Repeated calls to OpenACC-using function leak VRAM
The below test executable demonstrates the problem. With the ever-growing range-size (N), the VRAM is never released and keeps accumulating… Using nvc++ version 2025.11
Please, advise.
 * Minimal reproducer: scoped #pragma acc data copyin leaks VRAM
 * when allocation sizes vary across calls.
 * Build:
 *   nvc++ -acc -gpu=cc100 -O2 -o vram_leak vram_leak_test4_min.cpp -ldl
 * Expected: delta stays ~0 MB (memory freed at end of scoped block).
 * Actual:   delta grows monotonically, never stabilizes.
#include <cstdio>
#include <cstdlib>
#include <dlfcn.h>
#include <openacc.h>
static size_t
gpu_free_mb(void)
	size_t free_bytes, total_bytes;
	typedef int (*cuMemGetInfo_t)(size_t *, size_t *);
	static cuMemGetInfo_t fn;
	if (!fn) {
		void *h = dlopen("libcuda.so.1", RTLD_NOW | RTLD_GLOBAL);
		if (h)
			fn = (cuMemGetInfo_t)dlsym(h, "cuMemGetInfo_v2");
	if (fn && fn(&free_bytes, &total_bytes) == 0)
		return (free_bytes / (1024 * 1024));
	return (0);
static void
run(size_t N)
	double *buf = new double[N];
	for (size_t i = 0; i < N; ++i)
		buf[i] = 1.0;
	#pragma acc data copyin(buf[0:N])
		#pragma acc parallel loop
			buf[i] *= 2.0;
	/* buf[0:N] should be freed here -- but it is not. */
	delete[] buf;
int
main(void)
	/* Prime-number element counts so every allocation is unique. */
	static const size_t primes[] = {
		 500009,  520013,  540007,  560017,  580027,
		 600011,  620003,  640007,  660013,  680003,
		 700001,  720007,  740011,  760007,  780029,
		 800011,  820007,  840023,  860009,  880001,
		 900001,  920011,  940003,  960017,  980027,
	const int niters = sizeof(primes) / sizeof(primes[0]);
	run(1000);  /* warm up the OpenACC runtime */
	size_t base = gpu_free_mb();
	size_t cum = 0;
	printf("baseline: %zu MB free\n\n", base);
	for (int i = 0; i < niters; i++) {
		size_t N = primes[i];
		cum += N * sizeof(double);
		run(N);
		size_t now = gpu_free_mb();
		printf("iter %2d  N=%7zu (%2zu MB)  free=%5zu MB"
		    "  delta=%4zd MB  cumalloc=%3zu MB\n",
		    i, N, N * 8 / (1024 * 1024), now,
		    (long)base - (long)now, cum / (1024 * 1024));
	printf("\ntotal leaked: %zd MB  (cumulative allocs: %zu MB)\n",
	    (long)base - (long)gpu_free_mb(), cum / (1024 * 1024));
	return (0);
When running with the NV_ACC_MEM_MANAGE=0 the reported leak goes to zero, which is a relief.
I feel like this should be the default – and a lot more prominently documented…
It is done for performance reasons. Allocating memory on GPU is slow, it is better to keep a pool of memory around for reuse.
Multiple malloc-library implementations have been written over the decades for the same reason – the problem is not GPU-specific.
Still, a developer making use of acc-pragmas has a right to expect, all of the memory used by a kernel is freed after the kernel ends.
The usage of pools may make sense for one process accesses the GPU. But multiple workers accessing it in parallel – each with its own collection of allocated and never really freed blocks – blows up VRAM for no fault of the programmer…
Compared to CPU malloc, cudaMalloc is commonly 100x to 10,000x slower for small allocation.
So, for your very specific use case, NV_ACC_MEM_MANAGE=0 is the way to go. For general use, a memory pool is the right choice since it is performant.
