loop (skipped), value calculated using timer frequency… 62.50 BogoMIPS (lpj=125000)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.305371] pid_max: default: 32768 minimum: 301
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.306744] Security Framework initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.307574] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.307583] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.310121] ftrace: allocating 47851 entries in 187 pages
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.781753] sched-energy: Sched-energy-costs installed from DT
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.782188] ASID allocator initialised with 65536 entries
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.840900] tegra-id: chipid=21917.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.840968] tegra-id: opt_subrevision=0.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.841059] Tegra Revision: A02 SKU: 0xd0 CPU Process: 0 SoC Process: 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.841134] DTS File Name: /home/jahr_se/nvidia_env/public_sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.841196] DTB Build time: Feb 26 2019 15:58:04
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.842305] tegra-roc-flush: DT required.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.901665] CPU1: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.945488] CPU2: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.989754] CPU3: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.034323] CPU4: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.078563] CPU5: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.123163] CPU6: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.167496] CPU7: Booted secondary processor [4e0f0040]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.169562] Brought up 8 CPUs
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.170404] SMP: Total of 8 processors activated.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.170454] CPU features: detected feature: Privileged Access Never
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.170504] CPU features: detected feature: LSE atomic instructions
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.170601] CPU features: detected feature: User Access Override
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.170650] CPU features: detected feature: 32-bit EL0 Support
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.175284] CPU: All CPU(s) started at EL2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.175451] alternatives: patching kernel code
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.196016] devtmpfs: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.289218] Initilizing CustomIPI irq domain
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.289859] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.289928] futex hash table entries: 2048 (order: 6, 262144 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.292775] pinctrl core: initialized pinctrl subsystem
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.293117] OS set in device tree is not L4T.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.293515] regulator-dummy: no parameters
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.293983] Initializing plugin-manager
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.294076] Plugin module not found
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.294137] Plugin-manager status disabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.296513] NET: Registered protocol family 16
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.298886] pstore: using zlib compression
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.300347] console [pstore-1] enabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.300400] pstore: Registered ramoops as persistent store backend
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.300443] ramoops: attached 0x200000@0xf0a00000, ecc: 0/0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.302255] cpuidle: using governor menu
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.303969] bpmp: waiting for handshake
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.304014] bpmp: handshake completed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.304076] bpmp: synchronizing channels
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.304115] bpmp: channels synchronized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.304151] bpmp: mail init ok
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.308863] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309294] t19x-arm-smmu 12000000.iommu: probing hardware configuration…
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309340] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309379] t19x-arm-smmu 12000000.iommu: stage 1 translation
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309419] t19x-arm-smmu 12000000.iommu: stage 2 translation
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309458] t19x-arm-smmu 12000000.iommu: nested translation
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309499] t19x-arm-smmu 12000000.iommu: stream matching with 128 register groups, mask 0x7f80
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309566] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309703] t19x-arm-smmu 12000000.iommu: 64 context banks (0 stage-2 only)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309768] t19x-arm-smmu 12000000.iommu: Stage-1: 39-bit VA → 48-bit IPA
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.309833] t19x-arm-smmu 12000000.iommu: Stage-2: 39-bit IPA → 48-bit PA
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.316322] vdso: 2 pages (1 code @ ffffff8008fa7000, 1 data @ ffffff8009ec4000)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.316452] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.323939] atomic_pool_init():622: DMA: preallocated 2048 KiB pool for atomic allocations
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.325337] Registering BPMP clocks…
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.325596] tegra_bpmp_clk_init: clock init ok (395 clks)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.326134] tegra_bpmp_of_clk_init: EMC proxy not found.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.326928] tegra_powergate_init: DONE
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.327028] DTS File Name: /home/jahr_se/nvidia_env/public_sources/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.327186] DTB Build time: Feb 26 2019 15:58:04
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.332295] tegra_debug_uart_syscore_init: stdout-path property missing
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.332366] Tegra reboot handler registered.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.343538] iommu: Adding device 14180000.pcie to group 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.344954] iommu: Adding device 14100000.pcie to group 1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.346072] iommu: Adding device 14140000.pcie to group 2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.347206] iommu: Adding device 141a0000.pcie to group 3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.349843] iommu: Adding device 2490000.ether_qos to group 4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.350734] iommu: Adding device 3100000.serial to group 5
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.351597] iommu: Adding device 3110000.serial to group 6
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.352310] iommu: Adding device 3140000.serial to group 7
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.353332] tegra-pmc c360000.pmc: scratch reg offset dts data not present
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.353922] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.354036] tegra-pmc: ### PMC reset source: TEGRA_POWER_ON_RESET
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.354085] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.354134] tegra-pmc: ### PMC reset status reg: 0x0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.354241] tegra-pmc: PMC Prod config success
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.354640] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.354718] tegra-pmc c360000.pmc: IO padctrl driver initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.355380] iommu: Adding device 3460000.sdhci to group 8
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.356188] iommu: Adding device 3400000.sdhci to group 9
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.357068] iommu: Adding device c260000.spi to group 10
