Request help with orin Nano backup and recovery issues
Platform of use
PC:Ubuntu20.04
Jetson™ Linux version 36.3 GA
jatPcak6.0
Reference Example Source “/Linux_for_Tegra/tools/backup_restore/README_backup_restore.txt”
I did the following:
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -b jetson-orin-nano-devkit
After executing the command, the production file is shown below
Restore operation:
sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-orin-nano-devkit
The final result is fixed in the boot EFI, as shown below:
zynq@ubuntu:~/nvidia/Linux_for_Tegra$ sudo ./tools/backup_restore/l4t_backup_restore.sh -e nvme0n1 -r jetson-orin-nano-devkit
/home/zynq/nvidia/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --no-flash --initrd --showlogs jetson-orin-nano-devkit internal
*  Step 1: Generate rcm boot commandline *
ROOTFS_AB= ROOTFS_ENC= /home/zynq/nvidia/Linux_for_Tegra/flash.sh  --no-flash --rcm-boot jetson-orin-nano-devkit mmcblk0p1
# L4T BSP Information:
# R36 , REVISION: 3.0
# User release: 0.0
ECID is 0x80012344705DD50C6C00000001FE8140
Existing emcfuse(/home/zynq/nvidia/Linux_for_Tegra/bootloader/fuse_t234.xml) reused.
copying emc_fuse_dev_params(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip "0x23" --applet "/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "readfuses fuse_t234.bin fuse_t234.xml; dump eeprom cvm cvm.bin; dump try_custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0194 ] Reading fuses
[   0.0206 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.0215 ] File rcm_state open failed
[   0.0218 ] ERROR: failed to read rcm_state
[   0.0218 ]
[   0.0225 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0227 ] Assuming zero filled SBK key
[   0.0222 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.0291 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.0376 ] Parsing partition layout
[   0.0389 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0404 ] Kernel DTB used: None
[   0.0404 ] WARNING: dce base dtb is not provided
[   0.0404 ] Parsing partition layout
[   0.0414 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[   0.0430 ] Creating list of images to be signed
[   0.0440 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[   0.0450 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0459 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0463 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   0.0566 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   0.0578 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0639 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0643 ] adding BCH for mb2_t234_aligned.bin
[   0.0672 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   0.0814 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   0.0822 ] adding BCH for mb2_t234_aligned.bin
[   0.1015 ] Filling MB1 storage info
[   0.1015 ] Parsing dev params for multi chains
[   0.1084 ] Generating br-bct
[   0.1092 ] Updating dev and MSS params in BR BCT
[   0.1093 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1108 ] Updating bl info
[   0.1118 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[   0.1129 ] WARNING: boot chain is not completed. set to 0
[   0.1137 ] Generating signatures
[   0.1144 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1145 ] Assuming zero filled SBK key
[   0.1347 ] Warning: pub_key.key is not found
[   0.1343 ] Parsing dev params for multi chains
[   0.1343 ] Generating br-bct
[   0.1352 ] Updating dev and MSS params in BR BCT
[   0.1353 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   0.1363 ] Updating bl info
[   0.1372 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.1382 ] WARNING: boot chain is not completed. set to 0
[   0.1394 ] Generating SHA2 Hash
[   0.1414 ] Sha saved in br_bct_BR.sha
[   0.1409 ] Get Signed section of bct
[   0.1419 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   0.1431 ] Signing BCT
[   0.1437 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1439 ] Assuming zero filled SBK key
[   0.1463 ] Sha saved in br_bct_BR.sha
[   0.1466 ] Warning: pub_key.key is not found
[   0.1460 ] Updating BCT with signature
[   0.1467 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   0.1473 ] Offset :4608 Len :3584
[   0.1477 ] Generating SHA2 Hash
[   0.1484 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   0.1485 ] Assuming zero filled SBK key
[   0.1511 ] Sha saved in br_bct_BR.sha
[   0.1507 ] Updating BCT with SHA2 Hash
[   0.1514 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   0.1523 ] Offset :4608 Len :3584
[   0.1524 ] Offset :68 Len :8124
[   0.1536 ] Generating coldboot mb1-bct
[   0.1547 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1556 ] MB1-BCT version: 0.13
[   0.1569 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1571 ] Added Platform Config 9 data with size :- 100
[   0.1572 ]
[   0.1572 ] Updating mb1-bct with firmware information
[   0.1580 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1602 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   0.1609 ] Generating SHA2 Hash for mb1bct
[   0.1628 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   0.1639 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   0.1640 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   0.1646 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   0.1659 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1661 ] Assuming zero filled SBK key
[   0.1676 ] Warning: pub_key.key is not found
[   0.1679 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1696 ] Generating recovery mb1-bct
[   0.1703 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1709 ] MB1-BCT version: 0.13
[   0.1721 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   0.1723 ] Added Platform Config 9 data with size :- 100
[   0.1723 ]
[   0.1723 ] Updating mb1-bct with firmware information
[   0.1733 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[   0.1760 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   0.1769 ] Generating SHA2 Hash for mb1bct
[   0.1788 ] Sha saved in mb1_bct_MB1_aligned.sha
[   0.1799 ] Sha saved in mb1_bct_MB1.sha
[   0.1801 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   0.1807 ] adding BCH for mb1_bct_MB1_aligned.bct
[   0.1821 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.1823 ] Assuming zero filled SBK key
[   0.1837 ] Warning: pub_key.key is not found
[   0.1838 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   0.1863 ] Info: Skip generating mem_bct because sdram_config is not defined
[   0.1863 ] Copying signatures
[   0.1873 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[   0.2012 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2013 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[   0.2014 ] Boot Rom communication
[   0.2023 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.2029 ] BR_CID: 0x80012344705DD50C6C00000001FE8140
[   0.3228 ] Sending bct_br
[   0.4304 ] Sending mb1
[   0.4310 ] Sending psc_bl1
[   0.4678 ] Sending bct_mb1
[   0.4863 ] Boot Rom communication completed
[   0.4880 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   0.4900 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[   0.4909 ] adding BCH for applet_t234_aligned.bin
[   0.5017 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   0.5019 ] Assuming zero filled SBK key
[   0.5043 ] Warning: pub_key.key is not found
[   0.5048 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   0.5123 ] Sending mb2_applet...
[   0.5133 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[   0.5144 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.7146 ] Sending applet
[   0.8831 ] completed
[   0.8845 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   0.8854 ] MB2 Applet version 01.00.0000
[   1.1293 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   1.1304 ] MB2 Applet version 01.00.0000
[   1.2797 ] Parsing fuse info as per xml file
[   1.2811 ] tegraparser_v2 --chip 0x23 0 --get_fuse_names fuse_t234.xml read_fuse_names.txt
[   1.2820 ] MagicId=0x45535546 version=0x2
[   1.2823 ] trying to read fuse with MB2 Applet
[   1.2832 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PublicKeyHash read_fuse.bin
[   1.2845 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.2851 ] MB2 Applet version 01.00.0000
[   1.5718 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.6240 ] Fuse read successful
[   1.6530 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash1 read_fuse.bin
[   1.6556 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   1.6564 ] MB2 Applet version 01.00.0000
[   1.9343 ] Saved read fuses in file __fuse_read_scatter.bin
[   1.9852 ] Fuse read successful
[   2.0146 ] tegraparser_v2 --chip 0x23 0 --read_fusetype PkcPubkeyHash2 read_fuse.bin
[   2.0167 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.0174 ] MB2 Applet version 01.00.0000
[   2.2979 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.3492 ] Fuse read successful
[   2.3772 ] tegraparser_v2 --chip 0x23 0 --read_fusetype BootSecurityInfo read_fuse.bin
[   2.3797 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.3807 ] MB2 Applet version 01.00.0000
[   2.6622 ] Saved read fuses in file __fuse_read_scatter.bin
[   2.7134 ] Fuse read successful
[   2.7426 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ArmJtagDisable read_fuse.bin
[   2.7448 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   2.7462 ] MB2 Applet version 01.00.0000
[   3.0256 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.0779 ] Fuse read successful
[   3.1064 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SecurityMode read_fuse.bin
[   3.1084 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.1094 ] MB2 Applet version 01.00.0000
[   3.3909 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.4401 ] Fuse read successful
