Request for official R35.6.0 UEFI fix for AGX Xavier A/B slot switching failure
Hi NVIDIA Team,
We have multiple Jetson AGX Xavier production devices running Jetson Linux R35.6.0 with ROOTFS A/B enabled.
Affected devices show:
bios_version : 6.0-37391689
bios_date    : 08/28/2024
VarErrorFlag : 0xEF
After this occurs, nvbootctrl set-active-boot-slot does not persist across reboot. nvbootctrl set-SR-BR can only switch the slot for one warm reboot.
Related reports and fix:
Could NVIDIA please clarify the following?
  1. Could NVIDIA provide an officially built and validated R35.6.0 UEFI binary or capsule containing the c101ba5 fix, based on the same source, configuration, toolchain, and signing process as firmware 6.0-37391689?
    We would prefer an official binary rather than building and validating a custom UEFI ourselves. Please also provide the supported installation method for existing production devices.
  2. Which exact public UEFI source revision and complete NVIDIA-Platforms manifest correspond to firmware 6.0-37391689? Is it the NVIDIA-Platforms r35.6.0 combo and edk2-nvidia commit 78a917e?
  3. Which official Jetson Linux/JetPack release first includes the c101ba5 fix in its prebuilt UEFI binary for AGX Xavier? Is it included in any R35.6.x release?
  4. If we must build it ourselves, should we use the complete NVIDIA-Platforms r35.6.0 combo and apply only c101ba5? Please provide the officially supported build, signing and deployment procedure, including whether only uefi_jetson.bin must be updated or whether OP-TEE, TOS, StandaloneMm, MB2 or other bootloader components must also be updated.
  5. What is NVIDIA’s supported recovery procedure for devices already showing VarErrorFlag=0xEF, especially when USB Force Recovery is unavailable? After installing the patched UEFI, can it recover an already-full variable store, or must the 128 KiB uefi_variables partition be cleared separately?
Thank you.
hello shuang.cao,
unfortunately, you should rebuild UEFI since this change has not included in any JP-5.x public releases yet.
you may refer to Release edk2-nvidia-202210.8 · NVIDIA/edk2-nvidia · GitHub which should have c101ba5 fix included.
This issue looks serious. Haven’t you merged them? It seems all users are experiencing the inability to OTA updates.
  1. Which exact public UEFI source revision and complete NVIDIA-Platforms manifest correspond to firmware 6.0-37391689? Is it the NVIDIA-Platforms r35.6.0 combo and edk2-nvidia commit 78a917e?
  2. Which official Jetson Linux/JetPack release first includes the c101ba5 fix in its prebuilt UEFI binary for AGX Xavier? Is it included in any R35.6.x release?
  3. If we must build it ourselves, should we use the complete NVIDIA-Platforms r35.6.0 combo and apply only c101ba5? Please provide the officially supported build, signing and deployment procedure, including whether only uefi_jetson.bin must be updated or whether OP-TEE, TOS, StandaloneMm, MB2 or other bootloader components must also be updated.
  4. What is NVIDIA’s supported recovery procedure for devices already showing VarErrorFlag=0xEF, especially when USB Force Recovery is unavailable? After installing the patched UEFI, can it recover an already-full variable store, or must the 128 KiB uefi_variables partition be cleared separately?
Can you answer the questions posed above?
hello shuang.cao,
please see-also developer guide, UEFI Adaptation.
check below for Q&As.
>> Q1.
we do not have an official rebuilt R35.6.0 UEFI binary/capsule with c101ba5 available for download. please rebuild UEFI from source if you need this fix on R35.6.0.
>> Q2.
for R35.6.0, please use NVIDIA-Platforms r35.6.0. It pins edk2-nvidia tag r35.6.0, which is commit 78a917ecc3639c84097a180dedd33ad8482c6fb5
the fix commit is c101ba515b2737fb78d8929c2852f5c8f9607330 on top of that code line
>> Q3.
since this fix is not included in the public JP5.x/R35.6.x prebuilt UEFI binaries. the fix is available in the public UEFI source through r35.6.0-updates, and also in the later uefi-202210.8 UEFI source release.
for the smallest R35.6.0 delta, use the matching R35.6.0 UEFI source and apply c101ba5, or use the r35.6.0-updates combo which already contains it. this commit only changes the UEFI FVB/FTW write path, so the fix itself is in UEFI.
for deployment, replace the built uefi_Jetson_RELEASE.bin as Linux_for_Tegra/bootloader/uefi_jetson.bin, then generate and deploy a normal t19x bootloader BUP/capsule using the R35.6.0 BSP tools.
for production capsule update, please use your own production signing certificates, not the test certificates.
>> Q4.
for devices already showing VarErrorFlag=0xEF, the patched UEFI prevents the issue after it is installed, but it may not be possible to install it through the normal capsule path because triggering capsule update also requires writable UEFI variables. The supported recovery path is Force recovery/reflash, or an equivalent service procedure that can rewrite the boot firmware/UEFI variable storage offline. We do not recommend manually clearing the uefi_variables partition on production devices unless you have validated the full recovery flow, because it resets persistent UEFI state.
Hello JerryChang,
I am a colleague of Shuang Cao, and I will be primarily responsible for following up on this issue going forward. I still have a few questions I would like to consult with you:
  1. Why did your company decide not to include the UEFI binary file that fixes this issue in subsequent R35.6.x SDKs? Having it included would make it easier for us to obtain the firmware with the fixed version.
  2. I noticed that the serial log from our current version of the UEFI firmware contains a timestamp log that says “built on 2024-08-28.” However, the submission date for version 78a917ecc3639c84097a180dedd33ad8482c6fb5 in the R35.6.0-updates source code is “Sep 18 12:06:14 2024,” which seems inconsistent. We need to know which specific commit corresponds to our current UEFI firmware. If we merge changes unrelated to this issue, we are concerned about introducing other new problems.
just as FYI, JetPack 5 upcoming End-of-Life notice