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.358347] iommu: Adding device 3160000.i2c to group 11
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.359113] iommu: Adding device c240000.i2c to group 12
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.359886] iommu: Adding device 3180000.i2c to group 13
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.360593] iommu: Adding device 3190000.i2c to group 14
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.361378] iommu: Adding device 31b0000.i2c to group 15
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.362006] iommu: Adding device 31c0000.i2c to group 16
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.362641] iommu: Adding device c250000.i2c to group 17
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.363258] iommu: Adding device 31e0000.i2c to group 18
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.364436] iommu: Adding device sound to group 19
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.365348] iommu: Adding device 3510000.hda to group 20
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.366203] iommu: Adding device bc00000.rtcpu to group 21
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.369478] iommu: Adding device 13e10000.host1x to group 22
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.370182] iommu: Adding device 13e10000.host1x:ctx0 to group 23
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.371689] iommu: Adding device 13e10000.host1x:ctx1 to group 24
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.373284] iommu: Adding device 13e10000.host1x:ctx2 to group 25
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.374772] iommu: Adding device 13e10000.host1x:ctx3 to group 26
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.376355] iommu: Adding device 13e10000.host1x:ctx4 to group 27
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.378051] iommu: Adding device 13e10000.host1x:ctx5 to group 28
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.379462] iommu: Adding device 13e10000.host1x:ctx6 to group 29
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.381051] iommu: Adding device 13e10000.host1x:ctx7 to group 30
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.382692] iommu: Adding device 15340000.vic to group 31
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.384058] iommu: Adding device 15380000.nvjpg to group 32
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.384583] iommu: Adding device 15500000.tsec to group 33
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.385180] iommu: Adding device 15100000.tsecb to group 34
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.385663] iommu: Adding device 15480000.nvdec to group 35
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.386166] iommu: Adding device 15140000.nvdec1 to group 36
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.386715] iommu: Adding device 154c0000.nvenc to group 37
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.387357] iommu: Adding device 15a80000.nvenc1 to group 38
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.388272] iommu: Adding device 15880000.nvdla0 to group 39
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.389066] iommu: Adding device 158c0000.nvdla1 to group 40
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.389908] iommu: Adding device 15200000.nvdisplay to group 41
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.390348] platform 15200000.nvdisplay: IOVA linear map 0x00000000a0791000(800000)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.390441] platform 15200000.nvdisplay: IOVA linear map 0x00000000a078e000(3000)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.390510] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.391370] iommu: Adding device 15210000.nvdisplay to group 42
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.391501] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.392279] iommu: Adding device 15220000.nvdisplay to group 43
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.392386] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.395427] iommu: Adding device 15c10000.vi to group 44
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.395723] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.396530] iommu: Adding device 14800000.isp to group 45
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.398800] iommu: Adding device 16000000.pva0 to group 46
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.399705] iommu: Adding device 16800000.pva1 to group 47
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.400372] iommu: Adding device 15810000.se to group 48
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.401187] iommu: Adding device 15820000.se to group 49
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.401860] iommu: Adding device 15830000.se to group 50
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.402324] iommu: Adding device 15840000.se to group 51
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.402810] iommu: Adding device c1a0000.aon to group 52
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.405229] iommu: Adding device d000000.bpmp to group 53
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.405749] bpmp: ping status is 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.405997] bpmp d000000.bpmp: firmware tag is 588c62054ecdba8a44cb9d6ff5d04cb0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.411853] bpmp d000000.bpmp: probe ok
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.414266] tegra-reset 0.bpmp_reset: registered 186 resets.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.415009] iommu: Adding device smmu_test to group 54
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.416581] mc: mapped MMIO address: 0xffffff800a710000 → 0x2c10000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.416672] mc: mapped MMIO address: 0xffffff800a730000 → 0x2c20000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.416765] mc: mapped MMIO address: 0xffffff800a750000 → 0x2c30000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.416854] mc: mapped MMIO address: 0xffffff800a770000 → 0x2c40000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.416943] mc: mapped MMIO address: 0xffffff800a790000 → 0x2c50000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417122] mc: mapped MMIO address: 0xffffff800a7b0000 → 0x2b80000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417222] mc: mapped MMIO address: 0xffffff800a7d0000 → 0x2b90000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417311] mc: mapped MMIO address: 0xffffff800aab0000 → 0x2ba0000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417395] mc: mapped MMIO address: 0xffffff800aad0000 → 0x2bb0000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417480] mc: mapped MMIO address: 0xffffff800aaf0000 → 0x1700000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417580] mc: mapped MMIO address: 0xffffff800ab10000 → 0x1710000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417702] mc: mapped MMIO address: 0xffffff800ab30000 → 0x1720000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417788] mc: mapped MMIO address: 0xffffff800ab50000 → 0x1730000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417872] mc: mapped MMIO address: 0xffffff800ab70000 → 0x1740000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.417976] mc: mapped MMIO address: 0xffffff800ab90000 → 0x1750000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.418070] mc: mapped MMIO address: 0xffffff800abb0000 → 0x1760000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.418150] mc: mapped MMIO address: 0xffffff800abd0000 → 0x1770000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.418309] mc-err: mcerr ops are set to t19x
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.428060] iommu: Adding device 2600000.dma to group 55
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.436424] GPIO line 339 (wifi-enable) hogged as output/high
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.437361] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.447667] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.448102] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.451252] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.451319] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.452499] iommu: Adding device 3550000.xudc to group 56
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.453829] iommu: Adding device 3610000.xhci to group 57