[   3.4672 ] tegraparser_v2 --chip 0x23 0 --read_fusetype SwReserved read_fuse.bin
[   3.4694 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.4702 ] MB2 Applet version 01.00.0000
[   3.7530 ] Saved read fuses in file __fuse_read_scatter.bin
[   3.8033 ] Fuse read successful
[   3.8314 ] tegraparser_v2 --chip 0x23 0 --read_fusetype DebugAuthentication read_fuse.bin
[   3.8336 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   3.8345 ] MB2 Applet version 01.00.0000
[   4.1144 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.1637 ] Fuse read successful
[   4.1917 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmInfo read_fuse.bin
[   4.1938 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.1947 ] MB2 Applet version 01.00.0000
[   4.4727 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.5249 ] Fuse read successful
[   4.5531 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmId read_fuse.bin
[   4.5554 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.5561 ] MB2 Applet version 01.00.0000
[   4.8321 ] Saved read fuses in file __fuse_read_scatter.bin
[   4.8833 ] Fuse read successful
[   4.9115 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OdmLock read_fuse.bin
[   4.9139 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   4.9149 ] MB2 Applet version 01.00.0000
[   5.1924 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.2437 ] Fuse read successful
[   5.2727 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm0 read_fuse.bin
[   5.2749 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.2757 ] MB2 Applet version 01.00.0000
[   5.5577 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.6080 ] Fuse read successful
[   5.6361 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm1 read_fuse.bin
[   5.6381 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.6391 ] MB2 Applet version 01.00.0000
[   5.9161 ] Saved read fuses in file __fuse_read_scatter.bin
[   5.9684 ] Fuse read successful
[   5.9969 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm2 read_fuse.bin
[   5.9992 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   5.9999 ] MB2 Applet version 01.00.0000
[   6.2723 ] Saved read fuses in file __fuse_read_scatter.bin
[   6.3227 ] Fuse read successful
[   6.3518 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm3 read_fuse.bin
[   6.3539 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   6.3549 ] MB2 Applet version 01.00.0000
[   6.6447 ] Saved read fuses in file __fuse_read_scatter.bin
[   6.6950 ] Fuse read successful
[   6.7237 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm4 read_fuse.bin
[   6.7258 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   6.7268 ] MB2 Applet version 01.00.0000
[   7.0061 ] Saved read fuses in file __fuse_read_scatter.bin
[   7.0553 ] Fuse read successful
[   7.0833 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm5 read_fuse.bin
[   7.0857 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   7.0866 ] MB2 Applet version 01.00.0000
[   7.3643 ] Saved read fuses in file __fuse_read_scatter.bin
[   7.4155 ] Fuse read successful
[   7.4437 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm6 read_fuse.bin
[   7.4458 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   7.4468 ] MB2 Applet version 01.00.0000
[   7.7267 ] Saved read fuses in file __fuse_read_scatter.bin
[   7.7781 ] Fuse read successful
[   7.8071 ] tegraparser_v2 --chip 0x23 0 --read_fusetype ReservedOdm7 read_fuse.bin
[   7.8099 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   7.8109 ] MB2 Applet version 01.00.0000
[   8.0902 ] Saved read fuses in file __fuse_read_scatter.bin
[   8.1372 ] Fuse read successful
[   8.1665 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Sku read_fuse.bin
[   8.1687 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   8.1693 ] MB2 Applet version 01.00.0000
[   8.4498 ] Saved read fuses in file __fuse_read_scatter.bin
[   8.5007 ] Fuse read successful
[   8.5295 ] tegraparser_v2 --chip 0x23 0 --read_fusetype Uid read_fuse.bin
[   8.5319 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   8.5329 ] MB2 Applet version 01.00.0000
[   8.8107 ] Saved read fuses in file __fuse_read_scatter.bin
[   8.8598 ] Fuse read successful
[   8.8877 ] tegraparser_v2 --chip 0x23 0 --read_fusetype OptEmcDisable read_fuse.bin
[   8.8892 ] tegrarcm_v2 --oem readfuses __fuse_read_scatter.bin read_fuse.bin
[   8.8898 ] MB2 Applet version 01.00.0000
[   9.1681 ] Saved read fuses in file __fuse_read_scatter.bin
[   9.2194 ] Fuse read successful
[   9.2478 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   9.2488 ] MB2 Applet version 01.00.0000
[   9.4176 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[   9.4187 ] MB2 Applet version 01.00.0000
[   9.5921 ] Retrieving board information
[   9.5931 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[   9.5941 ] MB2 Applet version 01.00.0000
[   9.7666 ] Saved platform info in chip_info.bin
[   9.8077 ] Chip minor revision: 1
[   9.8079 ] Bootrom revision: 0x7
[   9.8080 ] Ram code: 0x4
[   9.8081 ] Chip sku: 0xd6
[   9.8082 ] Chip Sample: prod
[   9.8359 ] Retrieving EEPROM data
[   9.8360 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/zynq/nvidia/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[   9.8371 ] MB2 Applet version 01.00.0000
[  10.0058 ] Saved platform info in /home/zynq/nvidia/Linux_for_Tegra/bootloader/cvm.bin
[  10.1122 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.1132 ] MB2 Applet version 01.00.0000
[  10.2813 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.2823 ] MB2 Applet version 01.00.0000
[  10.4582 ] Dumping customer Info
[  10.4592 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[  10.4599 ] MB2 Applet version 01.00.0000
[  10.6304 ] Saved bct in tmp.bct
[  10.7151 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/zynq/nvidia/Linux_for_Tegra/bootloader/custinfo_out.bin
[  10.7160 ] C[  10.7166 ] ustomer data saved in /home/zynq/nvidia/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[  10.7166 ] Rebooting to recovery mode
[  10.7178 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[  10.8910 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[  10.8919 ] MB2 Applet version 01.00.0000
[  11.0618 ] Booting to recovery mode
[  11.0631 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[  11.0638 ] MB2 Applet version 01.00.0000
Board ID(3767) version(300) sku(0004) revision(S.1)
Chip SKU(00:00:00:D6) ramcode(00:00:00:04) fuselevel(fuselevel_production) board_FAB(300)
emc_opt_disable_fuse:(0)
Copy /home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0004-nv.dtb to /home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0004-nv.dtb.rec
copying bctfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0004-sdram-l4t.dts)... done.
copying minratchet_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-p3767-0004-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/zynq/nvidia/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/zynq/nvidia/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing tscfwfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/tsec_t234.bin) reused.
Existing mb2applet(/home/zynq/nvidia/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/zynq/nvidia/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
/home/zynq/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp /home/zynq/nvidia/Linux_for_Tegra/bootloader /home/zynq/nvidia/Linux_for_Tegra
53899 块
gzip: /home/zynq/nvidia/Linux_for_Tegra/kernel/Image: not in gzip format
_BASE_KERNEL_VERSION=5.15.136-tegra
cp: 无法获取'/home/zynq/nvidia/Linux_for_Tegra/rootfs/usr/bin/busybox' 的文件状态(stat): 没有那个文件或目录
warning: cp -f /home/zynq/nvidia/Linux_for_Tegra/rootfs/usr/bin/busybox /home/zynq/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/busybox
cp: 无法获取'/home/zynq/nvidia/Linux_for_Tegra/rootfs/usr/sbin/sgdisk' 的文件状态(stat): 没有那个文件或目录
warning: cp -f /home/zynq/nvidia/Linux_for_Tegra/rootfs/usr/sbin/sgdisk /home/zynq/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp//bin/sgdisk
cp: 无法获取'/home/zynq/nvidia/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libpopt.so.0' 的文件状态(stat): 没有那个文件或目录
warning: cp -f /home/zynq/nvidia/Linux_for_Tegra/rootfs/usr/lib/aarch64-linux-gnu/libpopt.so.0 /home/zynq/nvidia/Linux_for_Tegra/bootloader/ramdisk_tmp//lib/aarch64-linux-gnu/libpopt.so.0
75110 块
Making Recovery image...
copying recdtbfile(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0004-nv.dtb.rec)... done.
记录了20+0 的读入
记录了20+0 的写出
20字节已复制,0.000216793 s,92.3 kB/s
Existing sosfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing pvafile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/nvpva_020.fw) reused.
Existing dcefile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/zynq/nvidia/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/zynq/nvidia/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/bpmp_t234-TE950M-A1_prod.bin) reused.
copying bpfdtbfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/tegra234-bpmp-3767-0004-3509-a02.dtb)... done.
Existing camerafw(/home/zynq/nvidia/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/zynq/nvidia/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0004-nv.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
记录了131072+0 的读入
记录了131072+0 的写出
67108864字节(67 MB,64 MiB)已复制,0.416879 s,161 MB/s
	Sync'ing esp.img ... done.
copying tbcdtbfile(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0004-nv.dtb)... done.
copying cfgfile(/home/zynq/nvidia/Linux_for_Tegra/bootloader/generic/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/home/zynq/nvidia/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-carveouts.dtbo)... done.
copying overlay_dtb(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra-optee.dtbo)... done.
copying overlay_dtb(/home/zynq/nvidia/Linux_for_Tegra/kernel/dtb/tegra234-p3768-0000+p3767-0000-dynamic.dtbo)... done.
