Rep.modify.visibility(rep.distribution.sequence(...)) not working as expected Isaac Sim 4.0.0
Hello, I am following the example here: synthetic-data-examples/omni.replicator/snippets/replicator_multi_object_visibility_toggle.py at main · NVIDIA-Omniverse/synthetic-data-examples · GitHub
I have a simple code that groups three shapes and tries to toggle visability between them:
with rep.new_layer():
    with rep.trigger.on_time(interval = 1):
        cube = rep.create.cube()
        sphere = rep.create.sphere()
        cylinder = rep.create.cylinder()
        group = rep.create.group([cube, sphere, cylinder])
        with group:
            visability = rep.distribution.sequence([[True, False, False], [False, True, False], [False, False, True]])
            rep.modify.visibility(visability)
But all three prims are either visible or invisible.
Not sure what I am doing wrong.
visability_and_sequence
Thank you
Hi @danielle.sisserman ,
I have a bit of egg on my face on this one. I wrote the code to support this and published the example code. Only, I forgot to merge the code that actually made this functional.
This will likely come out in the next release (something after the current 1.11.16).
Sorry for the confusion!
Hi David, thank you for the reply. looking forward to the solution.
