Hi all,
Thanks for looking into this.
I’m working on Isaac ROS nvblox evaluation and would like to pull the official container from nvcr.io/isaac/ros.
I was able to docker login nvcr.io successfully using my NGC personal API key (Username: $oauthtoken), so authentication works.
However, pulling the Isaac ROS container still fails with “Access Denied”:
$ docker pull nvcr.io/isaac/ros
Error response from daemon: Head “https://nvcr.io/v2/isaac/ros/manifests/noble-ros2_jazzy”: denied: {“errors”:[{“code”:“DENIED”,“message”:“Access Denied”}]}
This suggests my account can authenticate to nvcr.io, but does not yet have pull permissions for the nvcr.io/isaac/ros registry namespace.
Could you please grant my NGC account access to that namespace?
My NGC account username is nobunana.
Please grant this account access to the nvcr.io/isaac/ros container registry.
Thank you!