/home/zynq/nvidia/Linux_for_Tegra/bootloader/L4TConfiguration_updated.dts: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
/home/zynq/nvidia/Linux_for_Tegra/bootloader/L4TConfiguration.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-8,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo, --bldtb tegra234-p3768-0000+p3767-0004-nv.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip "0x23" --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0004-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; tsec_fw tsec_t234.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; pva_fw nvpva_020.fw; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE950M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0004-3509-a02.dtb; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0004-nv.dtb" --sdram_config tegra234-p3767-0004-sdram-l4t.dts --cust_info custinfo_out.bin --bct_backup --boot_chain A
version 1.0.0
[   0.0208 ] tegrasign_v3.py --key None --getmode mode.txt
[   0.0210 ] Assuming zero filled SBK key
[   0.0205 ] Parsing partition layout
[   0.0216 ] tegraparser_v2 --pt flash.xml.tmp
[   0.0267 ] Change tegra234-bpmp-3767-0004-3509-a02.dtb to tegra234-bpmp-3767-0004-3509-a02_with_odm.dtb
[   0.0268 ] Change tegra234-bpmp-3767-0004-3509-a02.dtb to tegra234-bpmp-3767-0004-3509-a02_with_odm.dtb
[   0.0620 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0004-3509-a02_with_odm.dtb tegra234-bpmp-3767-0004-3509-a02_with_odm_tmp.dtb
[   0.2863 ] Concatenating L4TConfiguration.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo,tegra234-p3768-0000+p3767-0000-dynamic.dtbo to tegra234-p3768-0000+p3767-0004-nv_with_odm_overlay.dtb.updated
[   0.2865 ] Concatenating bl dtb to cpubl binary
[   0.2905 ] MB2 binary: mb2_t234.bin
[   0.2905 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[   0.3011 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[   0.5170 ] Generating coldboot mb2-bct
[   0.5170 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   0.5178 ] ERROR: value 0x31 is out of range
[   0.5187 ] ERROR: value 0x31 is out of range
[   0.5189 ] ERROR: value 0x31 is out of range
[   0.5190 ] ERROR: value 0x31 is out of range
[   0.5192 ] WARNING: unknown property 'tfc_version'
[   0.5194 ] WARNING: unknown property 'addr_header_version'
[   0.5271 ] Updating mb2-bct with storage information
[   0.5279 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   0.5295 ] Concatenating mb2-bct to mb2 binary
[   0.5295 ] mb2_bin_file = mb2_t234.bin
[   0.5295 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[   0.5338 ] DCE binary: display-t234-dce.bin
[   0.5338 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0004-nv.dtb
[   0.5338 ] Concatenating kernel-dtb to dce-fw binary
[   0.5339 ] dce_bin = display-t234-dce.bin
[   0.5339 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0004-nv.dtb
[   0.5339 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv.bin
[   0.5454 ] Update display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv.bin to dce_fw partitions
[   0.5488 ] Parsing partition layout
[   0.5505 ] tegraparser_v2 --pt flash.xml.tmp
[   0.5522 ] Creating list of images to be signed
[   0.5535 ] Generating ratchet blob
[   0.5536 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[   0.5597 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[   0.5656 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[   0.5708 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[   0.5771 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[   0.5867 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[   0.5980 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[   0.6046 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[   0.6112 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[   0.6166 ] Pre-processing config: tegra234-p3767-0004-sdram-l4t.dts
[   1.8109 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[   1.8173 ] Pre-processing config: tegra234-p3767-0004-wb0sdram-l4t.dts
[   2.9755 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[   2.9814 ] Generating coldboot mb1-bct
[   2.9821 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   2.9830 ] MB1-BCT version: 0.13
[   2.9840 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   2.9845 ] Added Platform Config 0 data with size :- 2416
[   2.9859 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   2.9861 ] WARNING: unknown node 'g2'
[   2.9862 ] WARNING: unknown node 'g2'
[   2.9862 ] WARNING: unknown node 'g9'
[   2.9862 ] Added Platform Config 2 data with size :- 24
[   2.9862 ]
[   2.9862 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   2.9862 ] Added Platform Config 4 data with size :- 288
[   2.9862 ]
[   2.9862 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   2.9862 ] Added Platform Config 3 data with size :- 52
[   2.9862 ]
[   2.9862 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   2.9862 ] WARNING: unknown property 'major'
[   2.9862 ] WARNING: unknown property 'minor'
[   2.9862 ] Added Platform Config 5 data with size :- 512
[   2.9862 ]
[   2.9862 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   2.9862 ] Added Platform Config 7 data with size :- 380
[   2.9862 ]
[   2.9863 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   2.9863 ] Added Platform Config 8 data with size :- 24
[   2.9863 ]
[   2.9863 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   2.9863 ] Added Platform Config 9 data with size :- 100
[   2.9863 ]
[   2.9863 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   2.9863 ] ModuleCount 0 NumProdNames 0
[   2.9863 ] Added Platform Config 6 data with size :- 16
[   2.9863 ]
[   2.9863 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   2.9863 ]
[   2.9864 ] Updating mb1-bct with firmware information
[   2.9875 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   2.9900 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   2.9908 ] Generating SHA2 Hash for mb1bct
[   2.9927 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   2.9940 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   2.9942 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   2.9949 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   2.9964 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   2.9966 ] Assuming zero filled SBK key
[   2.9986 ] Warning: pub_key.key is not found
[   2.9994 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   3.0013 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   3.0023 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.0033 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.0038 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.0120 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.0124 ] Header already present for tsec_t234_aligned.bin
[   3.0154 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.0188 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.0247 ] adding BCH for xusb_t234_prod_aligned.bin
[   3.0399 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   3.0468 ] adding BCH for tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned.dtb
[   3.0658 ] Header already present for pscfw_t234_prod_aligned.bin
[   3.0727 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   3.0781 ] Header already present for sc7_t234_prod.bin
[   3.0815 ] Header already present for psc_rf_t234_prod_aligned.bin
[   3.0846 ] adding BCH for mb2rf_t234_aligned.bin
[   3.0868 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   3.1682 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   3.1727 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   3.2320 ] adding BCH for tos-optee_t234_aligned.img
[   3.2910 ] adding BCH for eks_t234_aligned.img
[   3.3430 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin
[   3.5571 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin, ratio = 6%
[   3.5761 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned_blob_w_bin_aligned.bin
[   3.5936 ] adding BCH for spe_t234_aligned.bin
[   3.6061 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   3.6152 ] adding BCH for adsp-fw_aligned.bin
[   3.6308 ] INFO: compressing nvpva_020_aligned.fw
[   3.6805 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   3.6832 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   3.6848 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[   3.6901 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[   3.6913 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[   3.6978 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[   3.6984 ] Header already present for tsec_t234_aligned.bin
[   3.7023 ] Header already present for nvdec_t234_prod_aligned.fw
[   3.7075 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[   3.7159 ] adding BCH for xusb_t234_prod_aligned.bin
[   3.7329 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   3.7443 ] adding BCH for tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned.dtb
[   3.7689 ] Header already present for pscfw_t234_prod_aligned.bin
[   3.7780 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   3.7852 ] Header already present for sc7_t234_prod.bin
[   3.7891 ] Header already present for psc_rf_t234_prod_aligned.bin
[   3.7939 ] adding BCH for mb2rf_t234_aligned.bin
[   3.7971 ] INFO: compressing uefi_jetson_with_dtb_aligned.bin
[   3.8742 ] INFO: complete compression, uefi_jetson_with_dtb_aligned.bin, ratio = 91%
[   3.8787 ] adding BCH for uefi_jetson_with_dtb_aligned_blob_w_bin_aligned.bin
[   3.9618 ] adding BCH for tos-optee_t234_aligned.img
[   4.0364 ] adding BCH for eks_t234_aligned.img
[   4.0968 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin
[   4.3483 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin, ratio = 6%
[   4.3675 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned_blob_w_bin_aligned.bin
[   4.3932 ] adding BCH for spe_t234_aligned.bin
[   4.4097 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   4.4216 ] adding BCH for adsp-fw_aligned.bin
[   4.4401 ] INFO: compressing nvpva_020_aligned.fw
[   4.5037 ] INFO: complete compression, nvpva_020_aligned.fw, ratio = 2%
[   4.5066 ] adding BCH for nvpva_020_aligned_blob_w_bin_aligned.fw
[   4.5105 ] Filling MB1 storage info
[   4.5105 ] Parsing dev params for multi chains
[   4.5170 ] Generating br-bct
