Replacing the AI-BOXER-8251-A1-1010 System image from old AI-BOXER-8251A1-JP45E-A1-1010
after replacing the system image at /bootloader then command $ sudo ./flash.sh -r -k APP mmcblk0p to flash the older system image. Flashing the system image is success but after booting up the machine is stuck with the message (See image attached)
can you first contact the vendor for how to flash their boards correctly?
Also, are you sure it’s feasible to flash a board with system images generated for another board?