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.455587] arm64_ras arm64_ras: RAS driver enabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.456397] carmel_ras_enable:RAS enabled on cpu0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.456648] carmel_ras_enable:RAS enabled on cpu1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.456905] carmel_ras_enable:RAS enabled on cpu2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.457161] carmel_ras_enable:RAS enabled on cpu3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.457440] carmel_ras_enable:RAS enabled on cpu4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.457681] carmel_ras_enable:RAS enabled on cpu5
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.457914] carmel_ras_enable:RAS enabled on cpu6
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.458154] carmel_ras_enable:RAS enabled on cpu7
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.458387] carmel_ras_enable:RAS enabled on cpu0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.458584] carmel_ras_enable:RAS enabled on cpu1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.458779] carmel_ras_enable:RAS enabled on cpu2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.459061] carmel_ras_enable:RAS enabled on cpu3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.459270] carmel_ras_enable:RAS enabled on cpu4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.459449] carmel_ras_enable:RAS enabled on cpu5
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.459647] carmel_ras_enable:RAS enabled on cpu6
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.459843] carmel_ras_enable:RAS enabled on cpu7
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.459925] carmel_ras carmel_ras: probed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.462601] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 478, noc_nonsecure_irq = 477>
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.463932] tegra-cbb c600000.aon-noc: noc_secure_irq = 480, noc_nonsecure_irq = 479>
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.465625] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 482, noc_nonsecure_irq = 481>
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.467446] tegra-cbb be00000.rce-noc: noc_secure_irq = 484, noc_nonsecure_irq = 483>
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.469106] tegra-cbb b600000.sce-noc: noc_secure_irq = 486, noc_nonsecure_irq = 485>
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.470118] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.474987] vdd-3v3-cvb: 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.475892] vdd-1v8-cvb: 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.476616] vdd-1v8-sd: 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.477390] vdd-epb-1v0: supplied by vdd-3v3-cvb
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.477511] vdd-epb-1v0: 1000 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.478208] vdd-sdmmc1-sw: 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.478928] avdd-cam-2v8: 2800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.479466] vdd-sata-1v5: 1500 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.480143] vdd-1v8-slt: 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.480967] vdd-3v3-slt: 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.481720] vdd-fan: 5000 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.482534] vdd-hdmi-5v0: 5000 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.483205] vdd_sys_en: 1200 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.484077] vdd-5v-sata: 5000 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.485008] vdd-ac-bat: 5000 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.485437] vdd-5v-sata: supplied by vdd-ac-bat
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.518272] eventlib_kernel: keventlib is initialized, test id: 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.518956] SCSI subsystem initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.519407] libata version 3.00 loaded.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.519932] usbcore: registered new interface driver usbfs
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.520314] usbcore: registered new interface driver hub
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.520660] usbcore: registered new device driver usb
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.540004] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.543599] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.556938] vdd-1v0: at 1000 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.565161] vdd-1v8-hs: at 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.573199] vdd-1v8-ls: at 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.581304] vdd-1v8-ao: at 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.589266] vddio-ddr-1v1: at 1100 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.597040] vdd-rtc: at 800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.598719] spmic-ldo1: at 2375 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.609064] vdd-ao-3v3: at 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.621228] vddio-emmc-3v3: at 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.623116] spmic-ldo4: at 1587 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.633370] vdd-usb-3v3: at 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.645443] vddio-sdmmc1-3v3: at 3300 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.653444] vdd-csi-1v2: at 1200 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.655603] spmic-ldo8: at 1800 mV
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.658361] GPIO line 246 (gpio_default) hogged as output/high
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.660198] GPIO line 247 (gpio_default) hogged as output/high
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.660948] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.665739] max77620 4-003c: max77620 probe successful
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.666983] media: Linux media interface: v0.10
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.667290] Linux video capture interface: v2.00
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.670175] pps_core: LinuxPPS API ver. 1 registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.670224] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.670352] PTP clock support registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.671621] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.671725] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.673717] tegra_fiq_debugger_init: found FIQ source (IRQ 468)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.676286] Advanced Linux Sound Architecture Driver Initialized.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.677176] Bluetooth: Core ver 2.22
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.677301] NET: Registered protocol family 31
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.677345] Bluetooth: HCI device and connection manager initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.677416] Bluetooth: HCI socket layer initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.677542] Bluetooth: L2CAP socket layer initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.677622] Bluetooth: SCO socket layer initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.681529] camchar: rtcpu character device driver loaded
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.683260] clocksource: Switched to clocksource arch_sys_counter
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.750237] VFS: Disk quotas dquot_6.6.0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.750427] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.750918] nvmap_heap_init: nvmap_heap_init: created heap block cache
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.753715] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.753881] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.753934] nvmap_page_pool_init: Total RAM pages: 4043375
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.753974] nvmap_page_pool_init: nvmap page pool size: 505421 pages (1974 MB)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.754222] nvmap_background_zero_thread: PP zeroing thread starting.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.760560] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.778929] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.779614] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.780055] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.780700] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.781358] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type Tdiode_tegra
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.781778] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type PMIC-Die