[   4.5181 ] Updating dev and MSS params in BR BCT
[   4.5182 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0004-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.5988 ] Updating bl info
[   4.6002 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.6080 ] Generating br-bct
[   4.6089 ] Updating dev and MSS params in BR BCT
[   4.6089 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0004-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   4.6879 ] Updating bl info
[   4.6893 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[   4.6980 ] Generating BCT backup image
[   4.6981 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   4.6993 ] 记录了32768+0 的读入
[   4.7370 ] 记录了32768+0 的写出
[   4.7371 ] 32768字节(33 kB,32 KiB)已复制,0.0371181 s,883 kB/s
[   4.7371 ]
[   4.7372 ] Concatenating BCT for chain A to bct_backup.img
[   4.7372 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   4.7385 ] 记录了8192+0 的读入
[   4.7445 ] 记录了8192+0 的写出
[   4.7445 ] 8192字节(8.2 kB,8.0 KiB)已复制,0.00562449 s,1.5 MB/s
[   4.7445 ]
[   4.7446 ] Concatenating BCT for chain B to bct_backup.img
[   4.7446 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   4.7457 ] 记录了8192+0 的读入
[   4.7520 ] 记录了8192+0 的写出
[   4.7520 ] 8192字节(8.2 kB,8.0 KiB)已复制,0.00589105 s,1.4 MB/s
[   4.7520 ]
[   4.7520 ] Generating signatures
[   4.7527 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[   4.7529 ] Assuming zero filled SBK key
[   4.9342 ] Warning: pub_key.key is not found
[   4.9362 ] Parsing dev params for multi chains
[   4.9363 ] Generating br-bct
[   4.9373 ] Updating dev and MSS params in BR BCT
[   4.9374 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0004-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.0188 ] Updating customer data section
[   5.0201 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   5.0214 ] Updating bl info
[   5.0222 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   5.0247 ] Generating SHA2 Hash
[   5.0266 ] Sha saved in br_bct_BR.sha
[   5.0261 ] Get Signed section of bct
[   5.0269 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   5.0279 ] Signing BCT
[   5.0286 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.0288 ] Assuming zero filled SBK key
[   5.0321 ] Sha saved in br_bct_BR.sha
[   5.0324 ] Warning: pub_key.key is not found
[   5.0318 ] Updating BCT with signature
[   5.0328 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   5.0335 ] Offset :4608 Len :3584
[   5.0340 ] Generating SHA2 Hash
[   5.0347 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   5.0348 ] Assuming zero filled SBK key
[   5.0349 ] Assuming zero filled SBK key
[   5.0385 ] Sha saved in br_bct_BR.sha
[   5.0382 ] Updating BCT with SHA2 Hash
[   5.0392 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   5.0402 ] Offset :4608 Len :3584
[   5.0406 ] Offset :68 Len :8124
[   5.0408 ] Generating br-bct
[   5.0419 ] Updating dev and MSS params in BR BCT
[   5.0419 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0004-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[   5.1216 ] Updating customer data section
[   5.1230 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[   5.1246 ] Updating bl info
[   5.1261 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   5.1303 ] Generating SHA2 Hash
[   5.1324 ] Sha saved in br_bct_BR.sha
[   5.1319 ] Get Signed section of bct
[   5.1327 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[   5.1337 ] Signing BCT
[   5.1343 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.1345 ] Assuming zero filled SBK key
[   5.1375 ] Sha saved in br_bct_BR.sha
[   5.1378 ] Warning: pub_key.key is not found
[   5.1372 ] Updating BCT with signature
[   5.1380 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[   5.1389 ] Offset :4608 Len :3584
[   5.1397 ] Generating SHA2 Hash
[   5.1404 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[   5.1405 ] Assuming zero filled SBK key
[   5.1406 ] Assuming zero filled SBK key
[   5.1441 ] Sha saved in br_bct_BR.sha
[   5.1439 ] Updating BCT with SHA2 Hash
[   5.1449 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[   5.1456 ] Offset :4608 Len :3584
[   5.1460 ] Offset :68 Len :8124
[   5.1462 ] Generating BCT backup image
[   5.1462 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[   5.1474 ] 记录了32768+0 的读入
[   5.1844 ] 记录了32768+0 的写出
[   5.1844 ] 32768字节(33 kB,32 KiB)已复制,0.0364205 s,900 kB/s
[   5.1845 ]
[   5.1845 ] Concatenating BCT for chain A to bct_backup.img
[   5.1845 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[   5.1860 ] 记录了8192+0 的读入
[   5.1923 ] 记录了8192+0 的写出
[   5.1923 ] 8192字节(8.2 kB,8.0 KiB)已复制,0.00590709 s,1.4 MB/s
[   5.1923 ]
[   5.1923 ] Concatenating BCT for chain B to bct_backup.img
[   5.1923 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[   5.1936 ] 记录了8192+0 的读入
[   5.1998 ] 记录了8192+0 的写出
[   5.1998 ] 8192字节(8.2 kB,8.0 KiB)已复制,0.00586836 s,1.4 MB/s
[   5.1998 ]
[   5.1999 ] Generating coldboot mb1-bct
[   5.2011 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.2021 ] MB1-BCT version: 0.13
[   5.2037 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   5.2041 ] Added Platform Config 0 data with size :- 2416
[   5.2054 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   5.2058 ] WARNING: unknown node 'g2'
[   5.2058 ] WARNING: unknown node 'g9'
[   5.2058 ] Added Platform Config 2 data with size :- 24
[   5.2058 ]
[   5.2058 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   5.2058 ] Added Platform Config 4 data with size :- 288
[   5.2058 ]
[   5.2058 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   5.2059 ] Added Platform Config 3 data with size :- 52
[   5.2059 ]
[   5.2059 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   5.2059 ] WARNING: unknown property 'major'
[   5.2059 ] WARNING: unknown property 'minor'
[   5.2059 ] Added Platform Config 5 data with size :- 512
[   5.2059 ]
[   5.2059 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   5.2059 ] Added Platform Config 7 data with size :- 380
[   5.2059 ]
[   5.2059 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.2059 ] Added Platform Config 8 data with size :- 24
[   5.2059 ]
[   5.2059 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   5.2059 ] Added Platform Config 9 data with size :- 100
[   5.2059 ]
[   5.2059 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   5.2059 ] ModuleCount 0 NumProdNames 0
[   5.2059 ] Added Platform Config 6 data with size :- 16
[   5.2060 ]
[   5.2060 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   5.2060 ]
[   5.2060 ] Updating mb1-bct with firmware information
[   5.2071 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   5.2100 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[   5.2109 ] Generating SHA2 Hash for mb1bct
[   5.2130 ] Sha saved in mb1_cold_boot_bct_MB1_aligned.sha
[   5.2145 ] Sha saved in mb1_cold_boot_bct_MB1.sha
[   5.2148 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[   5.2159 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[   5.2176 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2178 ] Assuming zero filled SBK key
[   5.2197 ] Warning: pub_key.key is not found
[   5.2204 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.2220 ] Generating recovery mb1-bct
[   5.2227 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[   5.2234 ] MB1-BCT version: 0.13
[   5.2247 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[   5.2251 ] Added Platform Config 0 data with size :- 2416
[   5.2266 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[   5.2269 ] WARNING: unknown node 'g2'
[   5.2269 ] WARNING: unknown node 'g9'
[   5.2269 ] Added Platform Config 2 data with size :- 24
[   5.2270 ]
[   5.2270 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[   5.2270 ] Added Platform Config 4 data with size :- 288
[   5.2270 ]
[   5.2270 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[   5.2270 ] Added Platform Config 3 data with size :- 52
[   5.2270 ]
[   5.2270 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[   5.2270 ] WARNING: unknown property 'major'
[   5.2270 ] WARNING: unknown property 'minor'
[   5.2270 ] Added Platform Config 5 data with size :- 512
[   5.2270 ]
[   5.2271 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[   5.2271 ] WARNING: unknown property 'major'
[   5.2271 ] WARNING: unknown property 'minor'
[   5.2271 ] Added Platform Config 7 data with size :- 380
[   5.2271 ]
[   5.2271 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[   5.2271 ] Added Platform Config 8 data with size :- 24
[   5.2271 ]
[   5.2271 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[   5.2271 ] Added Platform Config 9 data with size :- 100
[   5.2271 ]
[   5.2271 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[   5.2271 ] ModuleCount 0 NumProdNames 0
[   5.2271 ] Added Platform Config 6 data with size :- 16
[   5.2271 ]
[   5.2271 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[   5.2271 ]
[   5.2271 ] Updating mb1-bct with firmware information
[   5.2279 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[   5.2301 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[   5.2313 ] Generating SHA2 Hash for mb1bct
[   5.2339 ] Sha saved in mb1_bct_MB1_aligned.sha
[   5.2354 ] Sha saved in mb1_bct_MB1.sha
[   5.2357 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[   5.2368 ] adding BCH for mb1_bct_MB1_aligned.bct
[   5.2383 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.2384 ] Assuming zero filled SBK key
[   5.2403 ] Warning: pub_key.key is not found
[   5.2408 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[   5.2426 ] Generating coldboot mem-bct
[   5.2435 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0004-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0004-sdram-l4t_cpp_1.bct tegra234-p3767-0004-sdram-l4t_cpp_2.bct tegra234-p3767-0004-sdram-l4t_cpp_3.bct tegra234-p3767-0004-sdram-l4t_cpp_4.bct
[   5.2442 ]  packing sdram params with Wb0 file tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb
[   5.3242 ] Packing sdram param for instance[0]
[   5.3244 ] Packing sdram param for instance[1]
[   5.3246 ] Packing sdram param for instance[2]
[   5.3248 ] Packing sdram param for instance[3]
[   5.3250 ] Packing sdram param for instance[4]
[   5.3251 ] Packing sdram param for instance[5]
