We are requesting you to provide the SOC details (part number, technical Specification and features) which is used in NVIDIA DRIVE AGX ORIN Series.
Regards,
Sangeeta K
Regards,
Sangeeta K
Dear @sangeeta.kopparad ,
Could you check DRIVE AGX Autonomous Vehicle Development Platform | NVIDIA Developer
and https://www.nvidia.com/content/dam/en-zz/Solutions/gtcf21/jetson-orin/nvidia-jetson-agx-orin-technical-brief.pdf
Hi Siva
I have checked above mentioned link, but i am not seeing any info related to SOC for ORIN Series. and also i am seeing doc related to JETSON. but we know that Jetson is for Robotics Application. Please provide SOC info(Part number and technical features) of DRIVE AGX ORIN Series.
Regards,
Sangeeta K
Jetson AGX orin and DRIVE AGX orin both are based on same Orin SOC. They could be difference in frequency of each engine, RAM, cores etc.
DRIVE AGX Autonomous Vehicle Development Platform | NVIDIA Developer gives info on the perf and configuration on Orin SOC in DRIVE.
You can refer to Jetson AGX orin technical brief document to get an overview of the Engines in Orin SOC.
Note that though both Jetson and DRIVE based on same Orin architecture, the BSP and release packages are different for each board.
May I know what part number you are referring? Are you asking about Orin SoC HW schema details?
If so, please contact your NVIDIA representative for details.
Hi Siva,
Can you please confirm if the DRIVE AGX Orin and Jetson AGX Orin use the same Orin SoC, or are they using different Orin SoCs for the two different platforms?"
Regards,
Sangeeta K
Mots of them are the same, but different SKUs.
Hi Kayccc,
Can you please elaborate about the SKUs? and what are the specification will change between JETSON and DRIVE AGX ORIN SERIES?
Regards,
Sangeeta K
We do not disclose the details of SoC.
May I know why that’s a concerns on your development?