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.782183] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tboard_tegra
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.798189] la/ptsa driver initialized.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.798909] NET: Registered protocol family 2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.800170] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.801025] TCP bind hash table entries: 65536 (order: 9, 3670016 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.803851] TCP: Hash tables configured (established 131072 bind 65536)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.803972] UDP hash table entries: 8192 (order: 8, 1048576 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.804752] UDP-Lite hash table entries: 8192 (order: 8, 1048576 bytes)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.805887] NET: Registered protocol family 1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.806824] RPC: Registered named UNIX socket transport module.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.806871] RPC: Registered udp transport module.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.806906] RPC: Registered tcp transport module.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.806938] RPC: Registered tcp NFSv4.1 backchannel transport module.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.806980] PCI: CLS 0 bytes, default 128
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.807320] Trying to unpack rootfs image as initramfs…
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.829949] random: fast init done
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.835479] host1x 13e10000.host1x: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.838035] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.845119] audit: initializing netlink subsys (disabled)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.845251] audit: type=2000 audit(1.388:1): initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.846370] workingset: timestamp_bits=46 max_order=22 bucket_order=0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.857415] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.859318] ntfs: driver 2.1.32 [Flags: R/W].
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.860205] 9p: Installing v9fs 9p2000 file system support
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.866557] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.866900] io scheduler noop registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.867462] io scheduler cfq registered (default)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.873287] gic 2a41000.agic-controller: GIC IRQ controller registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.918688] iommu: Adding device 2993000.adsp to group 58
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.040072] iommu: Adding device aconnect@2a41000:adsp_audio to group 59
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.041404] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.065152] tegra-pwm c340000.pwm: PWM clk can sleep in ops
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.065965] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.066857] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.070781] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.071386] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.071469] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=2000000, max_bw=4687500
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.076393] tsec 15500000.tsec: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.079513] tsec 15100000.tsecb: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.085414] nvdec 15480000.nvdec: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.089820] nvdec 15140000.nvdec1: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.096223] falcon 15340000.vic: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.099715] falcon 15380000.nvjpg: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.102483] falcon 154c0000.nvenc: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.105334] falcon 15a80000.nvenc1: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.108382] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.110877] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.113651] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.116233] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.118375] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.120540] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.122673] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.124957] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.129988] t194-nvcsi 15a00000.nvcsi: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.137020] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.137627] scare-pigeon 14b00000.isp-thi: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.148883] pva 16000000.pva0: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.181949] pva 16800000.pva1: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.213347] nvdla 15880000.nvdla0: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.245417] nvdla 158c0000.nvdla1: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.249969] tegra-slvs-ec 15ac0000.slvs-ec: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.250183] tegra-slvs-ec 15ac0000.slvs-ec: no streams defined
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.250229] tegra-slvs-ec 15ac0000.slvs-ec: failed to init SLVS media controller (-19)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.250288] tegra-slvs-ec 15ac0000.slvs-ec: probed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.251773] tegradccommon 15200000.dc_common: host1x channel mapped
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.251848] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.251981] tegradccommon 15200000.dc_common: dma mapping done
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.252952] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.253138] generic_infoframe_type: 0x87
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.253433] tegradc 15200000.nvdisplay: DT parsed successfully
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.253548] tegradc 15200000.nvdisplay: Display dc.ffffff800d010000 registered with id=0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.264817] tegra_nvdisp_bandwidth_register_max_config: max config iso bw = 15681600 KB/s
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.264898] tegra_nvdisp_bandwidth_register_max_config: max config EMC floor = 1066500000 Hz
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.264954] tegra_nvdisp_bandwidth_register_max_config: max config hubclk = 358400000 Hz
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.265433] tegradc 15200000.nvdisplay: vblank syncpt # 8 for dc 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.265496] tegradc 15200000.nvdisplay: vpulse3 syncpt # 9 for dc 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.268298] tegradc 15200000.nvdisplay: Bootloader disp_param detected. Detected mode: 1920x1080 (on 0x0mm) pclk=148350937
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.268894] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 16 channels
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.269994] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.271848] kfuse 3830000.kfuse: initialized
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.273074] tegradc 15200000.nvdisplay: hdmi: invalid prod list prod_list_hdmi_board
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.273141] tegradc 15200000.nvdisplay: hdmi: tegra_hdmi_tmds_range_read(bd) failed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.278279] tegradc 15200000.nvdisplay: probed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.280264] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.283824] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 50, base_baud = 0) is a TEGRA_UART
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.285571] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 51, base_baud = 0) is a TEGRA_UART
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 2.286910] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 52, base_baud = 0) is a TEGRA_UART
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.705419] console [ttyTCU0] enabled
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.706516] Console: switching to colour frame buffer device 240x67
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.711456] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:290 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.729088] tegradc 15200000.nvdisplay: fb registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.735286] gpio tegra-gpio wake71 for gpio=98(M:2)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.740415] brd: module loaded