[   5.3253 ] Packing sdram param for instance[6]
[   5.3255 ] Packing sdram param for instance[7]
[   5.3257 ] Packing sdram param for instance[8]
[   5.3258 ] Packing sdram param for instance[9]
[   5.3258 ] Packing sdram param for instance[10]
[   5.3260 ] Packing sdram param for instance[11]
[   5.3261 ] Packing sdram param for instance[12]
[   5.3262 ] Packing sdram param for instance[13]
[   5.3263 ] Packing sdram param for instance[14]
[   5.3265 ] Packing sdram param for instance[15]
[   5.4103 ] Getting sector size from pt
[   5.4116 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   5.4129 ] BlockSize read from layout is 0x200
[   5.4141 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0004-sdram-l4t_cpp_1.bct tegra234-p3767-0004-sdram-l4t_cpp_2.bct tegra234-p3767-0004-sdram-l4t_cpp_3.bct tegra234-p3767-0004-sdram-l4t_cpp_4.bct
[   5.4152 ] Binary 0 length is 58752
[   5.4158 ] Binary 0 align length is 58880
[   5.4168 ] Binary 1 length is 58752
[   5.4171 ] Binary 1 align length is 58880
[   5.4184 ] Binary 2 length is 58752
[   5.4186 ] Binary 2 align length is 58880
[   5.4194 ] Binary 3 length is 58752
[   5.4196 ] Binary 3 align length is 58880
[   5.4204 ] Buffer length is 235520
[   5.4206 ] adding BCH for tegra234-p3767-0004-sdram-l4t_cpp_1.bct
[   5.4209 ] new length is 243712
[   5.4209 ]
[   5.4226 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[   5.4246 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[   5.4254 ] Header already present for mem_coldboot_aligned.bct
[   5.4268 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.4270 ] Assuming zero filled SBK key
[   5.4290 ] Warning: pub_key.key is not found
[   5.4298 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[   5.4364 ] Generating recovery mem-bct
[   5.4379 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0004-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0004-sdram-l4t_cpp_1.bct tegra234-p3767-0004-sdram-l4t_cpp_2.bct tegra234-p3767-0004-sdram-l4t_cpp_3.bct tegra234-p3767-0004-sdram-l4t_cpp_4.bct
[   5.4389 ]  packing sdram params with Wb0 file tegra234-p3767-0004-wb0sdram-l4t_cpp.dtb
[   5.5244 ] Packing sdram param for instance[0]
[   5.5248 ] Packing sdram param for instance[1]
[   5.5250 ] Packing sdram param for instance[2]
[   5.5252 ] Packing sdram param for instance[3]
[   5.5254 ] Packing sdram param for instance[4]
[   5.5258 ] Packing sdram param for instance[5]
[   5.5260 ] Packing sdram param for instance[6]
[   5.5265 ] Packing sdram param for instance[7]
[   5.5268 ] Packing sdram param for instance[8]
[   5.5273 ] Packing sdram param for instance[9]
[   5.5275 ] Packing sdram param for instance[10]
[   5.5278 ] Packing sdram param for instance[11]
[   5.5281 ] Packing sdram param for instance[12]
[   5.5286 ] Packing sdram param for instance[13]
[   5.5288 ] Packing sdram param for instance[14]
[   5.5289 ] Packing sdram param for instance[15]
[   5.6083 ] Reading ramcode from backup chip_info.bin file
[   5.6084 ] RAMCODE Read from Device: 4
[   5.6084 ] Using ramcode 1
[   5.6084 ] Disabled BPMP dtb trim, using default dtb
[   5.6084 ]
[   5.6098 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[   5.6114 ] tegrahost_v2 --chip 0x23 0 --magicid MEM1 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[   5.6121 ] adding BCH for mem_rcm_aligned.bct
[   5.6152 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.6153 ] Assuming zero filled SBK key
[   5.6176 ] Warning: pub_key.key is not found
[   5.6181 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[   5.6211 ] Copying signatures
[   5.6222 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[   5.7338 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[   5.7351 ] gpt_secondary_3_0.bin:
[   5.7357 ] partition_id	partition_name			      StartingLba	EndingLba
[   5.7361 ]            1	BCT                                 	       0    2047
[   5.7365 ]            2	A_mb1                               	    2048    3071
[   5.7369 ]            3	A_psc_bl1                           	    3072    3583
[   5.7374 ]            4	A_MB1_BCT                           	    3584    3839
[   5.7377 ]            5	A_MEM_BCT                           	    3840    4351
[   5.7377 ]            6	A_tsec-fw                           	    4352    6399
[   5.7377 ]            7	A_nvdec                             	    6400    8447
[   5.7377 ]            8	A_mb2                               	    8448    9471
[   5.7377 ]            9	A_xusb-fw                           	    9472    9983
[   5.7377 ]           10	A_bpmp-fw                           	    9984   13055
[   5.7377 ]           11	A_bpmp-fw-dtb                       	   13056   21247
[   5.7377 ]           12	A_psc-fw                            	   21248   22783
[   5.7377 ]           13	A_mts-mce                           	   22784   23807
[   5.7378 ]           14	A_sc7                               	   23808   24191
[   5.7378 ]           15	A_pscrf                             	   24192   24575
[   5.7378 ]           16	A_mb2rf                             	   24576   24831
[   5.7378 ]           17	A_cpu-bootloader                    	   24832   31999
[   5.7378 ]           18	A_secure-os                         	   32000   40191
[   5.7378 ]           19	A_smm-fw                            	   40192   44287
[   5.7378 ]           20	A_eks                               	   44288   44799
[   5.7378 ]           21	A_dce-fw                            	   44800   55039
[   5.7378 ]           22	A_spe-fw                            	   55040   56191
[   5.7378 ]           23	A_rce-fw                            	   56192   58239
[   5.7378 ]           24	A_adsp-fw                           	   58240   62335
[   5.7378 ]           25	A_pva-fw                            	   62336   62847
[   5.7378 ]           26	A_reserved_on_boot                  	   62848   65023
[   5.7378 ]           27	B_mb1                               	   65024   66047
[   5.7378 ]           28	B_psc_bl1                           	   66048   66559
[   5.7378 ]           29	B_MB1_BCT                           	   66560   66815
[   5.7378 ]           30	B_MEM_BCT                           	   66816   67327
[   5.7379 ]           31	B_tsec-fw                           	   67328   69375
[   5.7379 ]           32	B_nvdec                             	   69376   71423
[   5.7379 ]           33	B_mb2                               	   71424   72447
[   5.7379 ]           34	B_xusb-fw                           	   72448   72959
[   5.7379 ]           35	B_bpmp-fw                           	   72960   76031
[   5.7379 ]           36	B_bpmp-fw-dtb                       	   76032   84223
[   5.7379 ]           37	B_psc-fw                            	   84224   85759
[   5.7379 ]           38	B_mts-mce                           	   85760   86783
[   5.7379 ]           39	B_sc7                               	   86784   87167
[   5.7380 ]           40	B_pscrf                             	   87168   87551
[   5.7380 ]           41	B_mb2rf                             	   87552   87807
[   5.7380 ]           42	B_cpu-bootloader                    	   87808   94975
[   5.7380 ]           43	B_secure-os                         	   94976  103167
[   5.7380 ]           44	B_smm-fw                            	  103168  107263
[   5.7380 ]           45	B_eks                               	  107264  107775
[   5.7380 ]           46	B_dce-fw                            	  107776  118015
[   5.7380 ]           47	B_spe-fw                            	  118016  119167
[   5.7380 ]           48	B_rce-fw                            	  119168  121215
[   5.7381 ]           49	B_adsp-fw                           	  121216  125311
[   5.7381 ]           50	B_pva-fw                            	  125312  125823
[   5.7381 ]           51	B_reserved_on_boot                  	  125824  127999
[   5.7381 ]           52	uefi_variables                      	  128000  128511
[   5.7381 ]           53	uefi_ftw                            	  128512  129535
[   5.7381 ]           54	reserved                            	  129536  129919
[   5.7381 ]           55	worm                                	  129920  130303
[   5.7381 ]           56	BCT-boot-chain_backup               	  130304  130431
[   5.7381 ]           57	reserved_partition                  	  130432  130559
[   5.7381 ]           58	secondary_gpt_backup                	  130560  130687
[   5.7381 ]           59	B_VER                               	  130688  130815
[   5.7382 ]           60	A_VER                               	  130816  130943
[   5.7382 ] gpt_primary_6_0.bin:
[   5.7382 ] partition_id	partition_name			      StartingLba	EndingLba
[   5.7382 ]            1	APP                                 	 3050048119537623
[   5.7382 ]            2	A_kernel                            	      40  262183
[   5.7382 ]            3	A_kernel-dtb                        	  262184  263719
[   5.7382 ]            4	A_reserved_on_user                  	  263720  328487
[   5.7382 ]            5	B_kernel                            	  328488  590631
[   5.7382 ]            6	B_kernel-dtb                        	  590632  592167
[   5.7382 ]            7	B_reserved_on_user                  	  592168  656935
[   5.7382 ]            8	recovery                            	  656936  820775
[   5.7382 ]            9	recovery-dtb                        	  820776  821799
[   5.7382 ]           10	esp                                 	  821800  952871
[   5.7383 ]           11	recovery_alt                        	  952872 1116711
[   5.7383 ]           12	recovery-dtb_alt                    	 1116712 1117735
[   5.7383 ]           13	esp_alt                             	 1117736 1248807
[   5.7383 ]           14	UDA                                 	 1248832 2068031
[   5.7383 ]           15	reserved                            	 2068032 3050047
[   5.7383 ] gpt_secondary_6_0.bin:
[   5.7383 ] partition_id	partition_name			      StartingLba	EndingLba
[   5.7383 ]            1	APP                                 	 3050048119537623
[   5.7383 ]            2	A_kernel                            	      40  262183
[   5.7383 ]            3	A_kernel-dtb                        	  262184  263719
