Request to Increase Rate Limit for NVIDIA NIM API — Personal Development / Agentic Coding Workflow
Hello NVIDIA Team,
I would like to request a rate limit increase for my NVIDIA NIM API usage in a personal development and prototyping environment.
Current Usage Context
  • Account type: Free trial / default trial rate limit
  • Current limit: current default trial rate limit
  • Requested limit: 200 RPM, or the next available higher tier for individual developer use
Models used:
  • nvidia/nemotron-3-super-120b-a12b
  • nvidia/nemotron-3-ultra-550b-a55b
Purpose of Increased Limit
I am using the NVIDIA NIM API to evaluate and prototype an agentic coding workflow built around OpenClaw and Aider on my local Mac mini environment.
This workflow involves multiple steps per task, including planning, code review, validation, tool use, and iterative refinement. As a result, a single user-level task may generate multiple sequential API requests.
A higher limit would help me:
  • Validate and prototype the OpenClaw + Aider agentic coding pipeline locally.
  • Test and refine automation scripts for local development repositories.
  • Evaluate different model tiers, using Nemotron-3 Super 120B for general tasks and Nemotron-3 Ultra 550B for high-complexity reasoning and review.
  • Reduce interruptions caused by throttling during local development and testing.
Usage Control Plan
To ensure responsible usage, I will:
  • Enforce strict concurrency limits, generally no more than 2–3 simultaneous requests.
  • Minimize redundant calls by caching or reusing results where appropriate.
  • Reserve the 550B model for high-complexity reasoning and validation tasks only.
  • Use the 120B model for the majority of routine interactions.
  • Maintain fallback providers for non-critical tasks.
  • Avoid unnecessary repeated calls and long-running automated loops.
  • Not use the NVIDIA NIM free endpoint for production traffic, public-facing services, or external customer workloads.
Security and Compliance
I will not expose the full API key publicly. If account verification is required, I can provide the relevant account information or API key suffix privately through the appropriate support channel.
No secret keys, tokens, or credentials will be committed to repositories or shared publicly. All usage is for local personal development, prototyping, and evaluation.
Thank you for reviewing my request. Please let me know if any additional information is needed.
Best regards,
Namhee Lim
Hey @lnh, I don’t know if this helps, but a moderator previously replied with this to someone asking for the same thing as you:“Many of you are using free tier API access to NVIDIA NIMs. This usually involves a rate limit that is dependent on model, use-case and the amount of current overall traffic using the same access. There is no official way to circumvent this rate limit or to receive a rate limit increase on that same tier. And specifically here on the forums we do not have any influence on those rate limits. To make full use of a NIM blueprint you will need to deploy it. For more details on NVIDIA NIM refer to…”
Basically, this means that if you are using the free-tier API, you have absolutely no right to request an RPM increase in free tier. The only way to legitimately request higher RPM limits is:
Not through the forum. Moderators have said it over and over again: the forum is not the place to request RPM increases, as there are other channels and processes for that.
You need to pay and deploy a model through NVIDIA NIM / NVIDIA Build if you require higher usage limits and production-level access.
First, go to the model you prefer, for example DeepSeek V4 Flash. In that section you’ll see three options: Experience / Model Card / Deploy.
Click on Deploy and you’ll see several options such as Partner Endpoints or Self-hosted Deployments.
From there, you choose the option you want, and it will show you the pricing and deployment costs.
You can start with DeepSeek Flash since it’s the cheapest one, so you can learn how the process works first. And if you need help, you can always contact a moderator privately and ask for guidance. There’s no problem with sending a direct message saying you want to pay and deploy properly.
I am not saying this to be toxic, rude, or disrespectful. My goal is simply to help you understand and follow NVIDIA’s rules and the guidance that has already been provided by moderators multiple times.
IF YOU ARE ALREADY PAYING FOR NVIDIA SERVICES AND DEPLOYED MODELS, THEN YOU SHOULD CONTACT NVIDIA DIRECTLY THROUGH THE APPROPRIATE SUPPORT CHANNELS, SUCH AS EMAIL OR PRIVATE COMMUNICATION WITH THE RELEVANT SUPPORT TEAM, RATHER THAN MAKING RPM INCREASE REQUESTS ON THE FORUM.