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.750479] loop: module loaded
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.750773] tegra_profiler: version: 1.128, samples/io: 44/25
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.751504] tegra_profiler: auth: init
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.755989] nct1008_nct72 4-004c: starting parse dt
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.756813] THERMAL EST: found 3 subdevs
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.756818] THERMAL EST num_resources: 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.756822] [THERMAL EST subdev 0]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.756845] [THERMAL EST subdev 1]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.756857] [THERMAL EST subdev 2]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.757250] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.757252] THERMAL EST: thz register success.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.757468] THERMAL EST: end of probe, return err: 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.758385] hisi_sas: driver version v1.6
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.800609] nct1008_nct72 4-004c: !!!Found deprecated property!!!
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.803994] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.804233] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.810200] libphy: Fixed MDIO Bus: probed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.812205] tun: Universal TUN/TAP device driver, 1.6
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.812210] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.813824] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.813830] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.813891] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.813895] igb: Copyright (c) 2007-2014 Intel Corporation.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.813949] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.813951] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.814007] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.814010] Copyright(c) 1999 - 2017 Intel Corporation.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.818673] sky2: driver version 1.30
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820376] PPP generic driver version 2.4.2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820643] PPP BSD Compression module registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820647] PPP Deflate Compression module registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820671] PPP MPPE Compression module registered
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820675] NET: Registered protocol family 24
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820749] usbcore: registered new interface driver r8152
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820818] usbcore: registered new interface driver asix
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820881] usbcore: registered new interface driver ax88179_178a
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.820959] usbcore: registered new interface driver cdc_ether
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.821020] eqos 2490000.ether_qos: no PHY interrupt found
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.821025] usbcore: registered new interface driver net1080
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.821080] usbcore: registered new interface driver cdc_subset
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.821144] usbcore: registered new interface driver zaurus
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.821210] usbcore: registered new interface driver cdc_ncm
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.821726] VFIO - User Level meta-driver version: 0.3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.822835] Parent Clock set for DC plld3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823688] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823708] ehci-pci: EHCI PCI platform driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823754] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823766] ohci-pci: OHCI PCI platform driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823821] ohci-platform: OHCI generic platform driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.827438] eqos 2490000.ether_qos: No prod values found
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.828250] eqos 2490000.ether_qos: Setting local MAC: 0 4 4b cb ae 12
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.828423] libphy: dwc_phy: probed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.835331] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.835337] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.838895] Could not get extcon-dev /xhci@3610000:id(0)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.843070] usbcore: registered new interface driver uas
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.843303] usbcore: registered new interface driver usb-storage
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.843449] usbcore: registered new interface driver usbserial
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.847991] Could not get extcon-dev /xudc@3550000:vbus(0)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.851262] ucsi_ccg 1-0008: FW1 Version: gn v12.05, [Base 3.1.2.1487]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.851307] ucsi_ccg 1-0008: FW2 Version: gn v12.05, [Base 3.1.2.1487]
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852460] ucsi_ccg 1-0008: fw_mode: 2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852464] ucsi_ccg 1-0008: fw1_invalid: 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852467] ucsi_ccg 1-0008: fw2_invalid: 0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852471] ucsi_ccg 1-0008: silicon_id: 0x1f00
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852668] ucsi_ccg 1-0008: typec-port0 extcon dev created
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852820] ucsi_ccg 1-0008: typec-port1 extcon dev created
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.852942] ucsi_ccg 1-0008: typec-pd extcon dev created
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.853214] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.855201] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.856168] ucsi_ccg 1-0008: get_current_pdo: 3e01912c:
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.856175] ucsi_ccg 1-0008: [typec-port0] DO type 0, max_current 300, voltage 100
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.860209] ucsi_ccg 1-0008: HPI Command Success.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.862905] ucsi_ccg 1-0008: HPI Command Success.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.862947] ucsi_ccg 1-0008: ucsi_ccg_init: complete
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.863811] mousedev: PS/2 mouse device common for all mice
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.886913] tegradc 15200000.nvdisplay: hdmi: tmds rate:148367K prod-setting:prod_c_hdmi_111m_223m
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.889050] tegradc 15210000.nvdisplay: disp1 connected to head1->/host1x/sor
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.889167] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.889452] tegradc 15210000.nvdisplay: DT parsed successfully
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.889529] tegradc 15210000.nvdisplay: Display dc.ffffff800d3e0000 registered with id=1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.889846] tegradc 15210000.nvdisplay: vblank syncpt # 11 for dc 1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.889854] tegradc 15210000.nvdisplay: vpulse3 syncpt # 12 for dc 1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.897423] tegradc 15210000.nvdisplay: probed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.998066] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.000058] Wake73 for irq=42
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.001633] rtc rtc1: alarm rtc device
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.001650] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.001734] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.001966] i2c /dev entries driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.005859] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.011588] FAN dev name: pwm-fan
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.011699] FAN:gpio request success.