[   5.7384 ]            4	A_reserved_on_user                  	  263720  328487
[   5.7384 ]            5	B_kernel                            	  328488  590631
[   5.7384 ]            6	B_kernel-dtb                        	  590632  592167
[   5.7384 ]            7	B_reserved_on_user                  	  592168  656935
[   5.7384 ]            8	recovery                            	  656936  820775
[   5.7384 ]            9	recovery-dtb                        	  820776  821799
[   5.7384 ]           10	esp                                 	  821800  952871
[   5.7384 ]           11	recovery_alt                        	  952872 1116711
[   5.7384 ]           12	recovery-dtb_alt                    	 1116712 1117735
[   5.7384 ]           13	esp_alt                             	 1117736 1248807
[   5.7384 ]           14	UDA                                 	 1248832 2068031
[   5.7384 ]           15	reserved                            	 2068032 3050047
[   5.7384 ]
[   5.7402 ] Get magic id
[   5.7413 ] tegraparser_v2 --get_magic psc_fw
[   5.7421 ] PFWP
[   5.7422 ] partition type psc_fw, magic id = PFWP
[   5.7469 ] tegrahost_v2 --chip 0x23 0 --align pscfw_t234_prod_aligned.bin
[   5.7487 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader pscfw_t234_prod_aligned.bin zerosbk
[   5.7496 ] Header already present for pscfw_t234_prod_aligned.bin
[   5.7558 ] tegrasign_v3.py --key None --list pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7560 ] Assuming zero filled SBK key
[   5.7582 ] Warning: pub_key.key is not found
[   5.7588 ] tegrahost_v2 --chip 0x23 0 --updatesigheader pscfw_t234_prod_aligned_sigheader.bin.encrypt pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[   5.7634 ] Get magic id
[   5.7649 ] tegraparser_v2 --get_magic mts_mce
[   5.7662 ] MTSM
[   5.7663 ] partition type mts_mce, magic id = MTSM
[   5.7685 ] tegrahost_v2 --chip 0x23 0 --align mce_flash_o10_cr_prod_aligned.bin
[   5.7707 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader mce_flash_o10_cr_prod_aligned.bin zerosbk
[   5.7718 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[   5.7760 ] tegrasign_v3.py --key None --list mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7762 ] Assuming zero filled SBK key
[   5.7781 ] Warning: pub_key.key is not found
[   5.7785 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[   5.7817 ] Get magic id
[   5.7827 ] tegraparser_v2 --get_magic tsec_fw
[   5.7844 ] TSEC
[   5.7844 ]
[   5.7844 ] partition type tsec_fw, magic id = TSEC
[   5.7863 ] tegrahost_v2 --chip 0x23 0 --align tsec_t234_aligned.bin
[   5.7884 ] tegrahost_v2 --chip 0x23 0 --magicid TSEC --ratchet_blob ratchet_blob.bin --appendsigheader tsec_t234_aligned.bin zerosbk
[   5.7892 ] Header already present for tsec_t234_aligned.bin
[   5.7933 ] tegrasign_v3.py --key None --list tsec_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.7935 ] Assuming zero filled SBK key
[   5.7956 ] Warning: pub_key.key is not found
[   5.7965 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tsec_t234_aligned_sigheader.bin.encrypt tsec_t234_aligned_sigheader.bin.hash zerosbk
[   5.8002 ] Get magic id
[   5.8013 ] tegraparser_v2 --get_magic mb2_applet
[   5.8024 ] MB2A
[   5.8025 ] partition type mb2_applet, magic id = MB2A
[   5.8039 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[   5.8056 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[   5.8065 ] adding BCH for applet_t234_aligned.bin
[   5.8166 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8169 ] Assuming zero filled SBK key
[   5.8190 ] Warning: pub_key.key is not found
[   5.8193 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[   5.8266 ] Generating recovery mb2-bct
[   5.8266 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[   5.8276 ] ERROR: value 0x31 is out of range
[   5.8283 ] ERROR: value 0x31 is out of range
[   5.8284 ] ERROR: value 0x31 is out of range
[   5.8285 ] ERROR: value 0x31 is out of range
[   5.8286 ] WARNING: unknown property 'tfc_version'
[   5.8288 ] WARNING: unknown property 'addr_header_version'
[   5.8366 ] Updating mb2-bct with storage information for RCM
[   5.8376 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[   5.8389 ] Concatenating mb2-bct to mb2 binary
[   5.8389 ] mb2_bin_file = mb2_t234.bin
[   5.8389 ] mb2_bct_file = mb2_bct_MB2.bct
[   5.8393 ] Get magic id
[   5.8401 ] tegraparser_v2 --get_magic mb2_bootloader
[   5.8408 ] MB2B
[   5.8409 ] partition type mb2_bootloader, magic id = MB2B
[   5.8420 ] tegrahost_v2 --chip 0x23 0 --align mb2_t234_with_mb2_bct_MB2_aligned.bin
[   5.8436 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[   5.8444 ] adding BCH for mb2_t234_with_mb2_bct_MB2_aligned.bin
[   5.8601 ] tegrasign_v3.py --key None --list mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8603 ] Assuming zero filled SBK key
[   5.8629 ] Warning: pub_key.key is not found
[   5.8636 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[   5.8696 ] Get magic id
[   5.8708 ] tegraparser_v2 --get_magic xusb_fw
[   5.8719 ] XUSB
[   5.8719 ]
[   5.8719 ] partition type xusb_fw, magic id = XUSB
[   5.8742 ] tegrahost_v2 --chip 0x23 0 --align xusb_t234_prod_aligned.bin
[   5.8762 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader xusb_t234_prod_aligned.bin zerosbk
[   5.8773 ] adding BCH for xusb_t234_prod_aligned.bin
[   5.8838 ] tegrasign_v3.py --key None --list xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.8840 ] Assuming zero filled SBK key
[   5.8862 ] Warning: pub_key.key is not found
[   5.8869 ] tegrahost_v2 --chip 0x23 0 --updatesigheader xusb_t234_prod_aligned_sigheader.bin.encrypt xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[   5.8930 ] Get magic id
[   5.8941 ] tegraparser_v2 --get_magic pva_fw
[   5.8948 ] PVAF
[   5.8949 ] partition type pva_fw, magic id = PVAF
[   5.9050 ] tegrahost_v2 --chip 0x23 0 --align nvpva_020_aligned.fw
[   5.9075 ] tegrahost_v2 --chip 0x23 0 --magicid PVAF --ratchet_blob ratchet_blob.bin --appendsigheader nvpva_020_aligned.fw zerosbk
[   5.9087 ] adding BCH for nvpva_020_aligned.fw
[   5.9862 ] tegrasign_v3.py --key None --list nvpva_020_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   5.9864 ] Assuming zero filled SBK key
[   5.9913 ] Warning: pub_key.key is not found
[   5.9917 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvpva_020_aligned_sigheader.fw.encrypt nvpva_020_aligned_sigheader.fw.hash zerosbk
[   6.0161 ] Kernel DTB used: kernel_tegra234-p3768-0000+p3767-0004-nv.dtb
[   6.0161 ] Concatenating kernel-dtb to dce-fw binary
[   6.0162 ] dce_bin = display-t234-dce.bin
[   6.0162 ] kernel_dtb = kernel_tegra234-p3768-0000+p3767-0004-nv.dtb
[   6.0162 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv.bin
[   6.0656 ] Get magic id
[   6.0669 ] tegraparser_v2 --get_magic dce_fw
[   6.0678 ] DCEF
[   6.0679 ] partition type dce_fw, magic id = DCEF
[   6.1153 ] tegrahost_v2 --chip 0x23 0 --align display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin
[   6.1167 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin zerosbk
[   6.1174 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned.bin
[   6.5092 ] tegrasign_v3.py --key None --list display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.5094 ] Assuming zero filled SBK key
[   6.5352 ] Warning: pub_key.key is not found
[   6.5359 ] tegrahost_v2 --chip 0x23 0 --updatesigheader display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned_sigheader.bin.encrypt display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_aligned_sigheader.bin.hash zerosbk
[   6.7004 ] Get magic id
[   6.7016 ] tegraparser_v2 --get_magic nvdec
[   6.7028 ] NDEC
[   6.7028 ]
[   6.7028 ] partition type nvdec, magic id = NDEC
[   6.7051 ] tegrahost_v2 --chip 0x23 0 --align nvdec_t234_prod_aligned.fw
[   6.7065 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader nvdec_t234_prod_aligned.fw zerosbk
[   6.7072 ] Header already present for nvdec_t234_prod_aligned.fw
[   6.7131 ] tegrasign_v3.py --key None --list nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.7133 ] Assuming zero filled SBK key
[   6.7152 ] Warning: pub_key.key is not found
[   6.7154 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvdec_t234_prod_aligned_sigheader.fw.encrypt nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[   6.7195 ] Get magic id
[   6.7203 ] tegraparser_v2 --get_magic bpmp_fw
[   6.7210 ] BPMF
[   6.7211 ]
[   6.7211 ] partition type bpmp_fw, magic id = BPMF
[   6.7262 ] tegrahost_v2 --chip 0x23 0 --align bpmp_t234-TE950M-A1_prod_aligned.bin
[   6.7279 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t234-TE950M-A1_prod_aligned.bin zerosbk
[   6.7287 ] Header already present for bpmp_t234-TE950M-A1_prod_aligned.bin
[   6.7466 ] tegrasign_v3.py --key None --list bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.7468 ] Assuming zero filled SBK key
[   6.7502 ] Warning: pub_key.key is not found
[   6.7510 ] tegrahost_v2 --chip 0x23 0 --updatesigheader bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.encrypt bpmp_t234-TE950M-A1_prod_aligned_sigheader.bin.hash zerosbk
[   6.7642 ] Using bpmp-dtb concatenated with odmdata
[   6.7643 ] Get magic id
[   6.7660 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[   6.7674 ] BPMD
[   6.7676 ] partition type bpmp_fw_dtb, magic id = BPMD
[   6.7700 ] tegrahost_v2 --chip 0x23 0 --align tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned.dtb
[   6.7725 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned.dtb zerosbk
[   6.7735 ] adding BCH for tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned.dtb
[   6.7814 ] tegrasign_v3.py --key None --list tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.7816 ] Assuming zero filled SBK key
[   6.7842 ] Warning: pub_key.key is not found
[   6.7849 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned_sigheader.dtb.encrypt tegra234-bpmp-3767-0004-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[   6.7894 ] Get magic id
[   6.7906 ] tegraparser_v2 --get_magic rce_fw
[   6.7917 ] RCEF
[   6.7919 ] partition type rce_fw, magic id = RCEF
[   6.7956 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-t234-rce_aligned.img
[   6.7979 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-t234-rce_aligned.img zerosbk
