Requesting entitlement to NuRec container on NGC
Hi NVIDIA team,
I’m following the official Omniverse NuRec documentation, specifically the “Reconstructing scenarios as 3D scenes” step (reconstructing real-world sensor/video data into USDZ). I’m trying to use the NuRec container from NGC for this workflow, but it appears I don’t have the required repository entitlement.
I can authenticate to nvcr.io successfully (docker login nvcr.io succeeds), but pulling the image fails with an access error:
docker pull nvcr.io/nvidia/nurec:latest
denied: {"errors":[{"code":"DENIED","message":"Access Denied"}]}
This suggests that nvcr.io/nvidia/nurec requires an entitlement beyond standard NGC login.
Could you please advise on:
  1. How I can request/obtain access to the NuRec container repository (nvcr.io/nvidia/nurec), or whether you can grant the required entitlement to my NGC account.
  2. The correct image path and available tags for the NuRec “core” reconstruction container (in case the repository name or tag is different from nvcr.io/nvidia/nurec:latest).
Environment (optional, if useful):
  • OS: Ubuntu 20.04.6 LTS
  • GPU: RTX A5000 + H100 PCIe (MIG enabled)
  • NVIDIA driver: 550.144.03
  • Docker: 26.1.3
  • NVIDIA Container Toolkit: 1.18.1
Thank you.
j77570265
Hi there and thanks for posting.
NuRec access is controlled via NVIDIA’s NGC/enterprise entitlements. Are you Enterprise? You have to be.
It is here at
Neural Reconstruction Engine Container | NVIDIA NGC
  • The NuRec docs state that the reconstruction models/services are provided as a “core NuRec container from NVIDIA,” but we do not publish a public nvcr.io/nvidia/nurec:latest path or open access instructions in the generic docs. docs.nvidia
  • The “Access Denied” error you see when pulling nvcr.io/nvidia/nurec:latest means the repository is private and requires an explicit entitlement on your NGC organization or user account, just like other restricted NGC containers.
The container for NuRec is publicly available: Neural Reconstruction Container - GA | NVIDIA NGC and AlpaSim is Open Source: GitHub - NVlabs/alpasim · GitHub