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.011709] FAN: can’t find tach_gpio
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.011762] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012060] pwm_fan_driver pwm-fan: got pwm for fan. polarity is inversed
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012067] pwm_fan_driver pwm-fan: tach period: 1000
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012557] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012564] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012570] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012575] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012580] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012585] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012589] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012594] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012599] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.012605] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.013565] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 0 not supported
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.014007] tegra-bpmp-thermal d000000.bpmp:bpmpthermal: zone 2 not supported
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.017422] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072126] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072175] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072184] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072327] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072462] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072466] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.072967] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.073078] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.073094] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.073483] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.073577] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.073589] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.074042] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.074158] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.074164] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.074485] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.076506] device-mapper: uevent: version 1.0.3
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.077144] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.081698] tegra194_cpufreq_probe: platform driver Initialization: pass
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.083232] cpuidle: Initializing cpuidle driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.084650] sdhci: Secure Digital Host Controller Interface driver
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.084651] sdhci: Copyright(c) Pierre Ossman
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.084653] sdhci-pltfm: SDHCI platform and OF driver helper
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.086445] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.088688] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.089439] sdhci-tegra 3400000.sdhci: Got CD GPIO
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.091288] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.093040] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 253
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.131149] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.139279] gpio tegra-gpio wake8 for gpio=55(G:7)
Jan 28 16:58:29 jetson-0423618000794 kernel: [ 5.13935
Sorry for the lengthy version. I don’t see any option to upload files here…
Is this full log? I don’t see PCIe host controller driver prints at all. If this is not the full log, can you please attach it? Also, did you make any modifications to the device tree? Is CVB/baseboard same as Jetson-Xavier’s baseboard or is it custom baseboard?
Now we did not do any changes to the Xavier bord. I honestly don’t see how I can attach files here. As far as I see, this is the complete kern.log file. Maybe the length of replies here is limited and it cut of parts? When I $ grep -rni pci in that file I get this output:
kern.log:44:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
kern.log:147:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.343538] iommu: Adding device 14180000.pcie to group 0
kern.log:148:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.344954] iommu: Adding device 14100000.pcie to group 1
kern.log:149:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.346072] iommu: Adding device 14140000.pcie to group 2
kern.log:150:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.347206] iommu: Adding device 141a0000.pcie to group 3
kern.log:358:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 1.806980] PCI: CLS 0 bytes, default 128
kern.log:464:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.814007] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
kern.log:484:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823708] ehci-pci: EHCI PCI platform driver
kern.log:486:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 4.823766] ohci-pci: OHCI PCI platform driver
kern.log:698:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.157126] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
kern.log:699:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.164940] OF: PCI: host bridge /pcie@14180000 ranges:
kern.log:700:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.168610] OF: PCI: IO 0x38100000…0x381fffff → 0x38100000
kern.log:701:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.174371] OF: PCI: MEM 0x38200000…0x39ffffff → 0x38200000
kern.log:702:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.180319] OF: PCI: MEM 0x1800000000…0x1bffffffff → 0x1800000000
kern.log:703:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.698220] tegra-pcie-dw 14180000.pcie: link is down
kern.log:704:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.699658] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
kern.log:705:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.700819] pci_bus 0000:00: root bus resource [bus 00-ff]
kern.log:706:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.701932] pci_bus 0000:00: root bus resource [io 0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
kern.log:707:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.703194] pci_bus 0000:00: root bus resource [mem 0x38200000-0x39ffffff]
kern.log:708:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.704326] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1bffffffff pref]
kern.log:709:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.705496] pci 0000:00:00.0: [10de:1ad0] type 01 class 0x060400
kern.log:710:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.705669] pci 0000:00:00.0: PME# supported from D0 D3hot D3cold
kern.log:712:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.707349] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
kern.log:713:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.708499] pci 0000:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
kern.log:714:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.710036] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
kern.log:715:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.711364] pcie_pme 0000:00:00.0:pcie001: service driver pcie_pme loaded
kern.log:716:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.711724] aer 0000:00:00.0:pcie002: service driver aer loaded
kern.log:717:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.711965] pcie_pme 0000:00:00.0:pcie001: unloading service driver pcie_pme
kern.log:718:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.712076] aer 0000:00:00.0:pcie002: unloading service driver aer
kern.log:719:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.712218] pci_bus 0000:01: busn_res: [bus 01-ff] is released
kern.log:721:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.713472] pci_bus 0000:00: busn_res: [bus 00-ff] is released
kern.log:722:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.713784] tegra-pcie-dw 14180000.pcie: PCIe link is not up…!