[   6.7991 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[   6.8172 ] tegrasign_v3.py --key None --list camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.8174 ] Assuming zero filled SBK key
[   6.8200 ] Warning: pub_key.key is not found
[   6.8203 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[   6.8285 ] Get magic id
[   6.8300 ] tegraparser_v2 --get_magic ape_fw
[   6.8308 ] APEF
[   6.8309 ] partition type ape_fw, magic id = APEF
[   6.8338 ] tegrahost_v2 --chip 0x23 0 --align adsp-fw_aligned.bin
[   6.8354 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader adsp-fw_aligned.bin zerosbk
[   6.8362 ] adding BCH for adsp-fw_aligned.bin
[   6.8520 ] tegrasign_v3.py --key None --list adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.8524 ] Assuming zero filled SBK key
[   6.8551 ] Warning: pub_key.key is not found
[   6.8557 ] tegrahost_v2 --chip 0x23 0 --updatesigheader adsp-fw_aligned_sigheader.bin.encrypt adsp-fw_aligned_sigheader.bin.hash zerosbk
[   6.8615 ] Get magic id
[   6.8627 ] tegraparser_v2 --get_magic spe_fw
[   6.8639 ] SPEF
[   6.8640 ]
[   6.8640 ] partition type spe_fw, magic id = SPEF
[   6.8665 ] tegrahost_v2 --chip 0x23 0 --align spe_t234_aligned.bin
[   6.8687 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t234_aligned.bin zerosbk
[   6.8697 ] adding BCH for spe_t234_aligned.bin
[   6.8808 ] tegrasign_v3.py --key None --list spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.8810 ] Assuming zero filled SBK key
[   6.8833 ] Warning: pub_key.key is not found
[   6.8840 ] tegrahost_v2 --chip 0x23 0 --updatesigheader spe_t234_aligned_sigheader.bin.encrypt spe_t234_aligned_sigheader.bin.hash zerosbk
[   6.8911 ] Get magic id
[   6.8924 ] tegraparser_v2 --get_magic tos
[   6.8934 ] TOSB
[   6.8935 ] partition type tos, magic id = TOSB
[   6.9016 ] tegrahost_v2 --chip 0x23 0 --align tos-optee_t234_aligned.img
[   6.9039 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-optee_t234_aligned.img zerosbk
[   6.9050 ] adding BCH for tos-optee_t234_aligned.img
[   6.9594 ] tegrasign_v3.py --key None --list tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.9596 ] Assuming zero filled SBK key
[   6.9636 ] Warning: pub_key.key is not found
[   6.9641 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tos-optee_t234_aligned_sigheader.img.encrypt tos-optee_t234_aligned_sigheader.img.hash zerosbk
[   6.9811 ] Get magic id
[   6.9829 ] tegraparser_v2 --get_magic eks
[   6.9844 ] EKSB
[   6.9844 ]
[   6.9845 ] partition type eks, magic id = EKSB
[   6.9859 ] tegrahost_v2 --chip 0x23 0 --align eks_t234_aligned.img
[   6.9880 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks_t234_aligned.img zerosbk
[   6.9888 ] adding BCH for eks_t234_aligned.img
[   6.9900 ] tegrasign_v3.py --key None --list eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[   6.9902 ] Assuming zero filled SBK key
[   6.9919 ] Warning: pub_key.key is not found
[   6.9926 ] tegrahost_v2 --chip 0x23 0 --updatesigheader eks_t234_aligned_sigheader.img.encrypt eks_t234_aligned_sigheader.img.hash zerosbk
[   7.0095 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[   7.0111 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[   7.0119 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[   7.1290 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[   7.1292 ] Assuming zero filled SBK key
[   7.1370 ] Warning: pub_key.key is not found
[   7.1378 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[   7.1745 ] Copying enc\/signed file in /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2300 ] Copying br bct for multi chains
[   7.2302 ] Signed BCT for boot chain A is copied to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[   7.2303 ] Signed BCT for boot chain B is copied to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[   7.2303 ] Copying BCT backup image bct_backup.img to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/bct_backup.img
[   7.2336 ] Copying pscfw_t234_prod_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2350 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt
[   7.2350 ] Copying mce_flash_o10_cr_prod_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2360 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt
[   7.2360 ] Copying tsec_t234_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2369 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/tsec_t234_sigheader.bin.encrypt
[   7.2370 ] Copying applet_t234_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2372 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/applet_t234_sigheader.bin.encrypt
[   7.2372 ] Copying mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2376 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt
[   7.2376 ] Copying xusb_t234_prod_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2384 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt
[   7.2385 ] Copying nvpva_020_sigheader.fw.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2400 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/nvpva_020_sigheader.fw.encrypt
[   7.2400 ] Copying display-t234-dce_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2472 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/display-t234-dce_sigheader.bin.encrypt
[   7.2472 ] Copying display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2553 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/display-t234-dce_with_kernel_tegra234-p3768-0000+p3767-0004-nv_sigheader.bin.encrypt
[   7.2554 ] Copying nvdec_t234_prod_sigheader.fw.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2569 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt
[   7.2570 ] Copying bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2613 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt
[   7.2613 ] Copying tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2625 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt
[   7.2625 ] Copying camera-rtcpu-t234-rce_sigheader.img.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2644 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt
[   7.2644 ] Copying adsp-fw_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2662 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt
[   7.2662 ] Copying spe_t234_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2675 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt
[   7.2676 ] Copying tos-optee_t234_sigheader.img.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2738 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt
[   7.2738 ] Copying eks_t234_sigheader.img.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2739 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
[   7.2740 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed
[   7.2764 ] Signed file: /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[   7.2796 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/zynq/nvidia/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
Using bpmp-dtb concatenated with odmdata in blob for t23x
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3768-0000+p3767-0004-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot.img; kernel_dtb tegra234-p3768-0000+p3767-0004-nv.dtb"    --bct_backup
saving flash command in flashcmd.txt
no_flash ...; prepare rcm blob
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
 Entering RCM boot
[   0.0196 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0196 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0197 ] rcm boot with presigned binaries
[   0.0208 ] Generating blob for T23x
[   0.0224 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.0233 ] The number of images in blob is 19
[   0.0237 ] blobsize is 78193888
[   0.0239 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3563584
[   0.0467 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.0472 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.0478 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.0482 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.0496 ] Not supported type: mb2_applet
[   0.0499 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.0502 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.0505 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.0509 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065152
[   0.0561 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.0582 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.0588 ] Added binary blob_tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt of size 204672
[   0.0591 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.0594 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.0597 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.0601 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.0605 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.0609 ] Added binary blob_boot.img of size 54284288
[   0.0945 ] Added binary blob_tegra234-p3768-0000+p3767-0004-nv.dtb of size 244096
[   0.2268 ] All RCM required files are saved in rcm_blob folder
done.
*** no-flash flag enabled. Exiting now... ***
User can run above saved command in factory environment without
providing pkc and sbk keys to flash a device
Example:
    $ cd bootloader
    $ sudo bash ./flashcmd.txt
Save initrd flashing command parameters to /home/zynq/nvidia/Linux_for_Tegra/tools/kernel_flash/initrdflashparam.txt
/tmp/tmp.vEI3MTkdsx /home/zynq/nvidia/Linux_for_Tegra
writing boot image config in bootimg.cfg
extracting kernel in zImage
extracting ramdisk in initrd.img
/tmp/tmp.vEI3MTkdsx/initrd /tmp/tmp.vEI3MTkdsx /home/zynq/nvidia/Linux_for_Tegra
75110 块
106186 块
flashimg0=boot0.img
Success
Cleaning up...
Finish generating flash package.
/home/zynq/nvidia/Linux_for_Tegra/tools/kernel_flash/l4t_initrd_flash_internal.sh --initrd --usb-instance 1-1 --device-instance 0 --flash-only --initrd --network usb0 jetson-orin-nano-devkit internal
# Entry added by NVIDIA initrd flash tool
/home/zynq/nvidia/Linux_for_Tegra/tools/kernel_flash/tmp 127.0.0.1(rw,nohide,insecure,no_subtree_check,async,no_root_squash)
Export list for localhost:
*  Step 1: Build the flashing environment    *
Create flash environment 0
/home/zynq/nvidia/Linux_for_Tegra/bootloader /home/zynq/nvidia/Linux_for_Tegra
Finish creating flash environment 0.
