Replicator Composer - Cannot use custom characters from Nucleus as obj_model
Hi, I’m having trouble running Replicator Composer for some simulation tests while trying to use assets from the Nucleus server, specifically from the Machinima Squad folder (characters and props). Here is my input YAML file:
# dropped warehouse objects
objects:
  obj_model: /NVIDIA/Assets/Machinima/Squad/Props/Weapons/Props/AK74.usd #/Library/Work Assets/Characters/Soldier_w_Gun_NoMotion.usd #Choice(["assets/models/warehouse.txt"])
  obj_count: 1 #Range(5, 15)
  obj_size_enabled: False
  obj_scale: Uniform(0.75, 1.25)
  obj_vert_fov_loc: Uniform(0, 0.5)
  obj_distance: Uniform(3, 5)
  obj_rot: (Normal(0, 45), Normal(0, 45), Uniform(0, 360))
  obj_class_id: 1
  obj_physics: True
# colorful ceiling lights
lights:
  light_count: Range(0, 2)
  light_coord_camera_relative: False
  light_coord: (Uniform(-2, 2), Uniform(-2, 2), 5)
  light_color: Uniform((0, 0, 0), (1, 1, 1))
  light_intensity: Uniform(0, 300000)
  light_radius: 1
# warehouse scenario
scenario_model: /NVIDIA/Assets/Isaac/2022.2.0/Isaac/Environments/Simple_Warehouse/warehouse.usd
scenario_class_id: 0
# camera
stereo: True
stereo_baseline: 0.2
camera_coord: (0, 0, Uniform(.20, 1))
camera_rot: (Normal(0, 1), 0, Uniform(0, 360))
# output
output_dir: dataset
num_scenes: 10
img_width: 1920
img_height: 1080
rgb: True
depth: True
semantic_seg: True
bbox_2d_tight: True
groundtruth_visuals: True
groundtruth_stereo: True
# simulate
physics_simulate_time: 2
scene_meters_per_unit: 1
And attempting to run a simulation test fails after checking input parameters and such… full output:
[7.263s] Simulation App Starting
[14.433s] app ready
[14.711s] RTX ready
[15.014s] Simulation App Startup Complete
Parsing and checking input parameterization.
2023-03-06 18:15:00 [18,806ms] [Warning] [carb.flatcache.plugin] UsdRelationship /Render/RenderProduct_Replicator.orderedVars has multiple targets, which is not supported
2023-03-06 18:15:07 [25,115ms] [Error] [omni.graph.core.plugin] /Replicator/SDGPipeline/OgnSampleChoice_01: Assertion raised in compute - Tried to set a value on AttributeData '__resolved_outputs:samples' of type 'token' with incompatible data (Unable to cast Python instance to C++ type (compile in debug mode for details))
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\ogn\python\_impl\nodes\OgnSampleChoice.py", line 115, in compute
    db.outputs.samples = samples
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\ogn\OgnSampleChoiceDatabase.py", line 168, in __setattr__
    super().__setattr__(item, new_value)
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.graph\omni\graph\core\_impl\database.py", line 657, in __setattr__
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/extscache/omni.replicator.core-1.6.4+104.1.wx64.r.cp37\omni\replicator\core\ogn\OgnSampleChoiceDatabase.py", line 143, in samples
    self.samples.value = value_to_set
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.graph\omni\graph\core\_impl\utils.py", line 385, in wrapper_non_const
    return func(self, *args, **kwargs)
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.graph\omni\graph\core\_impl\runtime.py", line 126, in value
    self.helper.set(new_value, on_gpu=self._on_gpu)
  File "C:\Users\joekh\AppData\Local\ov\pkg\isaac_sim-2022.2.0/kit/exts/omni.graph\omni\graph\core\_impl\attribute_values.py", line 115, in set
    self._data.set(new_value, on_gpu=on_gpu)
2023-03-06 18:15:07 [25,143ms] [Warning] [omni.usd] Coding Error (secondary thread): in TrackVariability at line 356 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::TrackVariability : Received unknown prim /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:07 [25,143ms] [Warning] [omni.usd] Coding Error (secondary thread): in TrackVariability at line 356 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::TrackVariability : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:08 [26,221ms] [Warning] [omni.usd] Coding Error: in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:08 [26,221ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:08 [26,223ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:08 [26,224ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:08 [26,225ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:08 [26,226ms] [Warning] [omni.hydra.scene_delegate.plugin] Calling getBypassRenderSkelMeshProcessing for prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_Section1_id2 that has not been populated
2023-03-06 18:15:08 [26,226ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetTransform at line 2671 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractTransform(cachePath, &ctm) '
2023-03-06 18:15:08 [26,226ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:08 [26,226ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetMaterialId at line 3145 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractMaterialId(cachePath, &pathValue) '
2023-03-06 18:15:08 [26,227ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetVisible at line 2760 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractVisible(cachePath, &vis) ' -- </Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0>
2023-03-06 18:15:08 [26,227ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:08 [26,227ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetMeshTopology at line 2145 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractTopology(cachePath, &tmp) '
2023-03-06 18:15:08 [26,227ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:08 [26,228ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetTransform at line 2671 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractTransform(cachePath, &ctm) '
2023-03-06 18:15:08 [26,228ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:08 [26,228ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetMaterialId at line 3145 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractMaterialId(cachePath, &pathValue) '
2023-03-06 18:15:08 [26,228ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetVisible at line 2760 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractVisible(cachePath, &vis) ' -- </Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0>
2023-03-06 18:15:08 [26,229ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:08 [26,229ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetMeshTopology at line 2145 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractTopology(cachePath, &tmp) '
2023-03-06 18:15:08 [26,489ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,489ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,489ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,490ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,490ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,490ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,490ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,491ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,491ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,491ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,493ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,493ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,493ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,493ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,493ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,494ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,494ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,494ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,494ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,494ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,592ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,593ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,593ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,593ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,593ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,594ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