Request access to the NVIDIA NIM API - Kira AI with its own memory architecture (educational/non-profit project)
Dear NVIDIA NIM team,
I’m a solo developer working on an AI assistant called Kira AI — a project focused on long‑term, context‑aware conversation.
Unlike most chatbots that forget everything after a few messages, Kira uses a custom memory layer I built from scratch (not a vector DB wrapper). It dynamically compresses, prioritizes, and recalls user information across sessions, allowing truly persistent and personal interactions.
Right now Kira is in late prototyping stage, and I’m scaling to a small group of beta testers (~20 people). To power the assistant I need access to a reliable, high‑throughput LLM API that can handle:
  • ~15–20 requests per minute per user (bursts up to 30 RPM)
  • Low latency (my memory layer already adds ~150ms overhead, so the model must be fast)
  • Strong reasoning capabilities (the memory system works better with models like Llama 3.3 70B / 405B or similar)
I’ve tested other free APIs (Groq, OpenRouter, Gemini) but they either have tight daily limits, geo‑restrictions, or unstable rate limiting. NVIDIA NIM stands out because of the generous 40 RPM free tier and the availability of large‑context, high‑intelligence models like Llama 3.1 405B and GLM 4.7.
My request:
I would like to obtain an active NIM API key for my NVIDIA Developer account (email: def.med.005@gmail.com). If possible, I’d also appreciate keeping the standard 40 RPM / 1000 RPD limits — that is already more than enough for my beta phase. I do not need higher limits right now, just a stable, non‑expiring access to the free tier.
Why NVIDIA NIM specifically?
  • Your free tier doesn’t require a credit card (I’m a student / independent dev).
  • You offer some of the best open‑weight models with commercial‑friendly licenses.
  • I plan to publish a case study about running Kira on NVIDIA NIM — which could be a nice reference for other developers in the voice / memory‑first AI space.
To be fully transparent:
  • Kira is not a commercial product yet — it’s a research demo and will remain free for testers.
  • I will stay well within the 40 RPM limit (average ~15 RPM).
  • I have already read and accepted the NVIDIA NIM terms of use.
Would you be able to activate NIM access for my account?
I’m happy to share more technical details, a demo video, or even a short write‑up about my memory architecture if that helps.
Thank you for considering Kira AI — and for building one of the most developer‑friendly AI platforms out there.
Best regards,
LAKLY TEAM
Email: def.med.005@gmail.com
phone: +7(
Kazakhstan)
