Hi
There are some BatchMatMul operations in my tensorflow model(pb file) and i found that it is same as MatMul. So how do i replace BatchMatMul with default MatMul when convert pb to uff file ?
For example, if the operation of network/attention_block/MatMul is BatchMatMul, how do i replace it with default MatMul ?
"network/attention_block/MatMul": gs.create_plugin_node(name="ab_matmul", op=" ? ")