*  Step 2: Boot the device with flash initrd image *
/home/zynq/nvidia/Linux_for_Tegra/temp_initrdflash/bootloader0 /home/zynq/nvidia/Linux_for_Tegra
./tegraflash.py --bl uefi_jetson_with_dtb_sigheader.bin.encrypt --bct br_bct_BR.bct --securedev  --bldtb tegra234-p3768-0000+p3767-0004-nv.dtb --applet rcm_2_encrypt.rcm --applet_softfuse rcm_1_encrypt.rcm --cmd "rcmboot"  --cfg secureflash.xml --chip 0x23 --mb1_bct mb1_bct_MB1_sigheader.bct.encrypt --mem_bct mem_rcm_sigheader.bct.encrypt --mb1_cold_boot_bct mb1_cold_boot_bct_MB1_sigheader.bct.encrypt --mb1_bin mb1_t234_prod_aligned_sigheader.bin.encrypt --psc_bl1_bin psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --mem_bct_cold_boot mem_coldboot_sigheader.bct.encrypt  --bins "psc_fw pscfw_t234_prod_sigheader.bin.encrypt; mts_mce mce_flash_o10_cr_prod_sigheader.bin.encrypt; tsec_fw tsec_t234_sigheader.bin.encrypt; mb2_applet applet_t234_sigheader.bin.encrypt; mb2_bootloader mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt; xusb_fw xusb_t234_prod_sigheader.bin.encrypt; pva_fw nvpva_020_sigheader.fw.encrypt; dce_fw display-t234-dce_sigheader.bin.encrypt; nvdec nvdec_t234_prod_sigheader.fw.encrypt; bpmp_fw bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt; bpmp_fw_dtb tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt; rce_fw camera-rtcpu-t234-rce_sigheader.img.encrypt; ape_fw adsp-fw_sigheader.bin.encrypt; spe_fw spe_t234_sigheader.bin.encrypt; tos tos-optee_t234_sigheader.img.encrypt; eks eks_t234_sigheader.img.encrypt; kernel boot0.img; kernel_dtb tegra234-p3768-0000+p3767-0004-nv.dtb"    --bct_backup  --instance 1-1
version 1.0.0
 Entering RCM boot
[   0.0351 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from --mb1_bin
[   0.0351 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from --psc_bl1_bin
[   0.0351 ] rcm boot with presigned binaries
[   0.0365 ] tegrarcm_v2 --instance 1-1 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[   0.0375 ] BR_CID: 0x80012344705DD50C6C00000001FE8140
[   0.0517 ] Sending bct_br
[   0.0564 ] Sending mb1
[   0.0577 ] Sending psc_bl1
[   0.0948 ] Sending bct_mb1
[   0.1147 ] Generating blob for T23x
[   0.1167 ] tegrahost_v2 --chip 0x23 0 --generateblob blob.xml blob.bin
[   0.1178 ] The number of images in blob is 19
[   0.1181 ] blobsize is 86887648
[   0.1181 ] Added binary blob_uefi_jetson_with_dtb_sigheader.bin.encrypt of size 3563584
[   0.1458 ] Added binary blob_pscfw_t234_prod_sigheader.bin.encrypt of size 310768
[   0.1464 ] Added binary blob_mce_flash_o10_cr_prod_sigheader.bin.encrypt of size 187120
[   0.1466 ] Added binary blob_tsec_t234_sigheader.bin.encrypt of size 176128
[   0.1467 ] Added binary blob_applet_t234_sigheader.bin.encrypt of size 279616
[   0.1468 ] Not supported type: mb2_applet
[   0.1469 ] Added binary blob_mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt of size 439968
[   0.1470 ] Added binary blob_xusb_t234_prod_sigheader.bin.encrypt of size 164864
[   0.1479 ] Added binary blob_nvpva_020_sigheader.fw.encrypt of size 2164640
[   0.1481 ] Added binary blob_display-t234-dce_sigheader.bin.encrypt of size 12065152
[   0.1551 ] Added binary blob_nvdec_t234_prod_sigheader.fw.encrypt of size 294912
[   0.1575 ] Added binary blob_bpmp_t234-TE950M-A1_prod_sigheader.bin.encrypt of size 1027008
[   0.1581 ] Added binary blob_tegra234-bpmp-3767-0004-3509-a02_with_odm_sigheader.dtb.encrypt of size 204672
[   0.1583 ] Added binary blob_camera-rtcpu-t234-rce_sigheader.img.encrypt of size 458096
[   0.1586 ] Added binary blob_adsp-fw_sigheader.bin.encrypt of size 414960
[   0.1588 ] Added binary blob_spe_t234_sigheader.bin.encrypt of size 270336
[   0.1589 ] Added binary blob_tos-optee_t234_sigheader.img.encrypt of size 1633344
[   0.1598 ] Added binary blob_eks_t234_sigheader.img.encrypt of size 9232
[   0.1601 ] Added binary blob_boot0.img of size 62978048
[   0.1929 ] Added binary blob_tegra234-p3768-0000+p3767-0004-nv.dtb of size 244096
[   0.2613 ] tegrarcm_v2 --instance 1-1 --chip 0x23 0 --pollbl --download bct_mem mem_rcm_sigheader.bct.encrypt --download blob blob.bin
[   0.2620 ] BL: version 1.4.0.2-t234-54845784-08a4de08 last_boot_error: 0
[   0.3755 ] Sending bct_mem
[   0.3808 ] Sending blob
[  11.7478 ] RCM-boot started
*  Step 3: Start the flashing process *
Waiting for target to boot-up...
Waiting for device to expose ssh ......Waiting for device to expose ssh ...Device has booted into initrd. You can ssh to the target by the command:
$ ssh root@fc00:1:1:0::2
Cleaning up...
Log is saved to Linux_for_Tegra/initrdlog/flash_1-1_0_20240731-111452.log
Run command:
ln -s /proc/self/fd /dev/fd && mount -o nolock [fc00:1:1::1]:/home/zynq/nvidia/Linux_for_Tegra/tools/backup_restore /mnt && /mnt/nvrestore_partitions.sh -e nvme0n1 -n
 on root@fc00:1:1::2
/mnt/images ~
nvrestore_partitions.sh: Use the default nvpartitionmap.txt as the index file.
40+0 records in
40+0 records out
20480 bytes (20 kB, 20 KiB) copied, 0.000624 s, 32.8 MB/s
nvrestore_partitions.sh Restoring qspi0 with image QSPI0.img...
Erasing 65536 Kibyte @ 0 --  0 % complete
gzip: QSPI0.img: not in gzip format
0+0 records in
0+0 records out
0 bytes copied, 0.00405885 s, 0.0 kB/s
nvrestore_partitions.sh Restoring gpt_2 with image gptbackup.img...
33+0 records in
33+0 records out
16896 bytes (17 kB, 16 KiB) copied, 0.000138976 s, 122 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p1_bak.img...
Erasing 65536 Kibyte @ 0 -- 100 % complete 7 s, 196 MB/s
27132225024 bytes (27 GB, 25 GiB) copied, 140 s, 194 MB/s67+1 records in
67+1 records out
67108864 bytes (67 MB, 64 MiB) copied, 72.8446 s, 921 kB/s
254431673856 bytes (254 GB, 237 GiB) copied, 1380 s, 184 MB/s
497068104+0 records in
497068104+0 records out
254498869248 bytes (254 GB, 237 GiB) copied, 1380.67 s, 184 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p2_bak.img...
101487104 bytes (101 MB, 97 MiB) copied, 1 s, 101 MB/s
262144+0 records in
262144+0 records out
134217728 bytes (134 MB, 128 MiB) copied, 1.55112 s, 86.5 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p3_bak.img...
1536+0 records in
1536+0 records out
786432 bytes (786 kB, 768 KiB) copied, 0.015493 s, 50.8 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p4_bak.img...
64768+0 records in
64768+0 records out
33161216 bytes (33 MB, 32 MiB) copied, 0.268433 s, 124 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p5_bak.img...
76128768 bytes (76 MB, 73 MiB) copied, 1 s, 76.1 MB/s
262144+0 records in
134217728 bytes (134 MB, 128 MiB) copied, 1.43855 s, 93.3 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p6_bak.img...
1536+0 records in
1536+0 records out
786432 bytes (786 kB, 768 KiB) copied, 0.0105393 s, 74.6 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p7_bak.img...
64768+0 records in
64768+0 records out
33161216 bytes (33 MB, 32 MiB) copied, 0.17717 s, 187 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p8_bak.img...
163840+0 records in
163840+0 records out
83886080 bytes (84 MB, 80 MiB) copied, 0.979405 s, 85.7 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p9_bak.img...
1024+0 records in
1024+0 records out
524288 bytes (524 kB, 512 KiB) copied, 0.00907898 s, 57.7 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p10_bak.img...
131072+0 records in
131072+0 records out
67108864 bytes (67 MB, 64 MiB) copied, 0.343883 s, 195 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p11_bak.img...
163840+0 records in
83886080 bytes (84 MB, 80 MiB) copied, 0.42383 s, 198 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p12_bak.img...
1024+0 records in
1024+0 records out
524288 bytes (524 kB, 512 KiB) copied, 0.00616454 s, 85.0 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p13_bak.img...
131072+0 records in
67108864 bytes (67 MB, 64 MiB) copied, 0.348471 s, 193 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p14_bak.img...
391950848 bytes (392 MB, 374 MiB) copied, 3 s, 131 MB/s
819200+0 records in
819200+0 records out
419430400 bytes (419 MB, 400 MiB) copied, 3.47074 s, 121 MB/s
nvrestore_partitions.sh Restoring nvme0n1 with image nvme0n1p15_bak.img...
475226624 bytes (475 MB, 453 MiB) copied, 7 s, 67.9 MB/s
982016+0 records in
982016+0 records out
502792192 bytes (503 MB, 480 MiB) copied, 7.76971 s, 64.7 MB/s
nvrestore_partitions.sh Successful restore of partitions on target board.
Operation finishes. You can manually reset the device
Hi 56101855,
Are you using the devkit or custom board for Orin Nano?
Are you backup from the 1st board connected with NVMe SSD and restore on another board?
It seems your restore log finish with successful.
Please share the full serial console log for further check.
You can upload the log as file here instead of paste the whole contents directly.
log.txt (38.7 KB)
Hello, this is my log file. Take a look. thank you
System restore produces logs.txt (101.1 KB)
Restore the logs generated by the system through the command.
Using devkit
@KevinFFF Can you help me see the problem of restoring after cloning?
From the log you shared, it seems you hit RAS error during boot up as following.
▒▒ERROR:   **************************************
ERROR:   RAS Uncorrectable Error in ACI, base=0xe01a000:
ERROR:          Status = 0xec000504
ERROR:   SERR = Assertion failure: 0x4
ERROR:          IERR = AR decode Error: 0x5
ERROR:          Overflow (there may be more errors) - Uncorrectable
ERROR:          MISC0 = 0x1
ERROR:          MISC1 = 0x0
ERROR:          MISC2 = 0x0
ERROR:          MISC3 = 0x0
ERROR:          ADDR = 0x8000f1b89e03e000
ERROR:   sdei_dispatch_event returned -1
ERROR:   Powering off core
Do you backup on the first Orin Nano devkit and restore on another Orin Nano devkit? (both connecting with an NVMe!?)
one and the same nvme0。
I’ll backup the system first,Then burn other systems,Then use the previous backup file to restore。
What system were you burning?
Does it also modify the partition layout in NVMe?
I use SDK MANAGER
Then burn other systems” do you mean flashing other release through SDK Manager?
Please share the detailed steps how you reproduce the issue.