kern.log:723:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.716386] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
kern.log:724:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.719051] OF: PCI: host bridge /pcie@14100000 ranges:
kern.log:725:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.720197] OF: PCI: IO 0x30100000…0x301fffff → 0x30100000
kern.log:726:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.721333] OF: PCI: MEM 0x30200000…0x31ffffff → 0x30200000
kern.log:727:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.722460] OF: PCI: MEM 0x1200000000…0x123fffffff → 0x1200000000
kern.log:728:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.831153] tegra-pcie-dw 14100000.pcie: link is up
kern.log:729:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.832447] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
kern.log:730:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.833596] pci_bus 0001:00: root bus resource [bus 00-ff]
kern.log:731:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.834700] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
kern.log:732:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.835942] pci_bus 0001:00: root bus resource [mem 0x30200000-0x31ffffff]
kern.log:733:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.837077] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x123fffffff pref]
kern.log:734:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.838260] pci 0001:00:00.0: [10de:1ad2] type 01 class 0x060400
kern.log:735:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.838424] pci 0001:00:00.0: PME# supported from D0 D3hot D3cold
kern.log:737:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841206] pci 0001:01:00.0: [1b4b:9171] type 00 class 0x010601
kern.log:738:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841354] pci 0001:01:00.0: reg 0x10: [io 0x8000-0x8007]
kern.log:739:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841426] pci 0001:01:00.0: reg 0x14: [io 0x8040-0x8043]
kern.log:740:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841516] pci 0001:01:00.0: reg 0x18: [io 0x8100-0x8107]
kern.log:741:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841588] pci 0001:01:00.0: reg 0x1c: [io 0x8140-0x8143]
kern.log:742:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841659] pci 0001:01:00.0: reg 0x20: [io 0x800000-0x80000f]
kern.log:743:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841747] pci 0001:01:00.0: reg 0x24: [mem 0x00900000-0x009001ff]
kern.log:744:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.841819] pci 0001:01:00.0: reg 0x30: [mem 0xd0000000-0xd000ffff pref]
kern.log:745:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.842207] pci 0001:01:00.0: PME# supported from D3hot
kern.log:747:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.857531] pci 0001:00:00.0: BAR 14: assigned [mem 0x30200000-0x302fffff]
kern.log:748:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.858709] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
kern.log:749:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.859920] pci 0001:01:00.0: BAR 6: assigned [mem 0x30200000-0x3020ffff pref]
kern.log:750:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.861112] pci 0001:01:00.0: BAR 5: assigned [mem 0x30210000-0x302101ff]
kern.log:751:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.862322] pci 0001:01:00.0: BAR 4: assigned [io 0x100000-0x10000f]
kern.log:752:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.863556] pci 0001:01:00.0: BAR 0: assigned [io 0x100010-0x100017]
kern.log:753:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.864748] pci 0001:01:00.0: BAR 2: assigned [io 0x100018-0x10001f]
kern.log:754:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.865939] pci 0001:01:00.0: BAR 1: assigned [io 0x100020-0x100023]
kern.log:755:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.867224] pci 0001:01:00.0: BAR 3: assigned [io 0x100024-0x100027]
kern.log:756:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.868452] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
kern.log:757:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.869606] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
kern.log:758:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.870799] pci 0001:00:00.0: bridge window [mem 0x30200000-0x302fffff]
kern.log:759:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.872061] pci 0001:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
kern.log:760:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.880275] pci 0001:01:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
kern.log:761:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.888905] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
kern.log:762:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.895804] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
kern.log:763:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.902281] pcie_pme 0001:00:00.0:pcie001: service driver pcie_pme loaded
kern.log:764:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.902608] aer 0001:00:00.0:pcie002: service driver aer loaded
kern.log:770:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.929044] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
kern.log:771:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.936992] OF: PCI: host bridge /pcie@14140000 ranges:
kern.log:772:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.940795] OF: PCI: IO 0x34100000…0x341fffff → 0x34100000
kern.log:773:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.946573] OF: PCI: MEM 0x34200000…0x35ffffff → 0x34200000
kern.log:774:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 10.952693] OF: PCI: MEM 0x1280000000…0x12bfffffff → 0x1280000000
kern.log:776:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.470498] tegra-pcie-dw 14140000.pcie: link is down
kern.log:777:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.472192] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0002:00
kern.log:778:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.473550] pci_bus 0002:00: root bus resource [bus 00-ff]
kern.log:779:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.474847] pci_bus 0002:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
kern.log:780:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.476285] pci_bus 0002:00: root bus resource [mem 0x34200000-0x35ffffff]
kern.log:781:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.477621] pci_bus 0002:00: root bus resource [mem 0x1280000000-0x12bfffffff pref]
kern.log:782:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.479001] pci 0002:00:00.0: [10de:1ad2] type 01 class 0x060400
kern.log:783:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.479208] pci 0002:00:00.0: PME# supported from D0 D3hot D3cold
kern.log:785:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.481088] pci 0002:00:00.0: PCI bridge to [bus 01-ff]
kern.log:786:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.482424] pci 0002:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
kern.log:787:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.484237] pcieport 0002:00:00.0: Signaling PME through PCIe PME interrupt
kern.log:788:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.485726] pcie_pme 0002:00:00.0:pcie001: service driver pcie_pme loaded
kern.log:789:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.486040] aer 0002:00:00.0:pcie002: service driver aer loaded
kern.log:790:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.486279] pcie_pme 0002:00:00.0:pcie001: unloading service driver pcie_pme
kern.log:791:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.486389] aer 0002:00:00.0:pcie002: unloading service driver aer
kern.log:792:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.486543] pci_bus 0002:01: busn_res: [bus 01-ff] is released
kern.log:794:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.488948] pci_bus 0002:00: busn_res: [bus 00-ff] is released
kern.log:795:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.489162] tegra-pcie-dw 14140000.pcie: PCIe link is not up…!
