Hello NVIDIA Jetson Support,
I am using a Jetson Xavier AGX 16GB system and would like to confirm whether there is an available JetPack/L4T kernel or package set that includes nftables support via the nf_tables kernel subsystem.
My current system details are:
- Device: NVIDIA Jetson Xavier AGX 16GB (Developer Edition)
- OS / L4T: Linux 5.10.216-tegra
- Architecture: aarch64
- Kernel config check: CONFIG_NF_TABLES is not enabled
- Observed behavior: nftables validation/apply fails with “Operation not supported”
- Current command evidence:
nft -c -f ...failszgrep CONFIG_NF_TABLES /proc/config.gzor equivalent shows it is absentmodprobe nf_tablesfails with “Module nf_tables not found”
I am evaluating this platform for a host-side security appliance / firewall configuration and need a kernel that supports nftables so I can run the required nft ruleset and enforce policy appropriately.
Could you please advise whether there is:
- a supported JetPack/L4T release for this device that includes nf_tables support,
- a compatible kernel package or module set for Jetson Xavier AGX,
- or a recommended rebuild/custom kernel path to enable nftables support on this platform?
If there are any known limitations for this specific Jetson model or board revision, please let me know.
I would also appreciate any guidance on:
- the correct kernel source package for this model,
- whether this support is available in the default JetPack release,
- and the safest procedure to rebuild or update the kernel for nftables compatibility.
Thank you for your time and guidance. I appreciate any information you can share to help confirm the supported path for this device.