,594ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,594ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,594ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,595ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,595ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,596ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,596ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,597ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,597ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,597ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,598ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,598ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,599ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,599ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,601ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,601ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,601ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,602ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,602ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,602ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,602ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,602ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,603ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,603ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,604ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,605ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,606ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,606ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,607ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,607ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,607ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,608ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,608ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,608ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,608ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,609ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,609ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,609ms] [Warning] [rtx.neuraylib.plugin] [MDLC:COMPILER]   1.0   MDLC   comp warn : omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,610ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1203,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,610ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1204,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,610ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1205,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,610ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1206,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,610ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1207,14): C182 unused constant 'b5'
2023-03-06 18:15:08 [26,611ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1214,14): C182 unused constant 'B'
2023-03-06 18:15:08 [26,611ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1215,14): C182 unused constant 'b2'
2023-03-06 18:15:08 [26,611ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1216,14): C182 unused constant 'b3'
2023-03-06 18:15:08 [26,611ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1217,14): C182 unused constant 'b4'
2023-03-06 18:15:08 [26,611ms] [Warning] [rtx.neuraylib.plugin] Compiler Core: omniverse://localhost/NVIDIA/Assets/Machinima/Squad/Props/Weapons/Materials/OmniUe4Function.mdl?watch=00000195433c4f90(1218,14): C182 unused constant 'b5'
2023-03-06 18:15:09 [27,406ms] [Warning] [omni.usd] Coding Error: in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:09 [27,406ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,655ms] [Warning] [omni.usd] Coding Error: in _RemoveDependencies at line 109 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\indexProxy.cpp -- Failed verification: ' primInfo != nullptr ' -- /__Master_2/AK74/Mesh/Section0
2023-03-06 18:15:17 [35,656ms] [Warning] [omni.usd] Coding Error: in _RemoveDependencies at line 109 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\indexProxy.cpp -- Failed verification: ' primInfo != nullptr ' -- /__Master_2/AK74/Mesh/Section1
2023-03-06 18:15:17 [35,657ms] [Warning] [omni.usd] Coding Error: in _RemoveDependencies at line 109 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\indexProxy.cpp -- Failed verification: ' primInfo != nullptr ' -- /__Master_2/AK74/Mesh/Section2
2023-03-06 18:15:17 [35,659ms] [Warning] [omni.usd] Coding Error: in TrackVariability at line 356 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::TrackVariability : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,671ms] [Warning] [omni.usd] Coding Error: in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/AssetCache/pi/Cached0_Prim_pi.proto_AK74_id0
2023-03-06 18:15:17 [35,671ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_0/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,672ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,672ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,673ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,674ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetTransform at line 2671 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractTransform(cachePath, &ctm) '
2023-03-06 18:15:17 [35,674ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,674ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetMaterialId at line 3145 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractMaterialId(cachePath, &pathValue) '
2023-03-06 18:15:17 [35,675ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetVisible at line 2760 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractVisible(cachePath, &vis) ' -- </Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0>
2023-03-06 18:15:17 [35,675ms] [Warning] [omni.usd] Coding Error (secondary thread): in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,675ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetMeshTopology at line 2145 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.ExtractTopology(cachePath, &tmp) '
2023-03-06 18:15:17 [35,855ms] [Warning] [omni.usd] Coding Error (secondary thread): in GetRenderTag at line 2092 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdImaging\delegate.cpp -- Failed verification: ' _valueCache.FindPurpose(cachePath, &purpose) ' -- /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:17 [35,855ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
Module omni.replicator.core.ogn.python._impl.nodes.OgnSemanticSegmentation load on device 'cuda:0' took 2.69 ms
2023-03-06 18:15:18 [36,374ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:18 [36,581ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:18 [36,922ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:19 [37,248ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:19 [37,422ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:19 [37,833ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:20 [38,047ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:20 [38,405ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:22 [40,395ms] [Warning] [omni.usd] Coding Error: in UpdateForTime at line 408 of C:\b\w\ca6c508eae419cf8\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp -- UsdSkelImagingSkeletonAdapter::UpdateForTime : Received unknown prim /Replicator/SampledAssets/Population_cf06cdb6/Ref_Xform_01/Ref.proto_AK74_id0
2023-03-06 18:15:22 [40,793ms] [Warning] [carb] Plugin interface for a client: omni.hydratexture.plugin was already released.
[40.837s] Simulation App Shutting Down
As you can see, all of the prims in the USD are failing to get recognized by the app. Anyone have a similar enouncter with Composer and managed to successfully load and use characters/custom assets for synthetic data generation?
Thanks in advance.
I get the same error, did you find a solution for this problem?
Not yet. I’ve posted in the Omniverse Discord as well but no one has come forward with a solution.
