Requesting activation for Public API Endpoints (404 error on NIM endpoint)
Description
When attempting to invoke NVIDIA NIM cloud-hosted vision models (such as meta/llama-3.2-11b-vision-instruct or minimaxai/minimax-m3.1-flash) via the standard OpenAI-compatible client endpoint ([``https://integrate.api.nvidia.com/v1``](``https://integrate.api.nvidia.com/v1``)), API calls consistently fail with a 404 Not Found error indicating that the specified function/model ID cannot be located within the authenticated developer account.
Environment
TensorRT Version:N/A (Cloud API execution)
GPU Type:Tesla T4 (Google Colab Free Tier)
Nvidia Driver Version:N/A (Cloud-hosted inference endpoint)
CUDA Version: 12.1 (PyTorch 2.11.0+cu130)
CUDNN Version:N/A
Operating System + Version:Ubuntu 22.04 LTS (Google Colab Environment)
Python Version (if applicable):3.13.1
TensorFlow Version (if applicable):N/A
PyTorch Version (if applicable):2.11.0+cu130
Baremetal or Container (if container which image + tag):Google Colab Cloud Notebook Container
Account Identifier / Email: smarika343@gmail.com
Steps To Reproduce
Please include:
  • Exact steps/commands to build your repro
  • Exact steps/commands to run your repro
  • Full traceback of errors encountered
NotFoundError Traceback (most recent call last) /tmp/ipykernel_2413/1437332425.py in <cell line: 0>() 13 14 # 3. Test a query using MiniMax M3.1 Flash (or Llama vision model) —> 15 response = client.chat.completions.create( 16 model=“meta/llama-3.2-11b-vision-instruct”, # or “minimaxai/minimax-m3.1-flash” 17 messages=[{ 3 frames /usr/local/lib/python3.13/dist-packages/openai/_base_client.py in request(self, cast_to, options, stream, stream_cls) 1146 1147 log.debug(“Re-raising status error”) → 1148 raise self._make_status_error_from_response(err.response) from None 1149 1150 break NotFoundError: Error code: 404 - {‘status’: 404, ‘title’: ‘Not Found’, ‘detail’: “Function id ‘9fa6fd04-ba2c-4bb3-90b7-ede407a9290f’ version ‘null’: Specified function in account ‘120OCSZ1QE11NPPzMcUdJUe5I8pC8lGzb4oaq6C_fGM’ is not found”}
Account access issues are not handled here through the forums.
Please check the pinned posts:
for details.
Thank you!