kern.log:796:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.491946] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
kern.log:797:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.495052] OF: PCI: host bridge /pcie@141a0000 ranges:
kern.log:798:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.496476] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
kern.log:799:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.497861] OF: PCI: MEM 0x3a200000…0x3bffffff → 0x3a200000
kern.log:800:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 11.499244] OF: PCI: MEM 0x1c00000000…0x1fffffffff → 0x1c00000000
kern.log:801:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.009938] tegra-pcie-dw 141a0000.pcie: link is down
kern.log:802:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.011521] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0003:00
kern.log:803:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.012888] pci_bus 0003:00: root bus resource [bus 00-ff]
kern.log:804:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.014214] pci_bus 0003:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
kern.log:805:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.015675] pci_bus 0003:00: root bus resource [mem 0x3a200000-0x3bffffff]
kern.log:806:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.017035] pci_bus 0003:00: root bus resource [mem 0x1c00000000-0x1fffffffff pref]
kern.log:807:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.018527] pci 0003:00:00.0: [10de:1ad0] type 01 class 0x060400
kern.log:808:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.018664] pci 0003:00:00.0: PME# supported from D0 D3hot D3cold
kern.log:810:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.020501] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
kern.log:811:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.021848] pci 0003:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
kern.log:812:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.023623] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
kern.log:813:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.025075] pcie_pme 0003:00:00.0:pcie001: service driver pcie_pme loaded
kern.log:814:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.025364] aer 0003:00:00.0:pcie002: service driver aer loaded
kern.log:815:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.025578] pcie_pme 0003:00:00.0:pcie001: unloading service driver pcie_pme
kern.log:816:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.025703] aer 0003:00:00.0:pcie002: unloading service driver aer
kern.log:817:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.025822] pci_bus 0003:01: busn_res: [bus 01-ff] is released
kern.log:819:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.027415] pci_bus 0003:00: busn_res: [bus 00-ff] is released
kern.log:820:Jan 28 16:58:29 jetson-0423618000794 kernel: [ 12.027726] tegra-pcie-dw 141a0000.pcie: PCIe link is not up…!
Can you please add “nvidia,disable-clock-request” entry to pcie@141a0000 DT node and check? I’m wondering if the card you are connecting doesn’t have CLKREQ signal?
How exactly would I do that? Could you point me to the file I need to edit to add this entry?
Please download the kernel source from our download center.
Add above line into the device tree and flash this new device tree to DUT.
You could see the device tree name(DTB_FILE) inside “p2972-0000.conf.common” and would know which file you need to modify.
Now that I am back from vacation I can finally answer here. Sorry for the delay. We are looking into that and I will come back to once we have tried it. One side-note: We are using a realtime-kernel on the Xavier as we use it to control a robot. Can that interfere with the issue we are discussing here?
Ideally it shouldn’t.
Thanks for the info.
Unfortunately our only Jetson Xavier is blocked until the 10th of July for a demo, meaning we cannot mess with the kernel until then. I will come back to you once we tried your proposal.
When searching for the .dtb file referenced in p2972-0000.conf.common I find actually three .dtb files in: Linux_for_Tegra/bootloader, Linux_for_Tegra/kernel/dtb and Linux_for_Tegra/rootfs/boot. I modified all three to include the “nvidia,disable-clock-request” entry. I then flashed the Xavier and it won’t boot properly:
- pcieport 0003:00:00.0: Signaling PME through PCIe PMME interrupt
- ionmu: Removing device 0003:00:00.0 from group 63!
- tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
What did I miss?
Hi Bruno,
Please file a new topic for your issue. It seems not related to original topic…
