Request for NVIDIA NIM API Rate Limit Increase (40 → 200 RPM)
Hello NVIDIA NIM Team,
I am writing to kindly request a rate limit increase for my NVIDIA NIM API account.
Account Details:
⦁ Registered Email: zihan@mczihan.link
⦁ API Key ID (last 4 chars): 4180b
⦁ Current Limit: 40 RPM
⦁ Requested Limit: 200 RPM
Use Case:
I am an individual developer using NVIDIA NIM for personal learning and building a personal AI agent system. My primary models are:
⦁ z-ai/glm-5.1 — for general reasoning and multi-step task orchestration
⦁ google/gemma-4 — for lightweight tool-calling and quick inference tasks
My agent workflow involves sequential LLM calls — prompt construction, tool selection, result validation, and response generation. A single user interaction can easily trigger 5–8 chained requests, and the current 40 RPM limit is frequently exceeded during normal usage, causing HTTP 429 errors that disrupt the entire agent loop.
Why the Current Limit Is Restrictive:
Even with concurrency disabled and a local token-bucket rate limiter set to ~0.6 req/s, the 40 RPM ceiling is reached within seconds of starting a multi-step agent session. This makes it difficult to test and iterate on agent workflows in any meaningful way.
Commitments:
⦁ This request is strictly for personal, non-commercial development and learning purposes
⦁ I am not running any public-facing service, production workload, or reselling access
⦁ I am not using multiple accounts or key rotation to bypass limits
⦁ I will implement proper exponential-backoff retry logic on 429 errors
An increase to 200 RPM would allow me to develop, test, and iterate on my agent system reliably while staying within reasonable fair-use boundaries.
Thank you for making NVIDIA NIM available to the developer community. I appreciate your consideration.
Best regards,
Zihan
Hey @zihan, I don’t know if this helps, but a moderator previously replied with this to someone asking for the same thing as you:“Many of you are using free tier API access to NVIDIA NIMs. This usually involves a rate limit that is dependent on model, use-case and the amount of current overall traffic using the same access. There is no official way to circumvent this rate limit or to receive a rate limit increase on that same tier. And specifically here on the forums we do not have any influence on those rate limits. To make full use of a NIM blueprint you will need to deploy it. For more details on NVIDIA NIM refer to…”
Basically, this means that if you are using the free-tier API, you have absolutely no right to demand an RPM increase. The only way to legitimately request higher RPM limits is:
Not through the forum. Moderators have said it over and over again: the forum is not the place to request RPM increases, as there are other channels and processes for that.
You need to pay and deploy a model through NVIDIA NIM / NVIDIA Build if you require higher usage limits and production-level access.
First, go to the model you prefer, for example DeepSeek V4 Flash. In that section you’ll see three options: Experience / Model Card / Deploy.
Click on Deploy and you’ll see several options such as Partner Endpoints or Self-hosted Deployments.
From there, you choose the option you want, and it will show you the pricing and deployment costs.
You can start with DeepSeek Flash since it’s the cheapest one, so you can learn how the process works first. And if you need help, you can always contact a moderator privately and ask for guidance. There’s no problem with sending a direct message saying you want to pay and deploy properly.
I am not saying this to be toxic, rude, or disrespectful. My goal is simply to help you understand and follow NVIDIA’s rules and the guidance that has already been provided by moderators multiple times.
IF YOU ARE ALREADY PAYING FOR NVIDIA SERVICES AND DEPLOYED MODELS, THEN YOU SHOULD CONTACT NVIDIA DIRECTLY THROUGH THE APPROPRIATE SUPPORT CHANNELS, SUCH AS EMAIL OR PRIVATE COMMUNICATION WITH THE RELEVANT SUPPORT TEAM, RATHER THAN MAKING RPM INCREASE REQUESTS ON THE FORUM.
Hi @VMMS1245, thanks for sharing that information — the pointer to the Deploy flow and paid options is genuinely helpful, and I appreciate you taking the time to explain it.
Just a small clarification: I was requesting, not demanding. I understand the free tier has its limits, and I fully respect NVIDIA’s policies. Posting here was simply following the pattern I saw from other community members — if there’s a more appropriate channel for this kind of request, I’m happy to use it instead.
I’ll look into the self-hosted deployment path you mentioned. Thanks again!
Just to chime in and in hope that Search engines and AI tools finally pick this up.
There is not a single post where any moderator wrote anything about granting an increased rate limit. The only patterns are requests. Nothing granted.
Noted, @MarkusHoHo. I hear you — the forum isn’t the right place, and I won’t push it further here. Thanks for the clarity and for the pointer toward proper deployment channels. I’ll explore those instead.
