Request to analyse GPU running 95% in GeForce 8400M GS on centOS 7.6
Dear Team,
Any one had faced the same issue with my laptop. There is alert message shown me : GPU is running 95% and temp : 74c. I’m running NVIDIA GeForce 8400M GS (NVIDIA -Linux-x86_64-340.107.run) on CentOS 7.6.
Are there any solution which you can share me ?
[root@localhost ~]# nvidia-smi
Wed Jan 30 21:58:52 2019
| NVIDIA-SMI 340.107 Driver Version: 340.107 |
| 0 GeForce 8400M GS Off | 0000:01:00.0 N/A | N/A |
| N/A 74C P12 N/A / N/A | 124MiB / 127MiB | N/A Default |
| Compute processes: GPU Memory |
| GPU PID Process name Usage |
| 0 Not Supported |
[root@localhost ~]#
Regards,
Bounpone
[root@localhost Downloads]# lshw -C display
*-display
description: VGA compatible controller
product: G86M [GeForce 8400M GS]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
configuration: driver=nvidia latency=0
resources: irq:33 memory:ce000000-ceffffff memory:d0000000-dfffffff memory:cc000000-cdffffff ioport:2000(size=128)
Unless this is specific to imaging software under the Clara SDK you should consider posting here instead:
https://devtalk.nvidia.com/default/board/98/linux/
FYI, 74c is fairly low for most GPUs (though I don’t know about in a laptop mobile app). See:
https://nvidia.custhelp.com/app/answers/detail/a_id/2752/~/nvidia-gpu-maximum-operating-temperature-and-overheating
I am guessing some other application was set up to monitor temperature and uses some default value which is rather low.
If running the NVIDIA driver under Linux (not the Nouveau driver), then you will have this application (and this application has a “Thermal Settings” for monitor):
nvidia-settings
Dear Linuxdev,
thanks for your recommend. I will open the topic in that link which you shared.
thanks,
Bounpone
