We have a host with a ConnectX-3 adapter connected to a SX6036 InfiniBand Switch (https://www.mellanox.com/related-docs/prod_ib_switch_systems/PB_SX6036.pdf ) using FDR10 cable (https://store.mellanox.com/products/nvidia-mc2206310-030-active-optical-cable-infiniband-qdr-fdr10-40gb-s-qsfp-30m.html ).
We would like to know if the ConnectX-3 FDR10 adapter can be replaced with a ConnectX-5 EDR adapter using the same cable.
Thank you.
MvB
February 27, 2021, 12:45am
#2
Hello Ubay,
Thank you for posting your inquiry on the NVIDIA Networking Community.
Based on the information provided, the following link provides the supported FDR10 cables for connecting a ConnectX-5 EDR adapter → https://docs.mellanox.com/display/ConnectX5Firmwarev16292002/Firmware+Compatible+Products#FirmwareCompatibleProducts-ValidatedandSupportedFDR10Cables
If the cable you are using is in the list, it is supported and validated. Please make sure that the adapter and the switch are running the latest f/w and s/w code.
Thank you and regards,
~NVIDIA Networking Technical Support
