I am trying to run the new 1.5.3-r2 Replicator container in an EC2 instance, but encounter an error.
I was successful with version1.4.7-r1, but I get an error with version 1.5.3-r2
I’m using a g5 instance that uses the AMI NVIDIA Omniverse GPU-Optimized AMI
I’m following the instructions from here:
docker pull nvcr.io/nvidia/omniverse-replicator:1.5.3-r2
docker run --gpus all --entrypoint /bin/bash -it nvcr.io/nvidia/omniverse-replicator:1.5.3-r2
./cache_script.sh
The following is the returned output after running cache_script.sh
libGLX_nvidia.so.0 (libc6,x86-64) => /usr/lib/x86_64-linux-gnu/libGLX_nvidia.so.0
/opt/nvidia/omniverse/vkapiversion/bin/vkapiversion: error while loading shared libraries: libvulkan.so.1: cannot open shared object file: No such file or directory
result of running nvidia-smi
| NVIDIA-SMI 470.141.03 Driver Version: 470.141.03 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA A10G Off | 00000000:00:1E.0 Off | 0 |
| 0% 21C P0 56W / 300W | 0MiB / 22731MiB | 1% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
1.4.7-r1 works fine btw.
Thank you,
Mark Olson
