Request for IBIS File – NVIDIA SOM 900-13767-0000-000
I require the IBIS file for the NVIDIA SOM (Part No. 900-13767-0000-000) for simulation purposes. Could you please let me know how I can obtain it?
https://www.arrow.com/en/products/900-13767-0000-000/nvidia
The IBIS (Input/Output Buffer Information Specification) file is a crucial component for signal integrity simulation and analysis. Unfortunately, the provided context does not directly mention the availability of IBIS files for NVIDIA SOMs. However, I can provide some guidance on how to obtain the IBIS file for the NVIDIA SOM Part No. 900-13767-0000-000.
  1. NVIDIA Official Website: You can start by visiting the official NVIDIA website and searching for the specific SOM part number (900-13767-0000-000). If the IBIS file is available, it should be listed under the “Downloads” or “Resources” section for that particular product.
  2. NVIDIA Developer Zone: The NVIDIA Developer Zone is a platform that provides resources, including documentation, software, and tools, for developers working with NVIDIA products. You can try searching for the IBIS file on the Developer Zone website.
  3. Arrow Electronics Website: Since you provided a link to the Arrow Electronics website, which lists the NVIDIA SOM Part No. 900-13767-0000-000, you can try contacting their technical support or sales team to inquire about the availability of the IBIS file.
  4. NVIDIA Technical Support: If you are unable to find the IBIS file through the above channels, you can try contacting NVIDIA’s technical support directly. They may be able to provide you with the IBIS file or guide you on how to obtain it.
  5. Third-Party Sources: As a last resort, you can try searching for third-party sources that provide IBIS files for NVIDIA SOMs. However, be cautious when using third-party sources, as the accuracy and reliability of the files may vary.
In comparison, the context does provide information on the product part number format, which includes the module ID and board ID. However, this information is not directly relevant to obtaining the IBIS file.
To summarize, to obtain the IBIS file for the NVIDIA SOM Part No. 900-13767-0000-000, you can try the following:
  • Check the NVIDIA official website and Developer Zone
  • Contact Arrow Electronics technical support or sales team
  • Reach out to NVIDIA technical support
  • Search for third-party sources (with caution)
If you are unable to find the IBIS file through these channels, you may want to consider contacting NVIDIA or Arrow Electronics directly to request the file or inquire about its availability.
Does this help?
https://developer.nvidia.com/embedded/downloads#?search=IBIS&tx=$product,jetson_orin_nx
this one is the simulation application note.i am looking for IBIS file.
That might require talking to a sales rep from NVIDIA, but I am uncertain about that. Maybe @carolyuu knows of a sales rep email address to inquire. NVIDIA is the one who created the carrier board and module for developer kits, tends to support allowing alternate builds of carrier boards, so I would think this is probably something publicly available if the right person can be asked about this, but I do not know for certain.
ok thanks for the info.
Please refer to Jetson Orin NX Series and Jetson Orin Nano Series Signal Integrity Simulation Application Note https://developer.nvidia.com/downloads/jetson-orin-nx-orin-nano-signal-integrity-simulation
Relevant IBIS models and S-parameters are attached in the pdf application note.
