DRIVE OS Version: 7.0.3
Issue Description: Clarification Needed: binderfs Support on NVIDIA Thor Kernel (Binder IPC Available but binderfs Mount Fails)
Hello NVIDIA team,
I am currently evaluating Android-related IPC mechanisms on a Thor-based platform and need clarification regarding binderfs support in the Thor kernel.
1. Kernel configuration shows binderfs enabled
After building the Thor kernel, I verified that the following configuration options are enabled:
CONFIG_ANDROID_BINDER_IPC=y
CONFIG_ANDROID_BINDERFS=y
CONFIG_ANDROID_BINDER_DEVICES="binder,hwbinder,vndbinder"
CONFIG_USER_NS=y
CONFIG_PID_NS=y
CONFIG_NET_NS=y
CONFIG_UTS_NS=y
CONFIG_TIME_NS=y
CONFIG_IPC_NS=y
The kernel image was successfully built and flashed onto the Thor hardware without errors.
2. Binder IPC works on the running system
Binder driver appears to be available:
cat /proc/filesystems | grep binder
Output:
nodev binder
Binder device nodes also exist on the system:
ls -l /dev | grep binder
This confirms binder IPC is operational.
3. Legacy binder mount works, but binderfs mount fails
When I try to mount binder using the legacy binder filesystem:
sudo mount -t binder binder /dev/binderfs
This succeeds and exposes:
/dev/binderfs/binder
/dev/binderfs/hwbinder
/dev/binderfs/vndbinder
/dev/binderfs/binder-control
/dev/binderfs/features/
However, attempting a binderfs mount fails:
sudo mount -t binderfs binder /dev/binderfs
Result:
mount: /dev/binderfs: unknown filesystem type 'binderfs'.
This seems to indicate that binderfs is not registered as a filesystem type, even though CONFIG_ANDROID_BINDERFS=y is enabled and the kernel was rebuilt and flashed.
4. Question: Is binderfs supported on Thor, or is additional configuration required?
I would like to clarify:
Is binderfs expected to work on Thor-based kernels?
The documentation suggests binderfs should be available whenCONFIG_ANDROID_BINDERFS=y, but the runtime behavior indicates otherwise. -
Is there any additional kernel configuration, patch, or security setting required to enable binderfs registration?
Is binderfs intentionally disabled or restricted on Thor?
(e.g., only mountable in init_user_ns, restricted by LSM, or not exposed in this BSP) -
Could there be any additional steps required during kernel flashing or bootloader configuration to ensure binderfs support is active?
My goal is simply to verify whether binderfs should be available on Thor platforms, and what is required (if anything) to enable it properly.
Any guidance or clarification from the NVIDIA kernel or BSP team would be greatly appreciated.
Thank you!
