Hi so I have a Gigabyte 4090 with an AMD Ryzen 9950X3d
I’m on Nixos, Kernel 7.1.3 on Plasma 6.7 Wayland. When I try to run Granblue Fantasy Relink/Ragnarok on higher settings, it will freeze with audio playing for a bit and needs to be killed in the system monitor. I get this error in my journal ctl
journalctl -k -b | grep -i xid
Jul 09 21:18:44 ShivumPCLinux kernel: NVRM: Xid (PCI:0000:01:00): 13, pid=24272, name=granblue_fantas, Graphics Exception: channel 0x00000013, Class 0000c9c0, Offset 00000000, Data 00000000
Every time on a specific mission that I can replicate (not only that mission; it’ll happen about anywhere). After enough happens on screen it’ll freeze. This issue isn’t just from the new DLC, I have had this issue for a bit before this release. The issue happens more often on 120 FPS Ultra, but does occur on 60 fps Standard settings
I have tried:
- Drivers 595.80, 595.84, and 610.43.03 which the issue happens on all of them.
- Disabled and enabled GSP firmware
- Kernels 7.1.1 and 7.1.3
- Multiple Proton versions
- Cleared shader cache
Someone had a similar issue here
Here are two logs from me as well after the crash.
nvidia-bug-report.log.gz (659.9 KB)
nvidia-bug-report.log.old.gz (683.9 KB)
I am not really familiar with all of this stuff, a lot of debugging came from sparse google searches and AI, so please be patient with me. Thanks
