• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0.1
• TensorRT Version 8.0.4
• NVIDIA GPU Driver Version (valid for GPU only) 11.4
• Issue Type( questions, new requirements, bugs) new requirements
Hello
I left an issue the other day that there was a bug in the Full Frame Inference result using Gst-nvdspreprocesses.
When I looked again after some time, I looked at the scale_and_fill_data
function in the file below and found that mainain-aspect-ratio
was not activated. So, in the case of yolo detector series…, mainain-aspect-ratio should be activated due to letterbox(padding features), but an error occurred because there was no value for the key value. In other words, only variable values are declared.
/opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-nvdspreprocess/gstnvdspreprocess.cpp
When I modified the code randomly, the above issue disappeared.
Please officially activate main-aspect-ratio
and add Symmetric Padding
option.
