When FSD is enabled, replicator returns an empty array.
Windows - Isaac Sim 2023.1.1
Replicator 1.10.20
Reproducing:
- In Isaac Sim enable FSD
import carb.settings as settings
import omni
fabric_enabled = settings.get_settings().get_as_bool("/app/useFabricSceneDelegate")
if not fabric_enabled:
settings.get_settings().set_bool("/app/useFabricSceneDelegate", True)
omni.kit.window.file.new()
print("Fabric Scene Delegate enabled")
- Create a camera and render product and try to get the rgb data
import asyncio
async def run():
rep.settings.set_render_pathtraced(samples_per_pixel=64)
camera = rep.create.camera()
rp = rep.create.render_product(camera, (512, 512))
annotator = rep.AnnotatorRegistry.get_annotator("rgb")
annotator.attach(rp)
await rep.orchestrator.step_async(rt_subframes=1)
out = annotator.get_data(device="cuda")
print(out)
task = asyncio.ensure_future(run())
If FSD is enabled then out is an empty array. Please let me know how to fix this.
There are a few warnings the first time get_data
is called:
2024-05-28 17:41:53 [Info] [omni.kit.app.plugin] Executing file: C:/Users/jreeves/AppData/Local/Temp/2/xxs4.0/script_1716918112.py
2024-05-28 17:41:53 [Info] [omni.kit.app.plugin] Found a script to execute: C:/Users/jreeves/AppData/Local/Temp/2/xxs4.0/script_1716918112.py
2024-05-28 17:41:53 [Warning] [omni.fabric.plugin] Warning: outputs:prims not found
2024-05-28 17:41:53 [Warning] [omni.fabric.plugin] No source has valid data array=0000022295FED378 usdValid=0 cpuValid=0
2024-05-28 17:41:53 [Info] [omni.graph.core.plugin] Resolving /Replicator/SDGPipeline/OgnSampleUniform.outputs:samples to float[3][]
2024-05-28 17:41:53 [Info] [omni.graph.core.plugin] Resolving /Replicator/SDGPipeline/OgnWritePrimAttribute.inputs:values to double[3][]
2024-05-28 17:41:53 [Warning] [omni.fabric.plugin] No source has valid data array=00000230A61ECBF0 usdValid=0 cpuValid=0
2024-05-28 17:41:53 [Info] [omni.usd] [MBVH]: enableHydraengineMasking: OFF, for indexForEngineInstance: 0
2024-05-28 17:41:53 [Info] [omni.usd] [MBVH]: raytracingMotion/enable: OFF, for indexForEngineInstance: 0
2024-05-28 17:41:53 [Info] [omni.replicator.core.scripts.annotators] Attaching rgb to render product(s) ['/Render/RenderProduct_Replicator']
2024-05-28 17:41:53 [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.graph.core.plugin; not changing unload order
2024-05-28 17:41:53 [Info] [omni.replicator.core.scripts.orchestrator] Replicator Step
2024-05-28 17:41:53 [Info] [rtx.multigpumanager.plugin] View 0 (/Render/RenderProduct_omni_kit_widget_viewport_ViewportTexture_0) assigned to device 0
2024-05-28 17:41:53 [Info] [rtx.multigpumanager.plugin] View 0 (/Render/RenderProduct_omni_kit_widget_viewport_ViewportTexture_0) switching to 1x1 layout
2024-05-28 17:41:53 [Info] [rtx.multigpumanager.plugin] View 1 (/Render/RenderProduct_Replicator) assigned to device 0
2024-05-28 17:41:53 [Info] [rtx.multigpumanager.plugin] View 1 (/Render/RenderProduct_Replicator) switching to 1x1 layout
2024-05-28 17:41:53 [Warning] [rtx.raytracing.plugin] Samples per pixel clamped to 32! Set /rtx/pathtracing/clampSpp to override clamp value, or 0 to disable clamping.
2024-05-28 17:41:53 [Info] [omni.kit.menu.utils.scripts.utils] omni.kit.menu.utils.rebuild_menus
2024-05-28 17:41:54 [Warning] [omni.syntheticdata.plugin] SdRenderVarPtr missing valid input renderVar LdrColorSDhost
2024-05-28 17:41:54 [Info] [omni.kit.app._impl] [py stdout]: []
This one in particular may be relevant: [Warning] [omni.syntheticdata.plugin] SdRenderVarPtr missing valid input renderVar LdrColorSDhost
since i’ve been able to trace the empty array all the way back to omni.replicatore.core.scripts.utils.annotator_utils
in AnnotatorCache.get_data
where the dataPtr
is 0.
FSD also seems to affect rendering AOVs from movie capture. If FSD is on, movie capture will not output anything while rendering with the Render Product.
I’ve also tested on Ubuntu and get the same results. Any help would be appreciated.
Bumping. I haven’t had any luck getting this to work on my end.
Hi @josiah7 Unfortunately FSD is not supported with Replicator yet. I ran this by the devs and they were a little surprised to see someone using it. :)
For a little bit of extra info, its a feature that’s needed in omni.syntheticdata. There’s no stage with history in FSD and we have no way of retrieving data from a specific point in time.
Hi @pcallender thanks for checking. Is there a way around using replicator to capture synthetic data perhaps?
Currently looking to use this with Cesium but it looks like FSD could be really useful for large scale scenes and I can can think of a few other uses for it.
