Please check the following details which can help your team to reproduce the issue.
OS: Windows 11
Commands Executed:
cd C:\Users\dev\AppData\Local\ov\pkg\isaac_sim-2022.2.1
.\python.bat tools\composer\src\main.py --input parameters\flying_things_3d.yaml --output dataset\tutorial_1 --num-scenes 10 --/renderer/multiGpu/enabled=false --renderer/activeGpu=1
Parameter file path used:
C:\Users\dev\AppData\Local\ov\pkg\isaac_sim-2022.2.1\tools\composer\parameters\flying_things_3d.yaml
Error Log:
2023-09-19 13:13:48 [14,756ms] [Warning] [omni.client.plugin] Tick: provider_nucleus: CC-493: Request through cache failed. Retrying without cache for omni1ReadAssetVersion(omniverse://localhost/NVIDIA/Materials/Base/Architecture): INVALID_URI
2023-09-19 13:13:48 [14,756ms] [Warning] [omni.client.plugin] Tick: omniclient: CC-873: Bypassing cache until the application is restarted
Screenshots Zip attached.
Archive.zip (594.7 KB)
